Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
Thread Tools
Old 11th August 2007, 11:21   #91 (permalink)
navin's Avatar
Originally Posted by Sam Kapasi View Post
4 gauge is the minimum what you need for the 75.4.
or you can run 2 gauge from the battery to a distribution block and run to seperate 4 gauge wires from the block to each amp.
__________________
Scixelsyd Etinu
Old 11th August 2007, 12:39   #92 (permalink)
You can wire it like this also...
Crimp the thimble on the wire like this...
the above is a 0 Gauge wire.
and connected them all the three like this....
Here I have connected two wires from the battery to three amps...
Old 11th August 2007, 12:40   #93 (permalink)
Bass&Trouble's Avatar
I do not understand. What do you mean by one 8 gauge and one 4 gauge? One amplifier has 8 gauge and the other 4 gauge? 4 gauge is the minimum what you need for the 75.4. I mean a real 4 gauge not claimed 4 gauge. (What brand are you using?) 8 gauge will simply not do.
The 75.4 is a very serious power consumer. Ordinary wiring will not cut it. You need 2 separate 4 gauge wires (good quality) directly from the battery to the +12V terminal of the amplifiers. Then you need 2 4 gauge wires going from the ground terminal to an unpainted part of your chassis.
Sam, the JBL 75.4 owner's manual specifies peak current requirement of the 75.4 as 85A, and recommends 8 ga amp wiring for lengths up to 10'. The length of power cable in MF's car must be about 13-14 ft. Theoretically, the gauge should be a little higher on account of the higher distance, agreed. But with both pairs of channels running in stereo and driving speakers, will this amp draw the max current? Not even close to 85A, I am sure. The inline fuse is also 60A. I am sure that MF will not be able to blow it irrespective of the operating volume.
The 4 gauge cable is used for the 75.4 intended for the sub. This cable will easily carry far over the rated 85A for the length.
__________________
Losers Commute. We Ride.
Bass&Trouble is online now   Reply With Quote
Old 11th August 2007, 12:47   #94 (permalink)
Razor's setup: Uses 8 gauge cabling for the 75.4, and is using two channels in stereo and the other two in bridged mode.
http://www.team-bhp.com/forum/sound-...tml#post521299 (ICE for Phoenix)
And if I remember right, this kit also uses a 60A inline fuse.
__________________
Old 11th August 2007, 12:59   #95 (permalink)
For a amp which will run on HPF will not need so much power to run it if compared to the same amp with Sub duty on it.
The 8 gauge is equal to 10 mmsq which can carry 100 amps load.
Recommended Power and Ground Cable Sizes
So i think the problem is some place else than the power wire...
And moral which brand power cable you are using ?
Old 11th August 2007, 13:32   #96 (permalink)
nura's Avatar
Will a distribution block help?
__________________
Every man has his follies.
And often they are the most interesting things he has!
nura is online now   Reply With Quote
Old 11th August 2007, 13:36   #97 (permalink)
In which case Nura. If one is on budget then the above method is a cheap option and DIY but if DBlock is available then nothing like it.
Old 11th August 2007, 14:21   #98 (permalink)
moralfibre's Avatar
Here I am. My first advice. Could you please advise me...
Point noted teacher .
Yes you are right. One amplifier is run using a 8 gauge Ichibahn power wire while the other (which is not working) is on a 4 gauge Ground Zero power cable. The Ground cable used for the amplifier is also 4 gauge and about 1.5 feet in length. Now when I use the 4 gauge wire on the amp that is working it works fine (meaning the amplifier driving the speakers is working on both the cables 4ga. as well as 8ga.).
I am using a Ground Zero wiring kit containing a SURE 4 gauge cable. The fact that beats me is that the 75.4 which is working is accepting the 8 gauge cable flawlessly.
So if you connect the subwoofer amplifier to the sub and disconnect the other amplifier, the sub fires up, correct?
No it doesn't. The amp remains in protect. Now there is an interesting behaviour of the LED's first the blue one glows and stays for about a second and then it runs into protect then again comes to blue and then goes off to protect mode again.
If both amplifiers are working individually, then your answer lies right there. It's a wiring issue. Your amps are working fine.
They worked fine at Karim's shop but when he tried to connect it in the car he was surprised that it doesn't work. I am confused big time.
Chalo I agree that it requires 2x4 gauge wires for power and ground then how is it that it works on a 8 gauge cable without issues?
You can take a 16 or 18 gauge wire from the P.connect (blue wire) of your HU and run it to one amplifier remote on and from here you can loop/jump it to the other amplifier, no problem.
I will do this for the remote wire.
Don't take any chances with this wiring, you may blow up the amps if you haven't done so already. You may even damage your speakers.
Even though one amplifier is working I am not taking chances and have disconnected everything and taped it to store it securely till I can make another visit to the installer.
__________________
/F/I/A/T/
Old 11th August 2007, 18:10   #99 (permalink)
clipto333's Avatar
moral, the problem is with amp im sure. please get it checked by a professional. even if the problem is with something else you could still blow your amp and/or oyher equipment. dont take a risk more than 12k are at stake. if an amp goes into protection it means there is a serious problem somewhere. like your earlier magnat amp install.
dont fiddle around please. take it to the A.S.S.
cheers
clip
clipto333 is offline   Reply With Quote
Old 13th August 2007, 16:56   #100 (permalink)
moralfibre's Avatar
Guys, any response to my post # 98?
__________________
/F/I/A/T/
Old 14th August 2007, 10:33   #101 (permalink)
navin's Avatar
Originally Posted by moralfibre View Post
No it doesn't. The amp remains in protect. Now there is an interesting behaviour of the LED's first the blue one glows and stays for about a second and then it runs into protect then again comes to blue and then goes off to protect mode again..
so that we are all on the same page....
you have 2 75.4 amps. both worked when tested at the dealers.
when you connected them to your car one amp (running on 8 GA) worked while the amp running on 4GA did not. Correct so far?
Now the amp that did not work, wont work (stays in protect mode) no matter what power cable is used and whether or not the other (working) amp is connected. Correct so far?
If th above is true then the non-working amp need to be taken to a service center.
If however the non-working amp does work please detail when it does so we can determine why it is tripping.
__________________
Scixelsyd Etinu
Old 14th August 2007, 10:44   #102 (permalink)
moralfibre's Avatar
Correct.
Correct again.
Will do. I shall update you on the progress.
Sure I will check this up before I head the service center way.
__________________
/F/I/A/T/
Old 14th August 2007, 11:24   #103 (permalink)
Sam Kapasi's Avatar
Yup, I was confused with your earlier post. No problem with the gauge of the wires. One amplifier is probably busted.
__________________
“I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart
Old 14th August 2007, 11:30   #104 (permalink)
moralfibre's Avatar
Thank you Sameer . I will get this amp checked soon with Karim.
__________________
/F/I/A/T/
Old 14th August 2007, 11:33   #105 (permalink)
Sam Kapasi's Avatar
Actually moral fibroid, ask him to change it. You just bought it didn't you?
__________________
Thread Tools
DIY SQ install: Gill's Swift ScarySkulls Sound Off and Show Off 306 11th July 2009 16:44
need help and advice - Car Audio install DIY patkim DIY - Do it yourself 8 15th December 2008 20:52
Need a few tools for DIY install adityamunshi DIY - Do it yourself 6 4th October 2008 20:40
My First ICE DIY Install in my swift. rider60 DIY - Do it yourself 17 9th July 2008 02:07
DIY amp install query! dr.abhijeet Ask the Gurus 3 13th September 2007 14:01
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
