Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
LinkBack Thread Tools
Old 18th March 2007, 01:18   #31 (permalink)
tsk1979's Avatar
Originally Posted by esteem_lover View Post
Really !!! this has got me very interested indeed. how much for the power supply then ?
Power supply would be 12 V - (12/5V/3V). You can get such a supply custom made in bangalore using the best components for about 300rs. Wish there was a SJP road in Delhi, Nehru place may be great for PCs but for electronics components, esp like op-amps etc., its very difficult to source anything.
__________________
Reclaimed, wrung dry and recycled....!
Old 18th March 2007, 02:30   #32 (permalink)
rishibravo's Avatar
Originally Posted by rishibravo View Post
I think Ankut speint close to 20,000$ in getting that CarPC in his car.... I think the most difficult thing would be to get the low power consumtion motherboard. Tried a lot at NehruPlace market but couldnt find it. It will be awesome to get a CarPC but my palio Dash has no space whatsoever to put a touchscreen LCD
sorry guys about the typo...its was $2000 ..but the effort that Ankur had done on it was amazing...
__________________
Boyz will remain Boyz.......Only their Toyz change
rishibravo is offline   Reply With Quote
Old 18th March 2007, 11:06   #33 (permalink)
sys_whiz's Avatar
The Mini ITX motherboard inclusive of processor costs about 3500 Rs max in delhi.
All you need to do is add RAM and HDD which takes the entire cost of the hardware, except for touch screen LCD and peripherals to around 9K.
The board is made by Kobian(Mercury) though the chipset is VIA.
Expect high costs if you want a VIA made motherboard.
tsk, I believe you are talking about flex itx board(230 X 190 mm), not mini itx(170 X 170 mm). Mercury has this board which has onboard via c3 processor. These boards are not designed for vehicle install. We can use these as a barebone install.
Mercury-pc.com
sys_whiz is offline   Reply With Quote
Old 18th March 2007, 11:12   #34 (permalink)
sys_whiz's Avatar
wow that's great. If we can get a DC-DC PSU in Rs. 300, its amazing. Do they manage to provide the start-up and shutdown controller too in the PSU?
Old 18th March 2007, 14:16   #35 (permalink)
tsk1979's Avatar
Mercury-pc.com
Nope not this one. The one I talk about is not on mercury site, its been discontinued, and some dealers at Nehru place have an old stock. A friend was trying for one, but after that he settled for a second hand HP/HCL think client, reflashed the motherboard and booted linux on it. Its an ideal low power motherboard with processor which is being used as a routing box now.
As for the link you posted, why can't that be used in-car? Any particular reason. If you have a large sedan, or a SUV, there is ample amount of space.
No, this is just power supply.
You have to find circuits on the web. Buy parts and those guys charge around 100-200rs for assembling and soldering etc.,
The parts are pretty cheap, all you need is make a regulator circuit.
__________________
Old 18th March 2007, 14:40   #36 (permalink)
Ya till heat isssue is controlled any board can be installed. I dont think that the mercury board has any issue...........
Ya the power supply can be done if you know some thing call DIY (do-it-yourself)........
Old 19th March 2007, 00:02   #37 (permalink)
tsk1979's Avatar
The good thing about SJP road or SP road BLR is that you don't have to struggle with a soldering iron. You just have to get the circuit from the web, and then ask those guys to assemble it for you. If you buy parts from that shop, it will cost you around 200rs for assembling.
__________________
Old 19th March 2007, 08:27   #38 (permalink)
hydrashok's Avatar
I just saw this on Gizmodo. Car PC from Shuttle. Not a DIY thing, but maybe you folks would be interested:
Source: Shuttle Car PC: A Techier Way to Die - Gizmodo
Shuttle just announced their new Car PC—or what looks to be a Mac Mini genetically enhanced with car audio badassness (known to some as a heat sink). Internally, the Car PC will run an Intel Core Duo chipset (not the 2 Duo, apparently) and store information on a standard laptop hard drive. 7.1 sound and graphics are predictably integrated onboard.
But what's so appealing about the Car PC is that it's powered by your car battery and will automatically shut down with no lost data when you turn off the ignition. So that quarterly budget you finished on the way to work will stay safe even after you park your car outside the hospital.
A little more info here; CeBIT 2007 – Shuttle's upcoming Car PC :: TweakTown
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 19th March 2007, 13:58   #39 (permalink)
ankur's Avatar
I would be very worried about using a PSU like that on my PC. I would rather spend more money and get something that has proven reliability and and a true spec rating. Be careful if you opt for getting a PSU made here. Keep in mind that an incorrectly made PSU can be a fire hazard apart from finishing off your PC components.
cheers.
ankur is offline   Reply With Quote
Old 19th March 2007, 14:08   #40 (permalink)
tsk1979's Avatar
cheers.
Welcome to the real world Ankur.
If you ever opened a factory built PSU that is normally sold in the market here, or connected it to a Oscilloscope, you would shudder every time you switched on your PC.
The kind of PSU you can get made using the best components is not easily available over here. I have blown motherboards due to so called factory made PSUs. Many of them do not even have a filter circuit at the end of the AC-DC converter, so you actually get very dirty DC.
If you are going to do a DIY, better go all the way. After all the argument is the same as assembling your PC yourself or letting Compaq/Dell doing it for you.
__________________
Old 19th March 2007, 14:22   #41 (permalink)
ankur's Avatar
In the real world people dont use oscilloscopes every time they are buying a PSU. I bought an Opus PSU simply because of their reputation, they could be making crap but most of their clients are happy with them, including me.
DIY is simply do it yourself there is no degree of it. The best part is that I decide how much i want to do myself someone else can make a fab and do their own CPUs for their own DIY fetish. There is no limit for going all the way in a DIY situation.
If you notice my post you will see that its my opinion about what i would do, i am not telling someone else not to buildt their own PSU.
I dont think the argument is the same as assembling your own PC or buying a ready made. No one really makes their own PC, not even Dell or Compaq. They also assemble from components that you or me can use. You are talking about trying to make each and every component. Why stop at the PSU, why not try making a hard disk next. Taking your DIY all the way, why even get a PSU made ? Make it your self.
cheers.
Old 19th March 2007, 14:26   #42 (permalink)
tsk1979's Avatar
Sometimes DIY is a necessity. I can get a HDD.
But as you must have discovered yourself, availability of rarely used peripherals is very bad over here. So unless you want something which sells in numbers you cannot source it.
So if you can find a 12V DC-DC PSU for a car PC made by a reputed manufacturer, its good, but if you can't then you go DIY.
__________________
Old 19th March 2007, 14:33   #43 (permalink)
ankur's Avatar
Thats true. I had the luck of being able to source most of my stuff from the US and get it here .
Old 19th March 2007, 15:39   #44 (permalink)
devarshi84's Avatar
I am researching on this issue at presnt and am really close to a solution. Need 2-3 days to work out on it. My main intent is streaming music in a car with the help of a reliance data card thereby eliminating the need to carry a hard-drive based unit.
will post on all the details such as price, features, availability, wi-fi, music etc.
__________________
-The Boyracer
2000 Suzuki WagonR VX
2003 Mitsubishi Lancer SFXi (soundstream ICE)
2008 Suzuki Access 125
devarshi84 is offline   Reply With Quote
Old 19th March 2007, 16:02   #45 (permalink)
rishibravo's Avatar
The data card gives you really bad bandwidth and it would be difficult to stream good quality music. Why arent we looking at the HDDs which come fitted in the Creative products ( I think they are Toshiba make and available in 30Gig and 60Gig). The advantage is that these hard drives are built to withstand shocks but that also means extra cost. Or we can simply use the laptop HDD with a USB casing. Let the OS boot from the USB Mass storage device. This is possible in the current Desktop motherboards (I am not sure if its possible in Mini ITX motherboard though).
__________________
Thread Tools
Engineering Studies: Discuss What is What and Where ! MillionSwords Shifting gears 2 6th September 2009 22:19
Maruti to build made-in-India car undead The Indian Car Scene 3 14th November 2008 09:19
planning to build car sub amp, help needed clipto333 DIY - Do it yourself 204 17th August 2007 16:25
Toyota, Daihatsu set to build car plant in India gr8guzzler The Indian Car Scene 3 9th July 2005 01:15
how to build a kit car? Harrie Modifications & Accessories 21 18th March 2005 16:30
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653
