| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hi, i have quite a big length of cat5 networking cable lying with me. wanted to know, can this cable be used as an interconnect(RCA)? im using some crappy Chinese cables and im not at all happy with them. im asking this because i saw an interconnect made of cat5 cable on some website related to DIY(i dont remember which website) i have some RCA plugs(terminals?) lying with me(made by MX and these are the best available in my city) so i thought of using the cat5 cable. the cable i have is made by lucent technologies so i think its decent quality. keep the suggestions coming in guys. One more thing. im going to chandigarh tonight. can anyone let me know a good electronics store from where i can buy capacitors, Heat shrink tubing? ill be really thankful. thanks in advance cheers clip P.S. - If this has been discussed before, please let me know as i couldnt find anything on this. Last edited by clipto333 : 26th July 2007 at 15:12. |
| | #2 (permalink) |
| Senior - BHPian | http://www.team-bhp.com/forum/ask-gu...-speakers.html (What makes a good wire for speakers?) it was discusses before.. and I would not recommend a CAT 5 cable for the same.for more info read the above thread. I would recommend neutrik and supra cable and the whole RCA will be in the price range of 1.5k with 6 meter length |
| | #3 (permalink) |
| BHPian Join Date: Jun 2005 Location: Bangalore
| Clip, Cat 5 network cables are used as speaker cable. I have tried it too. But again it needs to be of good quality. LBM, how much would shorter supra interconnects cost?
__________________ Thank God for DIY audio. |
| | #4 (permalink) | |
| Senior - BHPian | Quote:
The plugs costs 150 each. and one meter wire which is stereo cable costs about 150-175 per meter. | |
| | #5 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Supra and Sommer are cables made in Sweden and Germany respectively. CAT 5 can be used for very short runs. 1-2 meters. It's resistance and skin effect is too high for use beyond that. On a budget (cheaper than Sommer) you can use 100/40 or 100/38 intrumention wire. The cable has 100 strand of 40 or 38 gauge and ofnte has a good insulation (not Teflon but good grade PTFE).
__________________ Scixelsyd Etinu Last edited by navin : 27th July 2007 at 09:56. |
| | #6 (permalink) | |
| BHPian | Quote:
it was just that i had like 50 meters of cat5 lying unused so i thought if i could use it then why not. one problem with a cat5 is that the conductor breaks easily. even a slight twist sometimes break the wire. im ready to spend on good quality wires and im not on a really tight budget ![]() im gonna go to delhi next month so i will buy some wires from there if lbm can help. :-) there is no place in jalandhar to buy good wires and stuff. im looking for separate good quality wires and connector plugs. is there any place in delhi from where i can buy belden cables? navinji can you give a rough idea of the price you paid for belden? and my amplifier conked off last evening and im really sad :-( . right now i dont have enough $$$ to buy a new amp. i think the power transistor blew. even the heat sink above the transistor melted. there was a problem of alt whine and amp tripping earlier so i removed the sub rca cables. i connected it back and there was tonnes of smoke from the amp. i hope its repairable. the rest of the amp board was fine. how can one check what the problem is? if my amp is irrepairable, what be the best lternative? i was thinking of the 75.4 as it has oodles of power and would be perfect for the comps. whats the bridged power output of this amp? also is it 2 ohm stable(bridged) the 944 is. Gunbir bhai, ek achha sa amp gift kar do please( please gift me a good amp) any amp lying spare with you you wanna sell? otherwise please finance me an amp :-) no cheers clip | |
| | #9 (permalink) |
| BHPian | kahaan gaye sab ke sab? here my amp conked off and no one is worried!! no one asked what happened and if its fine. kidding :-) thanks to my repair guy, he repaired it like it was. the power supply transistor conked and you cant imagine, the heat sink above the transistor melted. above as in the upper part where you screw it. now its back and as good as it was. yey ive had a bad experience with my earlier pio 414 amp. a similar thing happened and it could never produce the power it used to. i had to sell it(the 414 was powering a pair of 2150 and 2 pio 304 subs lol and it was quite decent) im sorry but im really happy to have my amp back. cant help the excitement. bolo tararara chak de phatte clip |
| | #10 (permalink) | ||
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| Yeah, for once there was no post in the ICE section the whole day yesterday!!! Quote:
, your post is at 0253!!!
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||
| | #11 (permalink) |
| Senior - BHPian | the 944 does not have any thing between the transistor and the heat sink. just the thermal paste. ![]() ![]() (pic taken from amp guts) now this is a pioneer D510 amp... ![]() It has the insulated one and the direct type both. the No 1 is the direct type and the No 2 needs the insulation. In the case of Clip I think the amp is over driven which caused the faliure. Clip in the above picture which Mosfet blew. Can you mark it and post it. |
| | #13 (permalink) |
| Senior - BHPian | here is the link to all the major Amps in the car audio AmpGuts - Car Amplifier Guts There are currently 1756 amps from 238 different manufacturers and a total of 8237 pictures |
| | #14 (permalink) | |
| BHPian | Quote:
thanks for the link.:-) so what do you have to say about my amp? was it a major fault? i will check out the repair done when i have time and post a pic. i dont have a before pic sorry. what could have gone wrong? cheers clip p.s. - i could have been wrong. maybe they are the diodes. Last edited by clipto333 : 29th July 2007 at 18:07. | |
| Thread Tools | |
Similar Threads | ||||
| A question about cables | adityamunshi | Ask the Gurus | 37 | 23rd January 2008 11:47 |
| Jump start cables in Bangalore? | kumar2007 | Modifications & Accessories | 3 | 9th October 2007 10:02 |
| Are expensive speaker cables better? 1M$ if you can prove that | tsk1979 | Product Discussions | 41 | 8th October 2007 10:22 |
| Efx Cables | shadyrulez | Product Discussions | 18 | 7th October 2007 11:27 |
| Malfunctioning cables, help | honda_dude | Modifications & Accessories | 1 | 12th March 2007 17:09 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
