Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 6th November 2007, 12:59   #16 (permalink)
Cool Deterrminus - Guess you mistook!
Originally Posted by determinus View Post
Perhaps not. Most of these aux-in/ usb in devices have a capacity limit from which it can read. Most of the DVD players with USB fails to read anything above 8GB, and with externally powered drives, upto 40GB. Of course there are work arounds, like format the drive in FAT32 and theoretically it can go to any size, but about 4 levels of hierarchy and 500 folders is where it hangs when I tried with a 300GB drive. But I havent tried any such thing on any car audio HU's though. At the same time, there are head units that can drive iPods via dedicated iPod ports, but if you hook an iPod into a USB port, it is treated as any hard drive and the above mentioned limit applies.
Again on paper, the 6x9 coaxials are full range speakers and should suffice. But how would the setup sound, and more important if you would like it is another story. To know about the chances of just a pair of 6x9's sounding good in a setup, search this thread itself.
I never wanted a HU to read form my iPod or USB drive.
I will not buy a HU, instead I will connect my iPod to a AMP to a pair of Speakers for Rear Door only. Cost is like 7000/- and I'm done. Play with my iPod, playlists and all. I dont think any under 10,000/- HU can manage playlists, and most liked songs, rating a track, search by genre, album, artist - not much flexibility in a HU.
So i plan to drop the HU and only buy an AMP + Speakers for read door.
All I want to know form the GURUS is, if this is done, will the iPod be enuf to deliver to the AMP.? in terms of jargons like Ohms/Watts/RMS or anything you guys call ém.
May be I should draw a small flow diagram!
danny is offline   Reply With Quote
Old 6th November 2007, 13:11   #17 (permalink)
hey guys thanks for the great replies. i guess getting that sony front load usb Hu in greay for 5.5k is just the best fit. I have made a MP3 player form old compu parts way back when the HU never knew what MP3 file format was! But that is a lotta work, like making an inverter, writing shell scripts, loading linux OS with ripped off code, and compiling, and installing s/w like winamp in the HDD and buying a Num-pad keyboard for controlling the player and shutting down and booting etc.. well those were days when I found it too easy and had enuf time after college!
hey between, I wanted to ICE a Estilo that I booked last week. Your help would be useful to me.
Danny
Last edited by aah78 : 7th November 2007 at 20:14. Reason: Relevant link deleted. Thread merged.
Old 6th November 2007, 13:14   #18 (permalink)
I have pasted the latest post from my thread here:
I have a iPod with huge memory. I wanted to know if the following setup will work?
1. iPod >> to >>
2. Blau Amp GTA 2 Spl Mk-II (2x120 W/1 x 400W) >> to >>
3. Blau GTx 693 6x9" Triaxial (240W)
I will forego the Hu as of Now, the iPod receives FM + tons of Music.
Means I wont install a head Unit.
I will get the iPod connected to the Triaxial via the Amp!
I want to know if this would work. Will the output be good enough to get a good balance in Low and High pass. Will I need a front Speaker? or component? What speaker size is apt? how about JBL? If you guys suggest JBL - what models? Please gimme some idea!
luv,
Danny
Old 6th November 2007, 14:47   #19 (permalink)
rocksterraghu's Avatar
I am no guru, but in simple words - yes, it is enough. It is just pre-amp and does not involve impedance or other jargons.
I think most of us here get what you're saying - so no need to take trouble in drawing one.
__________________
Everything should be made as simple as possible, but not simpler
Old 6th November 2007, 16:05   #20 (permalink)
vebmetal's Avatar
Danny, use the Search feature in future. This exact topic has been discussed extensively in a thread started by me here (Crazy Idea - Direct connection to Amp (no HU) - Will it work?!?).
I myself am figuring out what to get for this exact kind of setup (no HU, amp, front speakers only), so looks like one of us might have to become the other's guinea pig. A pity we are not in the same city.
vebmetal is offline   Reply With Quote
Old 6th November 2007, 20:22   #21 (permalink)
Team-BHP Moderator
navin's Avatar
1. iPod
luv,
Danny
1. how do intend to turn on the amp, most use the remote output of the HU
2. the headphone out of the ipod will not drive the amp sufficiently well
3. if you intend to use the line out you will need some adapater that plugs into the ipod's line out and give your RCA or EP out
4. what do you intend to do for volume control if you use the line out (and not headphone out).
__________________
Scixelsyd Etinu
Old 6th November 2007, 22:07   #22 (permalink)
Thumbs up thanks
thanks Raghu, Navin and my sweet guniea pig! (no offence)
What is the loss when driven from the headphone output. I spoke to a Stereo technician and he too told me soemthing similar. He said it would work cool though, he has promised me to make a demo and show.,
He added the AMP can be switched on with a small switch, and eveything else is fine!
Old 7th November 2007, 08:11   #23 (permalink)
revtech's Avatar
what exactly do u plan on doing why not get a head unit with an aux port so u can connect ur ipd to it
if u connect your ipod to ur amp your only gonna hear it from the set of speakers your amp is connected to and being a 2 chan amp tht means only 2 speakers. later on wen u get 2 more speakers ur not gonna hear anything so..instead of haveing jus rear speakers and connecting ur ipod to ur amp id suggest u get a good set of component speakers. and a decent hed unit with an aux port and the blau amp and ur good to go for now.
__________________
Revin Beyond Limits !!
revtech is offline   Reply With Quote
Old 7th November 2007, 12:11   #24 (permalink)
Sam Kapasi's Avatar
When connecting an Ipod to a USB inout, be warned. It may not work.
An iPod does not use the simple FAT32 or FAT16 format present on USB memory devices. A device that can read the information off an iPod from a USB has to have a special software to be able to do that.
To successfully read an iPod, you will probably need an iPod specific data cable.
Simple using the cable that you use to update your iPod, plugged into the USB of your car stereo may not give you what you want.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 7th November 2007, 12:15   #25 (permalink)
vebmetal's Avatar
Danny, as I have told you in another thread, this topic of having an ICE system without a HU has been extensively discussed in this thread (Crazy Idea - Direct connection to Amp (no HU) - Will it work?!?). In addition, it's a bit irritating that you are posting the same question in multiple threads.
So as far the possibility of such a system goes, stick to that thread. Your question has already been answered (i.e. in short, yes, it's possible). As far as your other questions go, please continue.
btw I was under the impression that iPods (i.e. Apple iPods, not the generic term) didn't have FM.
Old 7th November 2007, 12:15   #26 (permalink)
hydrashok's Avatar
The Blau GTA480 (4-ch) and the GTA280 (2-ch) Amps have an aux-in (3.5mm socket) that is meant to be used as input from MP3 players.
(I'm not sure, but I think the earlier GTA 475/275 amps also had this).
__________________
Seven are my colours
Many are my lovers
What was three will soon be two
The music will again sound pure and
true
Old 7th November 2007, 12:17   #27 (permalink)
Sam Kapasi's Avatar
There is no generic term baba. There is only one iPod and it is an Apple product and an Apple trademark.
And you are correct, iPods do not have FM.
__________________
Live the YetiLife®
Old 7th November 2007, 12:20   #28 (permalink)
mobike008's Avatar
I own a 30GB model, and they don't have a speakerphone just incase we are lazy to put on the headphone. I wonder why they didnt install this feature
Other than FM and Speakerphone, it is a perfect product
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 7th November 2007, 12:24   #29 (permalink)
Sam Kapasi's Avatar
*Imagining myself holding an iPod to my ear like a villager listening to the cricket score.*
No I'm glad they didn't put a speaker phone on that lol.
__________________
Live the YetiLife®
Old 7th November 2007, 12:38   #30 (permalink)
vebmetal's Avatar
^ditto. I hate people who blast (and I use that term loosely) ****ty music on their cell phones in public places. I wish I could have some excuse, like medical insanity, to go around breaking their phones.
And I know that iPod is a very specific and trademarked term. Most people don't and refer to any manner of DAP as an 'iPod' and that's what I was wondering was meant by Danny or not.
Thread Tools
Used Zen Estilo for 3.6L pradeepbhambi Hatchbacks 30 24th July 2008 12:14
Basic ICE for Zen Estilo - Rs. 10,000 vebmetal Ask the Gurus 51 17th November 2007 16:33
Icing Zen Estilo bmdesai1987 Ask the Gurus 25 7th November 2007 12:14
Driven: Zen Estilo drifter Test-Drives & Initial Ownership Reports 27 30th January 2007 14:46
New Zen Estilo Launched GeekSrik The Indian Car Scene!! 230 27th December 2006 08:16
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
