| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #196 (permalink) |
| BHPian Join Date: Jun 2007 Location: Pune
| I am not sure, how to edit the old link. But below link works in my both computers. 41Hz Audio Forum Regards |
| | #197 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| Enh!? Sure, the link works, and the photos are visible. Superb work, Mishra-ji! The amp looks neat and well finished. * Where did you get the front baffle for the speaker boxes? Seems to have 2 ports! What are the drivers that you have put in? * Or, did you buy these boxes readymade? * Where did you get the input select switch from?
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #198 (permalink) | |
| Thanks DerAlte, That I wanted perfect 99% silent without input with full volume. Now it cleaned more. Quote:
I calulated the port volume /area and resonance frequecy was decided 60Hz. (I wanted to avoid any 50Hz hum and below that I cant hear). Box volume calculated and odd dimensions were given to that guy to make boxes.(8.5"WX13.5"HX11"D) to avoid internal reflection and waves cancelling/resonating. MDF ply thick ness is 1". costed 350Rs for pair. Regarding dual port it does not matter number of ports (total volume V=V1+V2) Inside surface is coated with dual foam tape as Damping material. Over that I pasted all side using buble sheet (packing material) , exposing bubbles to internal air, so damping is good and cleaner/hygenic than fibre glass wool. This switch is available anywhere on SP road. I bought in Marudhar Ele. Ulsoor, end of CMH road. There are two qualities, I selected the one with chrome plated connectors and phenolic PCB (can be seen from connector side) Rs 80. Drivers I am using normal Bolten one (200Watts), but planning to replace soon with Luxco which I have in my hometown. It has 2" diameter voice coil. and 2.5kg Magnet for 8" driver. Cheers, | |
| | #200 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
Another website for the same -> SeekandSource.com - Radio Electric Pvt. Ltd..
__________________ Ein bißchen Frieden | |
| | #202 (permalink) |
| BHPian | hi guys, finally, i bought an lcr meter. got it for 2k. the brand is lutron. dont know if it is a known brand though. now i need a true rms meter and an osci. the target is to buy it next month. and im going to delhi on the 24th. can anyone suggest a good electronics store? it would be of great help guys. i more thing. im trying to diy an LC meter. i got most of the components but the problem iam facing is that precision caps(1% or less tolerance. lesser the better) are not available here and i dont know what type of caps are the precision caps. can anyone help me out with these caps? please post a pic of a low tolerance cap if anyone can. cheer clip |
| | #203 (permalink) |
| BHPian Join Date: Mar 2004 Location: Ludhiana
| Rishab, I have tried looking around A LOT. Couldnt find much of the stuff. Only low grade chinese, If at all. My friend tells me there is one last store left. Will see that too before my final answer.
__________________ Punjabi for Life. |
| | #205 (permalink) | |
| BHPian | Quote:
thanks for looking around ss. i really appreciate your help. this is the problem. no one keeps good electronic stuff. this is the only reason why i dont like india (assuming this is the case everywhere). india is not a DIY friendly place. maybe delhi has the stuff im looking for. ill be going there on the 24th but i still dont know any place and store. cheers clip | |
| Thread Tools | |
Similar Threads | ||||
| Discuss how to build a Car PC.... | sys_whiz | DIY - Do it yourself | 53 | 19th April 2007 00:09 |
| planning to build an atv or a quad bike !!! | gonecase_01 | Modifications & Accessories | 25 | 20th January 2007 12:16 |
| Nissan Planning To Build Anti-Drunk Driving Cars. | ollie | Shifting gears | 3 | 4th October 2006 21:55 |
| Planning to sell Esteem (help needed to fix selling price) | Minardi | Shifting gears | 3 | 22nd June 2006 22:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
