Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 29th June 2007, 09:35   #16
archat68's Avatar
Thanked: 290 Times
Thanks guys for the encouragement and positive response.
The plus point is u dont need any calibration and being microcontroller based its very stable and accurate.
BTW any suggestion for the cabinet? the assembled PCB is of the size 3.5X2 inch. presently i'm using a transparent plastic box with black tape taped around it except the display window. it serves the purpose - but looks ugly. any idea about fabricating the case from acrylic sheet.
If sufficiently large members are interested in building the project i may talk to some dealer in my city for preparing the PCB in bulk and also can get the microcontroller programmed in bulk.
______
Arup
__________________________________________________ __________
[FONT=sans-serif][SIZE=2]Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds - Samuel Butler
[/SIZE][/FONT]
archat68 is offline   Reply With Quote
Old 29th June 2007, 12:53   #17
gd1418's Avatar
Thanked: 656 Times
Earning bread n butter from Alchemy and doing physics experiments... Good man, good..
______
Arup
Old 29th June 2007, 13:36   #18
Sudipto-S-Team's Avatar
Thanked: 266 Times
Arup
Congrats. Great project. If you want to know who fabricates acrylic sheets in Kolkata I can tell you.
Sudipto
Sudipto-S-Team is offline   Reply With Quote
Old 29th June 2007, 14:00   #19
madan80's Avatar
Thanked: 73 Times
Hi Arup, looks like a lovely D-I-Y. Anyways, how did you get the code for programming the controller? can you please share those details. I wouldn't mind attempting to build one myself!
madan80 is offline   Reply With Quote
Old 29th June 2007, 14:01   #20
speedmiester's Avatar
Thanked: 931 Times
awesome job due, i think ill get down to building one for myself for my zen.
thanks a lot for the links.
Keep it up
speedmiester is online now   Reply With Quote
Old 29th June 2007, 16:29   #21
Thanked: 294 Times
indian site.
http://www.phoenixmecano.in/
the link might not be working right now but you can the enclousre here.
BOPLA liefert weltweit Kunststoff und Aluminium Gehäusesysteme und Folientastaturen
Old 29th June 2007, 21:43   #22
archat68's Avatar
Thanked: 290 Times
@Sudipto
please post the detail
@madan
please go through the link of electronics-lab provided by me in one of my earlier post. u'll get a rapidshare link which contains all required things.
Old 30th June 2007, 12:21   #23
Thanked: 53 Times
it's easy it program the controller you will find this in most of the web sitess related to PIC microcontrollers. all u need is a computer with serial prot and couple of easy to get components.check this page you'll understand
My PIC Programmer An easy-to-build PIC programmer, based in the JDM. Uses the serial port. (10/24/2004).
dinar is offline   Reply With Quote
Old 30th June 2007, 14:26   #24
IMP
Awesome DIY project, i am actually thinking of how do i go about it myself!!! How does it pickup the engine rpm from the engine? can someone please clarify? Post csme more details and pics please.
Heres a link to a similar project. Tachometer and Digital Dash
IMP is offline   Reply With Quote
Old 30th June 2007, 17:40   #25
Thanked: 53 Times
IMP ,I hope you know how these tach work....
u can use an optical sensor ie: an L.E.D. with an light dependent resistor on the timing pulley or any other pulley which is convenient to fix an led pointing at it as well as the L.D.R. so the the light is reflected onto the L.D.R. by the pulley mark a point on the pulley with white paint or any reflective material, so that the ldr gives a pulsed out put as the reflective material is rotates. the output of the ldr is the signal you are looking for.
or you can use the ignition system to get the pulsed signal it is directly proportional to the prm of the engine.
or you fabricate a dice with a slot oen in it and use the optical sensor mentioned above with led and ldr facing each other, mount this dice on any of the rotating shafts of the engine and when this rotate due to the slot there is a pulsed on off sequence in the lrd getting exposed to light from led . the output is the signal.
I hope I have provided ans to your question. let me know if you need any more info.
Old 30th June 2007, 17:51   #26
archat68's Avatar
Thanked: 290 Times
You get the input from either low voltage input at the ignition coil or from your ECU (it connects where a normal tacho connects in a car).
Here is the link for another forum where it was posted on my request:
Electronics Lab - Community
here u go
_______
Arup
Old 30th June 2007, 19:21   #27
Thanked: 266 Times
Archat
For acrylic sheet fabrication you could either go to Chhatawala Gali (behind Poddar Court) in Central Calcutta where you will find quite a few small shops doing it. Alternatively, there is a gentleman near Deshapriya Park who does it.
If both of these sound too far (I don't know where you stay), ask your neighbourhood aquarium shop. The hoods they sell are done by acrylic sheet fabricators.
Sudipto
Old 1st July 2007, 10:45   #28
archat68's Avatar
Thanked: 290 Times
Thanks Sudipto. I'll give it a try.
OT I stay near tollygaunge. Where do u?
@IMP, the project you've mentioned is nice. one con is it uses PIC18 Microcontrollers which is a bit costly and also programmers are not that easy to build. I've built a JDM based PIC programmer which costed me 300 bucks (excluding the cable) - costliest part of that was the 40 pin ZIF socket which costed me 200 bucks.
here it is:
There are other tacho circuits in the web too. Siliconchip has another one:
Silicon Chip Online - LED Tachometer With Dual Displays, Pt.1
quite nice but the display driver ICs are not available in kolkata and also manufacturer is not providing free samples.
Another one is Josepino tachometer (search for Josepino tachometer in google) - i built this one first - but very unstable in the noisy car environment. So dropped that.
Another one. original page is in german. here is the translated version:
LED tachometer
I didn't try it.
As i had said earlier the toughest part is the PCB fabrication. I had to built the same circuit thrice and had to built 3 sets of PCBs before i finally succeeded. In the first two there was some invisible defects (like short or cut) in the copper track. the 3rd was perfect.
__________
Arup
Old 1st July 2007, 18:47   #29
IMP
@Arup: The project i mentioned uses the PICAXE 18 microcontroller, these mc's are easily programmed directly via a serial cable, one just needs to connect 3 pins of the mc to the correct serial port pins. No need of programmers. But availability of picaxe in India may be a problem.
BTW which microcontroller did you use? is it a PIC16?
Great job on the Programmer there, which PIC's are compatible with it?
Regarding your tacho showing half of the actual rpm, i think, you can easily change that by just minor changes in the programming.
I must add that because of your project, i got interested, and found out a lot of info about microcontrollers and electronics over the net. I was a complete noob two days back, but today i know enough to start my own little "hello world" project using a microcontroller.
Cheers,
IMP.
Old 1st July 2007, 19:11   #30
xinome's Avatar
this is too hightech for me, but seriously aweosme D.I.Y.
xinome is offline   Reply With Quote
DIY amps based on Chinese boards? greenhorn In-Car Entertainment 2 19th October 2015 15:56
Is a tachometer required on a CAR ? skamb Technical Stuff 72 6th December 2014 21:57
Sensor based traffic signals (based on induction-loops) in India? vharihar Street Experiences 8 13th February 2014 21:46
DIY: L.E.D Based Battery Monitor and In-console Integrated 5Volt USB Charger ghpk DIY - Do it yourself 8 16th July 2012 02:18
Tachometer Pricing dragger Modifications & Accessories 10 11th February 2005 17:47
