| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #136 (permalink) | |
| BHPian | Quote:
waiting waiting. sir ill not kill anyone for a transformer. i was talking about the meet yesterday. im coming to delhi on the 18th. how far is faridabad ? i definitely want to hear your system at work. how are the id max's ? never heard such high end drivers and amps. cheers clip sir please post the specs for transformer quickly otherwise ill definitely kill you. lol. me enjoying sunday. | |
| | #138 (permalink) | |
| BHPian | Quote:
tell me how to wind a toroidal. do i need 2 wires for +ve and neutral or a single wire with the 2 ends as mains wires? and please reply asap. cheers clip | |
| | #139 (permalink) | |
| BHPian | Quote:
im still waiting for the details dude. and now im gonna kill you. im coming tomorrow so you better watch out. ![]() ![]() navinji can i have your ph. no? this will be much faster. please pm me your no. i need to know things about trannys( transformer you idiots :-)) cant use a smiley. and im not going to repeat this as it too long. ill use the shorter) cheers clip cheers | |
| | #140 (permalink) |
| Senior - BHPian | yaar could not find the notes....but here is some thing which will help...... firstly which wire gauge to use.....thicker the wire more current carrying capacity it can handle.....so it will depend on the final output you require at the output stage....so I will consider some factor as constant...like you require 0-24 volts and that two tappings....and I will assume you will be putting 5 amps load on the winding so the final load will be 10 amps on the secondary......and on the primary you will be getting a load of 10 amperes x 24 volts = 240 VA = 220 volts x 1.09 amperes so now you will be have your currents value with you.....the primary would be running at 1.09 A and the secondary at 10 A.......here you can select the wire gauge of the same with a little above the rating for the saftey factor.....like 18-19 gauge for the secondary and the 26-27 gauge for the primary...... American Wire Gauge table and AWG Electrical Current Load Limits now the number of turns.....suppose you make 400 turns in the primary and 200 in the secondary and the input voltage is 220 volts then the output will be 110 volts.....because as the number of turns are half the voltage will also get half......so if you plan to get 22 volts then you will require to do....40 turns to get the required voltage..... Turns-> volts 400 -> 220 200 -> 110 100 -> 55 50 -> 27.5 40 -> 22 Hope you understand a bit....
__________________ 156.6 db, naa....time is coming to cross it...... |
| | #141 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
And certainly not if you call everyone idiots. We love humour, but do be nice and try and find that line you cannot cross. And Navin is here to help you, but he is a busy man. He logs on when free, you may end up calling him when he isn't. You can get advice from Navin here, or PM him. I am sure he will reply as soon as he has time. Take it easy then, will you? Cheers.
__________________ Live the YetiLife® Madonna is a Goddess. | |
| | #142 (permalink) | |
| BHPian | Quote:
cheers clip | |
| | #143 (permalink) | |
| Senior - BHPian | Quote:
and why would 400 turns of 1 wire would trip the MCB.......also the two wire ends would be the neutral and phase.....
__________________ 156.6 db, naa....time is coming to cross it...... | |
| | #144 (permalink) | |
| BHPian | Quote:
cheers if you can call my no is 98723t66634 | |
| | #146 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
In all single step, step down transformers (like yours) the primary wire will be much longer than the seconrdary. If I am right the primary wire would aboue 8 times longer. read this primer Transformers Part 1 - Beginners' Guide to Electronics and this small PDF http://www.q-tran.com/pdf/the_toroid_truth.pdf this is how guys like miracle electronics winds theirs SMC-2 Picture and here are some design tools SWITCHER.NATIONAL.COM - Simple Switchers, Switching Regulators, Buck Converters,Buck-Boost as you can see that winding a torroid is a time consuming process unless you have some ratheer special machinery.
__________________ Scixelsyd Etinu | |
| | #147 (permalink) |
| Thanks Sam. Clip feel free to PM me. I log on when I am free and my life is kinda crazy. I really wish I could log on more. This forum does de-stress me a lot. If you want 220V on the primary and 22V on the secondary the turn ratio would be 220:22 or 10:1. Now you have to determine what the VA of the secondary need be. If you want 220VA then you need secondary wire that can hanlde 10A (220VA / 22V). Your primary wire will be a lot thinner (it need only carry 1A). This is as simple as I can make it. As Sam can tell you I am doing my best to keep it simple.
| | #148 (permalink) | |
I would second that......get a ready made one....dont go in the hassle of winding one or there can be any accident.........and your are going to make a AMP....not a Transformer........ ![]()
| | #149 (permalink) |
| BHPian | hi, i managed to wind the toroid...it took me like 15 hours at a stretch. i tested it on the mains. i wound a thick secondry with quite a few turns. it was giving me 14v. i think its working fine. me in delhi rightnow so ill wind the secondaries when i go back. thanks for your advice guys. it really helped me. and lbm the transformer is also a part of the amp . sam, just chill. well im sorry for that. and i hope lbm knows its just a joke. i was in a real hurry as i had to leave for delhi next morning, thats why i asked the number. lbm are you free?? wanted to hear your ice. if not possible nevermind cheers clip |
| Thread Tools | |
Similar Threads | ||||
| planning to build an atv or a quad bike !!! | gonecase_01 | Modifications & Accessories | 26 | 8th September 2008 14:22 |
| Nissan Planning To Build Anti-Drunk Driving Cars. | ollie | Shifting gears | 3 | 4th October 2006 21:55 |
| Planning to sell Esteem (help needed to fix selling price) | Minardi | Shifting gears | 3 | 22nd June 2006 22:52 |
| how to build a kit car? | Harrie | Modifications & Accessories | 21 | 18th March 2005 16:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
