Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 11th September 2007, 00:12   #1 (permalink)
clipto333's Avatar
Default Tools for a DIYer.
hi guys,
since im a DIYer i know how important a tool kit is. one definitely need some tool to make life a little easy. i have had a few bad experiences because i didnt have proper tools.
safety is the most important reason to use proper tools. if one uses a wrong tool for eg a using flat head screwdriver for a phillips head(+) screw can be dangerous because of the screw driver slipping. you can cut your finger or you can hurt your self in many ways which isn't good. its really painful.
the time taken to do a job can be cut if one uses proper tools and equipment.
here is a list of some toos and equipment which can make life simpler and safer for a DIYer.
for starters, you need to have some safety equipment like :-
good quality latex or other gloves. fiber glass is very tricky to handle because it can cuse rashes and can badly itch.
glasses - this is very important to avoid small particles from getting into the eyes. you can damage your eyes if a solid object comes flying into your eyes.
breathing mask(dont know thw technical name) to work with Fiber glass and some chemicals. the fumes from these chemicals can be deadly.
proper clothing. you need it to cover your body entirely so that no Fiber Glass particles or any other dangerous substance comes in contact with your skin. before working on something, make sure you are not allergic to the things you are working with.
the most important thing is a first aid kit. if any thing goes wrong and you hurt yourself or others you will need it till you can reach a hospital. dont omit this please.
these wer some safety equipment you must have so dont do anything without these.
now the tools
one needs a set of wrench(the one used for tightening a nut or bolt.) to loosen or tighten a bolt. its good to have 5 to 22 size wrenches as these are the most commonly used ones and you one doesnt work with more than size 22 often. baaki it your wish iw you want more sizes.
one needs a combination of different kinds of pliers. and i dont need to explain why it is importance. you dont need too many so 2-3 will be ok.
a combination of small, medium and large screw drivers. you will also need allen bolt opening tools as they are quite common nowdays. allen bolts have a pentagonal shape where you insert the allen keys.
you will be needing a dremel kit. it hs a motor and is just like a drilling machinw. i dont have it but im going to get it soon. you will also need a small drill machine for heavier work. dremel is important because it is light and can fit in your hand easily. drill is a heavy machine
one should have an assortment of drill bits. you should also stock some wall mounting thingys. the ones you insert the screw in a wall.
you might also need a hack saw. a junior one is great as it is small in size and light in weight. i have it and it can cut through quite a few things.
yyou might want a wrench which has a switch to reverse its operation. it is really of great help in situations where there is less space to use a normal wrench.
one should have a soldering iron for minor work if one can solder. a 15 watt iron will do for most of the smaller work. but you will need a high wattage iron if you want to work with thick wires etc. you will need a soldering wire and wax and a desoldering wire along with a stand for the iron.
solderon is a good indian brand with good quality soldering irons. sirion IIRC is also a good brand.
you need a crimping tool to crimp wire terminals etc.
you will need electrical insulating tape.
rest i will update later as i have to go now.
cheers
clip
clipto333 is offline   Reply With Quote
Old 11th September 2007, 09:39   #2 (permalink)
moralfibre's Avatar
Something that could be of use is given by
crutchfield advisor.
__________________
Ask not what your country can do for you, think of a way you can make them do it!
Old 20th September 2007, 12:25   #3 (permalink)
ankur's Avatar
A dremel tool , its a must in any DIYers toolbox. Once you get it, you will wonder how you lived without it.
ankur is offline   Reply With Quote
Old 20th September 2007, 14:13   #4 (permalink)
clipto333's Avatar
yes, i agree. ill be buying some power tools, i think. its good to have proper tools. i have had bad experiences earlier and they were painful.
cheers
clip
Old 7th October 2007, 00:13   #5 (permalink)
Vivekphadnis's Avatar
I don't know how I would have done speaker box building without my impact drill and circular saw. It's just so easy with these two. I am planning to get myself a orbital sander.
__________________
Thank God for DIY audio.
Vivekphadnis is offline   Reply With Quote
Old 7th October 2007, 00:34   #6 (permalink)
esteem_lover's Avatar
Vivek, you are leagues above the common DIYer. I just cannot understand what is an orbital sander ? Does it revolve in orbit while it saws off your speaker boxes ?
__________________
can't you hear me? What, do you have bubble gum in your ears ? like Mr.Bean ?
The Bean effect on my 4 year old
Old 7th October 2007, 02:08   #7 (permalink)
rohan_fonseca's Avatar
Any ideaswho stocks dremels and approximate costs?
rohan_fonseca is offline   Reply With Quote
Old 7th October 2007, 09:05   #8 (permalink)
kutlee's Avatar
Hole saws and wood saws are quite useful in wood work. Hacsaw has very less clearance and is mainly intented for cutting steel and wood work using that might take more time...my observations.
kutlee is offline   Reply With Quote
Old 7th October 2007, 10:43   #9 (permalink)
Team-BHP Moderator
DerAlte's Avatar
As opposed to the belt sander, where the abrasive is on a belt continuously moving in one direction, the Orbital sander moves a sheet (OK, 1/2 of a conventional sandpaper sheet) and moves it around in circles. The movement is 'orbital' with respect to the sander motor housing (can be a small palm-sized one, a larger 2-handed version). Belt is better for coarse work (removing large amount of peaks), orbital for finer work.
Saves a lot of elbow grease when sanding large surfaces. By using progressively finer sandpaper / emery-paper, one can get a smooth uniform surface very fast.
Not recommended for water-based 'cutting' for final coats of lacquer or paint, though - tends to leave circular marks.
@vivek - where do you buy your tools from?
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 7th October 2007, 11:55   #10 (permalink)
Sam Kapasi's Avatar
Clip is right, but I want to elaborate.
The brand that you cannot go wrong with is SOLDRON - inexpensive and bits are easily available. Beware of cheap imitations.
The industry standard and my own recommendation is a 25W Soldron iron.
Solder Wire: Again, the wrong choice here will make a mess of everything. In India I prefer JOINT brand only. I would not dream of experimenting.
You get various gauges, for the best, clean work i prefer 22 gauge flux cored Joint brand solder wire. It has a typical white and green packing.
You also get 18 gauge, but that causes too much solder to be present on the joint.
Remember to scrub. clean or tin the copper surface. Never attempt to solder a wire without scraping it slightly with a blade or sandpaper - it makes a clean and better joint.
Not Wax, the word is FLUX: While soldering you may not need any. The joint solder wire is flux cored, so if your joint is clean, you wont need extra flux. But flux causes the solder to join faster at a lower temperature.
And finally - you will not need De-soldering wicks for regular wire based soldering, unless you plan to do desolder some PCB soldering. Like removing a transistor or something.
In this case I would recommend a brand called DESOLWIK - but you will need to warm it (By placing an iron on it) and soak it in flux first, before desoldering.
Enjoy and do not hesitate to ask any question here before attempting your first soldering job.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 8th October 2007, 22:49   #11 (permalink)
DerAlte, the drill and circular saw are of Electrex make. I bought them from a small shop in Guttahalli. But I have a Hitachi disc grinder which I bought from SJP Road. That is the best place to get power tools.
Hi Sam, the subwoofer boxes are almost finished. I am in the process of building two 200W amplifier modules for the drivers.
__________________
Old 8th October 2007, 23:17   #12 (permalink)
Bass&Trouble's Avatar
I think MF picked up a sheet listing out the common tools required for car audio installation last time he was in Bombay. Maybe you can put that here, the farsee, tocha, hathodee, iskrew-drive one.
__________________
Operator! Give me the number for 911!
Old 9th October 2007, 10:56   #13 (permalink)
S@~+#0$#'s Avatar
As much as I can, I try and do things myself. To be able to do this, I have a small collection of tools that varies from spanners, rachets, duct-tapes files to soldering-irons, drill-guns and blowers but have found it difficult carrying them when required. I am currently using an old military explosives box that I picked from the Chor Bazaar. But I need something more organised and lightweight. Any ideas on a good brand that makes toolboxes? Something like this would be great Craftsman Tool Case, Black - Model 59378 at Sears.com
IMO, another must-have is a Victorinox Multi-functional knife. It is very handy and has bailed me out of many a difficult situation.
__________________
Santhosh
U'll never lead in someone else's tracks. Cut your own!
S@~+#0$# is offline   Reply With Quote
Old 12th October 2007, 01:42   #14 (permalink)
clipto333's Avatar
thanks sam :-) yes it is SOLDRON. and its flux. sorry for that. i can imagine someone asking for wax and making a fool out of himself. and desoldering wick ofcourse. thanks again.
sam, isnt 15 watts more than enough? a 25 watt ca damage thing if used for too long. but for wires and stuff, the 25w iron will be fine.
and i have bought some power tools. sorry for posting it in three different threads but it belongs here. gota black & decker cordless drill, a jigsaw machine, a crew driver kit(to be used with the drill) a wood planer and some drill bits and jigsaw blades. these power tools have made my life a lot easier. i could remove my sub from the enclosure in 1 minute flat. :-)
cheers
clip
Old 12th October 2007, 10:14   #15 (permalink)
Team-BHP Moderator
navin's Avatar
you do get solder wire with a flux core, at best you now need flux to clean the tips. Soldoron makes nice irons and interchangable tips too. They've been in the business as long as I can remember. :-)
__________________
Scixelsyd Etinu
Thread Tools
Power tools dadu Gadgets, Computers & Software 15 16th June 2008 12:05
Fantastic store for tools kartikkumar Shifting gears 11 13th December 2007 19:37
tools for bike garage bullboy Motorbikes 1 11th September 2006 12:50
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
