| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #31 (permalink) | |
| BHPian Join Date: Aug 2007 Location: Chandigarh
| Quote:
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. Last edited by Gill : 7th October 2007 at 16:16. | |
| | #32 (permalink) |
| BHPian Join Date: Apr 2006 Location: Bangalore
| 1st the enclosure needs to be airtight if its an sealed enclosure. before u check for airleaks check the dimension as per the specification of the sub. Yes using screws are better as they dont loosen when the sub is playing. forget to check airleaks, put it on and test if the bass is tight else check for dimension or build an other enclosure with proper care.
__________________ Venu We Make Driving A Pleasure |
| | #33 (permalink) |
| performance of the sub calls for a good amplifier and a good enclosure - selection of enclosures largely depends upon the vehicle and the amplifier. a good and a knowledgeable installer will be of a great help to decide the sub, enclosure and amplifier. Remember the more u spend the better you get.
| | #34 (permalink) | ||
| BHPian Join Date: Mar 2004 Location: Ludhiana
| Quote:
I think time is ripe for building another one.
__________________ Punjabi for Life. | ||
| | #36 (permalink) |
| Problem faced is that Sub bottoms out very easily even at moderate settings. Read up on internet and found that a leaky box can do that. A friend also told be his incident when a leaky box was causing his IDQ's to bottom out easily. Box changed and everything back to normal. Why, Even our SPL Guru LBM's subs will bottom out if he tries to cover ports with hands. Which shouldnt happen because in a sealed enclosure, the Sub will effectively handle more power than a ported one. But a hand cannot achieve a good seal. Hence leak. And Hence Bottoming out. What's your take Navin Ji?
| | #37 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
ask LBM to try this. stuff about 0.5lb of polyfill or even opencell foam in the port (make sure it can be removed) and see if this sub stil bottoms out. what you guys are doing is tuning the box to a very low freq and the sub acoustically decouples when driven at that freq. and bottoms out. if your HU had a Subsonic filter you could engage that and the sub would not bottom out as easily.
__________________ Scixelsyd Etinu | |
| | #38 (permalink) | |
| Senior - BHPian | Quote:
As we are talk here a new enclousre of 15 x 15 x 12.5 inch is being made. The internal volume comes to 1.16 cuft. And after removing the woofer displacement volume which is 0.12 cuft the final volume is 1.04 cuft. The enclosure volume is taken 1 cuft because more power handling is required as 1200 watts rms is going in to the sub. I will try to run the sub with 1200 and 335 watts from the Steg and 700 watts rms with the alpine mrd-1005. So that I will get a fair idea how the sub handle different wattages... Will be posting some details about the test tomorrow.
__________________ Looks Can Be Deceiving | |
| | #39 (permalink) | ||
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
* @scaryskulls has not described the symptoms that make him infer that the sub is bottoming out, since he couldn't have actually measured the travel, nor has he described he circumstances under which it happens * That there is a leak is a conjecture * That the circumstances of whoever said "bottoming=leak" are comparable to this situation is also conjecture * It is possible for the sub to bottom out in a perfectly sealed box. After all, the air behind the sub is not solid, incompressible medium that will prevent the cone from traveling any further. It will at most only try to slow it down * The bottoming out can be caused by - the nature of the signal (independent of box) - faster the acceleration of the cone, more the chances that it will bottom out - the amp is 'too good' or 'too bad' for the sub: too large output di/dt (no reflection on the ID sub) or too much peak clipping/ringing * The leak, if at all, is more likely to be between the sub frame and the box, if the gasket is not seated well * If the box is much larger than idea Vb, it could possibly lead to bottoming out under some circumstances * Comparing sealed box behavior with ported/BR box behavior (with port closed by hand) is not correct - the internal volumes and dynamics are different
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||
| | #40 (permalink) | |||||||
| Quote:
That is true. Quote:
__________________ Punjabi for Life. | |||||||
| | #41 (permalink) | |||||
| Quote:
It is a conjecture since it is not established that bottoming out, if so in your case, is due to a leak Quote:
Try playing "Jaane kyun log pyaar karte hain" from that Aamir Khan movie - it has a synthetic bass accompaniment which slides really really low on every note. You can figure out at what point (even at low volume) the cone really starts to reach limits of excursion. Quote:
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |||||
| | #42 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
Bally Sagoo's version of Chura Liya Karunesh - Punjab Nitin Sawhney - Nadiya ![]()
__________________ Operator! Give me the number for 911! | |
| | #45 (permalink) |
| If the general notion that "Speaker fat rahe hain yaar"....Or crossing excursion limits means bottoming out, then that's perfectly it. Good idea on the Talcum powder. Thanks. Lets see what happens. Give it a shot Gill.
« Merged threads: Pioneer CD-RB10 IP Bus Cable and how to install or splice it.
iRide's iPC-Lx as car PC »
| Thread Tools | |
Similar Threads | ||||
| Best direction to face box subwoofer in boot of car ? | DRAGONLORD | Ask the Gurus | 4 | 28th December 2007 01:31 |
| Subwoofer for OHC - suggestions pls. | gbpscars | Ask the Gurus | 1 | 3rd October 2007 11:16 |
| MODIFIED suggestions for 4 ch. amp & subwoofer | ggoyal_83 | Ask the Gurus | 114 | 15th December 2006 19:07 |
| New AC making noise | Real_man | Technical Stuff | 2 | 22nd March 2006 04:06 |
| Need help in making my subwoofer box | libre sito | DIY - Do it yourself | 6 | 27th August 2004 23:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
