| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #31 (permalink) |
| BHPian | hi guys, thanks a lot for the replies. im not gonna build a car amp as of now as i don't have the required experience. ill go for home amp. i already have 2 lm3886 chips but im confused as there are too many schematics. DIY Chip Amplifier Kits, PCB's, Components and Information. has a kit based on 3886. should i replicate that? and how much watts will it put out? i want to be realistic. when i have the experiance ill go for bigger amps. guys you know what it is, the excitement is there so much that you think you can diy anything. Navin, the drivers i was reffering to were 6 ohms(im confused now if they are 6 or 8 ohms.) they were 6 ohm definitely. lol i think you mistook it for 6". they are from my old sony stereo system. they are floor standers with a 6 incher midbass i guess and edge drived dome tweeter( i dont know if im correct can any one explain edge driven? the coil is on the edge of the dome and the dome itself is removable. i think ts-20s are the same kind) theres also a xo which is mounted inside of the terminals and are glued there so couldn't check. i love the sound quality of the speakers. are the drivers made by sony ? will let you guys know what i decide. yaar if anyone has a schematic with parts lits please post it yaar. thanks rishabh |
| | #32 (permalink) |
| BHPian | hi, the elec shop guy in jalandhar has a 48v smps ps. can i use it with these chips or is it too much. can anyone tell me how to wind a toroidal core. eg. what do you mean by no. of turns, 4+4, what wire size to use etc. how do i convert a schematic into actual board design? thanks rishabh |
| | #33 (permalink) | |
| Senior - BHPian | Quote:
dont go for number of turn or such details....for ordering a simple transformer or a torodial you require first the input and the output voltages and second the current requirement or how much power would you require which that transformer can deliver......and the tapping you require...thats all..... hmmm like this one.... ![]() here you can see the pri or the input voltage is 230 volts and the secondary is having 4 taping which are 71-0-71 , 71-0-71 , 12-0-12, 15-0-15 which are used in different circuits of the amp.... here is a full pic of that same amp.... ![]() in the above amp he is using simple bridge rectifiers to supply the DC and two capacitor on each side for filtering it....the main power supply to the amp section is of 71 volts wala...for the pre-amp section and the fans and other stuff the 15 and 12 volts supply is used..... the above amp is capable of 800 watts rms x 2 at 4 ohms.....and it is full range amp... which circuit have you decided to make....there are many software which can help you to make the PCB design
__________________ 156.6 db, naa....time is coming to cross it...... | |
| | #34 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
LBM are those fans always on or do they trigger if the heatsink gets too warm? I dont see a thermistor on that photo but some amps use current triggers as well. clip the V on your tranny should be atleast twice the output wattage. so if you are looking at a 50W x 2 amp I would suggest a 300 VA tranny.
__________________ Scixelsyd Etinu Last edited by navin : 23rd March 2007 at 09:44. | |
| | #36 (permalink) | |
and i can see the thermistor at the bottom end of the heat sink .....white grey in colour.....Navin Ji I think you must get some close eyesight glass.......just joking.....
| | #38 (permalink) | |
| BHPian | Quote:
im planing on using the chipamp schematic for my amp. can i use short forms? i fractured my finger last night so cannot write properly. and is there any substitute for the mur860 diode? do i need it? where can i get it in india thanks Last edited by clipto333 : 23rd March 2007 at 11:51. | |
| | #42 (permalink) |
| BHPian | hi navin, well i asked something sir. can i use short hand because i fractured my finger lastnight? it is a special request to the mods. never mind if not possible. i have 15 days now before i can solder again. so will look for the diode and psu. thanks please let me know from where i can source this mur860 fast diode? or is there an alt diode which i can use without creating problem in the amp? |
| | #43 (permalink) |
| BHPian | hi guys, i have a diode which says fmgg2c. i googled and it says fast rect diode dont know if i can use it. please search for this diode and let me know. also i have a pc smps. is it possible that this psu uses ultra fast diodes? please bhai logon let me know asap thanks rishabh if im really asking for too much then upto you guys i you wanna help or not. i not getting the required help here. i have to look elsewhere |
| | #45 (permalink) |
| the problem is that a) I am too old to follow that SMS stuff kids use nowadays b) can imagine if everyone starts using SMS claiming some injury or handicap? The amp can wait. I will be here for more than the next 15 days. You can PM me SMS if you like but given my understanding of SMS I wonder if it will lead to more questions than answers! :-)
__________________ Scixelsyd Etinu |
| Thread Tools | |
Similar Threads | ||||
| planning to build an atv or a quad bike !!! | gonecase_01 | Modifications & Accessories | 26 | 8th September 2008 14:22 |
| Nissan Planning To Build Anti-Drunk Driving Cars. | ollie | Shifting gears | 3 | 4th October 2006 21:55 |
| Planning to sell Esteem (help needed to fix selling price) | Minardi | Shifting gears | 3 | 22nd June 2006 22:52 |
| how to build a kit car? | Harrie | Modifications & Accessories | 21 | 18th March 2005 16:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
