Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 2nd April 2007, 20:12   #106 (permalink)
clipto333's Avatar
Originally Posted by low_bass_makker View Post
the 300 VA 24-0-24 or 25-0-25 or 24-0-25 step down would cost around 1200/- .........for 1500/- it is a bit on the higher side....is there any brand related to the transformer or just it is a local brand....I used to get GURU....they were quite good.....
i think guru is available here. the transformer is local made.
ill try and find out if guru's avaiable.
thanks
clip
ot - hey lbm, nice amps.
clipto333 is offline   Reply With Quote
Old 3rd April 2007, 10:37   #107 (permalink)
Team-BHP Moderator
navin's Avatar
1200-1500 is a good price. Miracle would be more I guess.
__________________
Scixelsyd Etinu
Old 3rd April 2007, 14:32   #108 (permalink)
clipto333's Avatar
hi,
ill buy it from here only. but my project is stuck as i dont know the size of resistors, caps etc. size as in physical size. so dont know what to use from the library of eagle. wish i had a board design of pa100 in eagle.
cheers
clip
Old 5th April 2007, 18:53   #109 (permalink)
clipto333's Avatar
hi,
i was thinking if i can use 3 drivers on 1 channel? eg. if i use 8 ohm drivers( woofer,mid,tweeter) is it possible to get 8 ohm load on the amp on 1 ch? ill use a crossover but dont know how il get the impedance to 8 ohms.
1 thing more. i have hertz energy 165 comps. the drivers are 4 ohms. they have seperate XOs. what will be the final impedance if they are wired in parellel i.e. 1 tweeter and 1 woofer on 1 channel of the amp?? im confused. do they present a 2 ohm load on the amp?
cheers
clip
Old 6th April 2007, 01:03   #110 (permalink)
low_bass_makker's Avatar
no the final load will be 4 ohms if you connect them through the XOs......as there is a capacitor in the way....which will reduce the impedence of the tweeter....
__________________
156.6 db, naa....time is coming to cross it......
Old 6th April 2007, 10:53   #111 (permalink)
Bass&Trouble's Avatar
cheers
clip
Any component set has one woofer and one tweeter on one channel of the amp. That is normal. Just dont bypass the crossover while wiring like this.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 6th April 2007, 13:46   #112 (permalink)
clipto333's Avatar
hi,
i know how to wire the comps. just want to know how the capacitors lower the impedence. lower as in 4 to 8?? or 4 to 2??
lbm paaji please clarify.
cheers
clip
Old 6th April 2007, 14:21   #113 (permalink)
if we pass DC current from a capacitor it wil not allow but when we pass AC current it will allow to pass.....likewise in a inductor it will allow to pass DC current and will not allow AC current to flow....in the above statment if I mean allow to flow does not mean it will not flow but a liitle will flow...let me explain a bit further....
In terms of crossover there are capacitor, inductor and resistance is used...
the capacitor is used to make high pass filter.....the inductor is used to make low pass filter and the resistance is used to adjust the gain......
here is a simple circuit of a 6 db slope crossover in which the speaker is given a HPF with the help of the capacitor and the woofer is given a LPF with the help of a inductor......
you can see that the as the value of the capacitor or inductor the change of frequency is there......
there is something more left...will be posting soon...as I have to go for some work....
__________________
Old 7th April 2007, 12:38   #114 (permalink)
Team-BHP Moderator
navin's Avatar
clipto you are confusing impedance with resistance. impedance is depedant on the freq at which it is measured. if you are connecting a 8 ohm woofer, midrange and a tweeter via a crossover each driver will reproduce a seperate freq band and the nominal impedance of the speaker system will be 8 ohms. In reality there will be peaks and dips in the freq response.
A capacitor does NOT decrease or increase the resistance of a tweeter. It does however LIMIT the freq range of the tweeter. In a perverse way one can say that a capacitor INCREASES the impedance of a tweeter because a cap is an OPEN circuit to DC and as the freq of the signal increases the capacitor shows less resistance.
__________________
Scixelsyd Etinu
Old 7th April 2007, 17:46   #115 (permalink)
clipto333's Avatar
hi navin,
thanks for clarifying. what i understand from the above is that the nominal impedance of the speaker system( woofer,,mid,tweet ) will be 8 ohms nominal.
if i dont use a XO, will the nominal impedance still be 8 ohms??
Nominal impedance is measured in free air at a given low frequency right??
I just built a pcb myself. it turned out really good. ill post pics in a while. my cam is on charging. this was my first attempt and its almost perfect. i used the toner transfer method.
cheers
clip
Old 7th April 2007, 17:59   #116 (permalink)
if you dont have the XO then the nominal impedance will be 4 ohms when the woofer is 8 ohms and tweeter is 8 ohms....
yes the nominal impendance is measured in free air....when the impedance of speaker has reached the resonant freq it will have maximum impedance....
wating to see the pics of your amp.....
__________________
Old 8th April 2007, 00:30   #117 (permalink)
clipto333's Avatar
hi lbm,
thanks for clarifying. ive not build the amp yet. just built the pcb. ill post pics of that tomorrow.
cheers
clip
Old 8th April 2007, 01:11   #118 (permalink)
here is a graph of a sub the black line is the impedence of the driver....and its FS (resonant freq) is approx 75 hz.....at which the sub is having least impedance otherwise it is close to 4 ohms as the sub is a SVC......hope this make the thing a bit more clear....
__________________
Old 9th April 2007, 11:30   #119 (permalink)
Team-BHP Moderator
navin's Avatar
if you dont use an XO and connect all 3 drivers in parallel you will get a nominal impedance of 2.33 ohms (8/3). However once you connect your amp to this speaker and play it for a while the nominal impedance will rise to 4 ohms becuase you will have burnt your tweeter out and you will have only 2 drivers (woofer and midrange) left. :-(
Why on earth are you trying to build/wire a 3 way speaker and bypass the crossover?
__________________
Scixelsyd Etinu
Old 10th April 2007, 16:36   #120 (permalink)
clipto333's Avatar
hi navin,
im not going to power the speakers without the XO. it was just for knowledge. ill have to do more research on the XO to understand how it works. :-)
cheers
clip.
Thread Tools
Discuss how to build a Car PC.... sys_whiz DIY - Do it yourself 53 19th April 2007 00:09
planning to build an atv or a quad bike !!! gonecase_01 Modifications & Accessories 25 20th January 2007 12:16
Nissan Planning To Build Anti-Drunk Driving Cars. ollie Shifting gears 3 4th October 2006 21:55
Planning to sell Esteem (help needed to fix selling price) Minardi Shifting gears 3 22nd June 2006 22:52
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
