| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hi, Did anyone try installing CarPC System : iPC Lx as a car PC? Does it make sense to buy a `complete solution' as they claim, or build one from scratch? I know the latter would be much more fun, but given my expertise and time, I'd want to consider an almost ready to go solution. So does iPC-Lx look like a bad idea? Being a software hacker, I want to run Linux on it. Did anyone try installing Linux kernel on it (say a fairly new one, 2.6.+) ? Will it run? I am ok tweaking the kernel, if some drivers need hacking. regards Kousik. |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Depends on the price that you get. Did you enquire about the bundle price? iRide seems to be a dealer, and the whole stuff must be coming from Taiwan. One wouldn't write them off for A.S.S. but since they are only in Mumbai, that would be suspect. The greatest advantage of a 'bundle' would be that you need not run around for the parts such as DC-DC convertor, cables, etc. Unfortunately we don't have an Akihabara or a Den Den Town in India, which would have given us off-the-shelf choices. There are quite a few Via C7 based boxes out there, which are suitable for Carputer apps. It might be prudent to use an older Linux kernel (2.4.x or 2.5.x) instead of 2.6.x, as the latest would not give any distinct advantages over the older ones. Quite likely the drivers etc. would already be available, since the chips used are fairly common, and there would be a mature user community around it. I wouldn't be surprised if there are already some images on Source Forge or in the User Groups for that config - one just needs to ask around. Also, perhaps a 1.8" HDD might work out better from reliability in automotive apps p-o-v - not sure if they allow user access to the innards without voiding warranty.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! Last edited by DerAlte : 18th August 2007 at 10:16. |
| | #3 (permalink) | |||||
| BHPian | Quote:
Thanks, Kousik | |||||
| | #5 (permalink) |
| BHPian | well I guess it will do what you want it to do. It can analyse the data from you ECU in an OBDII compiant car (provided you have necessary cable and software), It can play music , videos etc.... You can use it for Satellite navigation..etc etc etc...
__________________ Boyz will remain Boyz.......Only their Toyz change |
| | #6 (permalink) | |
| BHPian | Quote:
If you have a car PC, the possibilities are endless ... imagine a geek birdwatcher's dream: you see a rare bird, take a photo, put the SD card in your carpc's usb port, edit the image, and finally post it (with precise latitude/longitude from your bluetooth GPS) to a birding group's mailing list (or flicker) using your mobile as a EDGE modem (again over bluetooth) in 5 minutes flat, without leaving your car! Kousik | |
| | #7 (permalink) |
| BHPian | I bought some of the parts from iRide for my car PC setup(http://www.team-bhp.com/forum/diy-do...ing-stage.html (My First Car PC Install - Research and Planning Stage)). The people there are helpful and genuine. |
| | #8 (permalink) |
| Newbie Join Date: Feb 2007 Location: Bangalore
| I too am planning for a Car-PC for my Honda City. The parts list (or rather shopping list) is as follows - PC Case(Quadrant-Fx) Motherboard(Vista 1G3) DDR RAM (1GB DDR2 533Mhz (Kingston)) HDD (120 GB Western Digital) Displays - 1 DIN touchscreen, non-motorized(IRV-700ID) overhead monitor / headrest LCD screens (need to decide). OBD over USB - ELM 327 USB(Multiprotocol) Windows XP Professional If my calculations are correct, the whole thing must cost me around 42k, excluding the overhead/headrest displays. I already have a factory fitted Alpine music system. So as of now, I'll be using its AUX-in for audio. As far as the software part is concerned, I'm developing my own. . Its just started. So it will take some time before it is ready. Herez a pic of the partially done main screen -![]()
__________________ You can be faster... Don't think you are.... Know you are Last edited by vinayind : 24th August 2007 at 00:16. |
| | #9 (permalink) | |||
| BHPian | Quote:
Kousik | |||
| | #10 (permalink) |
| Sure... why not. I decided on Windows XP because, I work with .NET and WPF (that jaazy Windows Vista stuff) as a part of my job. So I'll be able to develop my stuff faster. In the long run, of course, I too will migrate to open source (sooner or later).
__________________ You can be faster... Don't think you are.... Know you are |
| | #11 (permalink) | |
| Quote:
Linux, with significantly lesser overheads (especially with lighter no-frills builds), would run significantly faster. [Kousik: R and RW mounts at different times would be a severe over-kill and likely to be an operational pain. It won't prevent the HDD from crashing on a severe jolt, since the head will float whether you select R or RW mount, as long as the disk is spinning. That's why I wanted 1.8" disks, since the head is much lighter in those drives and far less likely to be influenced by vibrations and bumps. One can always gel-mount the HDD] Speed, per se, doesn't matter if you are not running large apps, but definitely the apparent response on the screen suffers a lot with Windoze overheads. Case in point: Windows-based seat-back entertainment systems in aircraft - Boeing's system from Rockwell-Collins goes "Huh? OK, sure, gimme a minute or two" for user clicks. Will it be possible to put a WiFi connection to iRide's box? Of course there are some USB-based adapters, but they aren't 11g grade. That way I could upload to the unit from my home PC or laptop without having to remove it from the car.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #12 (permalink) | |||
| Quote:
Also, I'm planning to have speech recognition ahd TTS (Text To Speech) features implemented in my CarPC application. .NET 3.0 comes with Speech libraries. They have very good TTS and speech recognition libraries. I've tried them myself, and am very happy it. In Linux, we need to spend time finding and testing speech libraries even before we incorporate them into the final application. These are some of the reasons why I want to try things first on Windows before I move over to Linux. First, I want to master the nitty gritties of creating and using a CarPC. Later I can use that knowledge to create a CarPC application in Linux. Quote:
And Wi-Fi will not work while driving, since there'll be lot of corrupt packets due to doppler effect on the signal. From what I know, automotive companies are working on a technology called WoW (Wireless LAN on Wheels) to support wireless LAN for ICEs. So currently Wi-Fi will be helpful only when the car is stationary.
__________________ You can be faster... Don't think you are.... Know you are | |||
| | #13 (permalink) | |||
| Quote:
Desktop processor? Sure, the Vista 1G3 has C7, not C7M - which is the power-optimizing mobile version. But, the OS has nary a relationship with whether the processor is desktop or mobile, as long as it handles x86 instruction set. Power management, as supported by C7M and Pentium M (P-States, the feature that allows the CPU to dynamically reduce voltage and frequency; no, C7 and Celeron M don't have it) is exploited by the same OS. Otherwise, there would be processor specific Win XX installs!!! Wonder why iRide is not giving MB with C7M! The Mini ITX boards are actually meant for fit-and-forget (but with AC power) applications, not mobile apps. Being able to use P-state as with laptop would be a great help in Car applications (when the engine is off). Quote:
The open-source world has had usable TTS and voice recognition abilities waaayyy before Windows. I have used voice recognition on Linux 8 years back, but I had to recompile it with changes for Win CE 5 years back.But, your approach is quite rational. We'll be waiting to hear of your travails and exploits. Quote:
But, my point was being able to connect to the CarPC from remote, of course with the car stationary, so that I could connect and UPLOAD TO the CarPC, instead of having to DOWNLOAD FROM the CarPC. BTW, WoW is journo-speak, not tech-speak. Journos are confusing short-distance Bluetooth with continuous connection 802.xx or UMTS transport, without realizing the objectives and means are different.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! Last edited by DerAlte : 26th August 2007 at 18:54. | |||
| | #14 (permalink) | |
| Quote:
Added to that, I have Visual Studio 2005 and it only allows me to use .NET Compact Framework for CE platforms. Thats a big drawback for me. If you have some articles and information regarding the use of .NET 2.0/3.0 desktop version, on Windows CE the do let us know. From what I know, Intel, AMD, Via all use x86 instruction set. So naturally Windows will fit with all their processors. But if the processor architecture changes, then the install build will also change. If you see Linux, they give different builds for different processor architectures. But since Windows concentrates only on x86 market, they only have to release only one build of Windows. WoW is already being implemented in certain automotive projects that have a release deadline of 2009 / 2010. And I know this first hand (I have been working in automotive software for the past 4 years).
(sooner or later).
