| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | After a lot of fight with my elder brother to let me do the ICE of his Hyundai Getz I failed the attempt and he went in for a crap sounding audio system. I decided that day that I will do a install for once in my life to prove that I can do it with help from gurus here. Bought a car on 3rd November 2006 but work kept my schedules tight hence I got a pretty basic but nice audio system from a local installer. He did not do a good job with the install and I was a too sad hearing it. Finally I stripped off the entire system last week and have been doing up the install slowly and steadily myself. It takes time since I do not get to work more than half an hour a day on the car. Work that is currently done: Laying of power cables and speaker wire ONLY! Equipment I already have: Infinity ref 5010cs for the fronts Alpine S-Type 6x9 for the rears which will we replaced with the new Infinity 6x9 from the reference series. Pioneer 7650. To be replaced by an Alpine 9830 but I am in a 100 minds for now. Bought a pair of MDF spacer rings for the front compos from BAASSFX . They are BaassFX UNI 514 and are pretty decent for Rs. 150/- a pair Magnat XCite 300 from hermit audio Bombay. Ichibahn IKit8 8 gauge amplifier wiring kit which retails at Rs. 2,450/- and I got a discount from B&T. Stock Midbass mounted earlier ![]() Tweeter mount that I did earlier on the dash grill. Removed! ![]() This is how it was mounted on the RHS and was held by flexible cable ties: ![]() Crossover for the LHS midbass and tweeter. Not the poor quality cables used without wire crimps: ![]() Another view. The location is under the glove box: ![]() The place where I worked for ages on this setup: ![]() The speaker cables and RCA cables run under this. RHS: ![]() Done with cable laying jobs. Coming from the left are Power cable for the Amplifier and remote turn on cable for the amp: ![]() This is the stuff that is going in the car. Mobil 1 is already lubricating nicely. Also seen are Ichibahn IKIT8 wiring kit for the Magnat XCite 300 2 channel amp. ![]() Ichibahn IKIT8. A very very decent VFM wiring kit ![]() ![]() Magnat XCite 300 amplifier ![]() And lastly my other source of noise: Stebel Fog horn ![]() ![]() Please keep suggestions coming. According to Shrivz, the speaker cable should be mounted in a direction using a convention. The label on the speaker wire should start reading from the amplifier and go up to the speakers in reading direction. I have mounted them ulta. I will lay them again in reverse direction. Thanks Shrivz
__________________ /F/I/A/T/ Last edited by moralfibre : 24th April 2007 at 10:55. |
| | #3 (permalink) |
| Senior - BHPian | No Rishi, not on the stock tray. The Alpines are currently mounted on the stock tray. I have some carpenters working on my house interiors who have voluntarily offered me help to make a tray in MDF. Hopefully a 0.75 inch thick tray should suffice. I forgot to mention that I am trying to souce Infinity Kappa Perfect 10.1 subs in a pair for my car. Once I find them, I will add a GTO 601.1 to the setup (If budget permits of course). But boxes will be made and kept ready. 0.85 cu. ft sealed enclosure for each sub. The carpenters will be done with the work soon and will build me these boxes after I provide exact lengths.
__________________ /F/I/A/T/ Last edited by moralfibre : 24th April 2007 at 11:23. |
| | #4 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| sometime back the doc from ludhiana had a space 10" Infinity. PM him. also try and install your tweeter a bit more discretely. if the dash has speaker pods use them. you might need a small plate to mouth the tweeter. this can be fabricated from MS or wood.
__________________ Scixelsyd Etinu |
| | #5 (permalink) | |
| Senior - BHPian | Quote:
About the tweeters: The dash doesn't have tweeter pods, the rear view mirror pods do have tweeter mounting locations but surprisingly they fire away from the listeners. On top of the dash is difficult because if you see the 3rd picture, the curve above the speedometer causes a hindrance. What is MS? How about half way up the A-Pillar. I met a guy who can help me with fiber glass pods.
__________________ /F/I/A/T/ | |
| | #7 (permalink) | |
make the enlcosure wedge type so that you can stick it to the rear seat so the minimum space is wasted........ | |
| | #11 (permalink) |
| Senior - BHPian | Good going, Moral Nice to see another good DIY effort.The blowers in the dash are a great location for flush-mounting the tweeters. (If you don't use them much. I've never used them). I'd get that fiberglass guy to remove the grilles that are there currently and fabricate something for the tweeters there. As there is already a hollow space there, the fiberglass pod wouldn't stand out much either. (I've never used those blowers). Do you have the flush-mount kit for your tweeters with you still? You can use those kits in that area for best (and almost stock-looking) results. If you want to keep the blowers, fiberglassing a pod in the corner of the dash and the A pillar might be a good idea. If done well, it wouldn't take up much space, and you'll be able to aim the tweeters well. (Having a fiberglass guy on hand is a luxury which I think you must use). Couple of tweeter pods I'd seen recently on the net for inspiration: ![]() ![]()
__________________ Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison |
| | #13 (permalink) |
| BHPian | My knowledge is also newly acquired . I guess there are ICE gurus here to answer your question. All I know is that you lows should be handled by the pair or subs you are getting so you dont need to run the 6x9s fullrange (I might be wrong here)
__________________ Boyz will remain Boyz.......Only their Toyz change |
| | #14 (permalink) |
| Senior - BHPian | Halfway up the A-Pillar would be a little too high IMHO. I think you shouldn't go higher than say 1 or 2 inches above dash-level at the most. Ideal would be at top-of-dash level.
| | #15 (permalink) |
| Senior - BHPian | If one person who does not like tweeter and wants to tone down them the best location for them is this...... ![]() about the box this is the shape I was talking about.... ![]() for .8 cuft the sizes you can use are.....(change the dim mentioned in the above drawing as they are of my box which has a internal volume of approx 1.5 cuft so I have written the corresponding dim in front of the required for your enclosure with the internal volume of .84 cuft in which you can subtract the .04 cuft for the driver displacement resulting in the net volume of .8 for your purpose...) 18 -> 17 15 -> 10 10 -> 8 15.5 -> 14 |
| Thread Tools | |
Similar Threads | ||||
| DIY SQ install: Gill's Swift | ScarySkulls | Sound Off and Show Off | 306 | 11th July 2009 16:44 |
| need help and advice - Car Audio install DIY | patkim | DIY - Do it yourself | 8 | 15th December 2008 20:52 |
| Need a few tools for DIY install | adityamunshi | DIY - Do it yourself | 6 | 4th October 2008 20:40 |
| My First ICE DIY Install in my swift. | rider60 | DIY - Do it yourself | 17 | 9th July 2008 02:07 |
| DIY amp install query! | dr.abhijeet | Ask the Gurus | 3 | 13th September 2007 14:01 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
