Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 28th November 2007, 13:35   #16
Thanked: 11 Times
Congrates Lbm.. It looks awesome.
Where did you fit the strobes ?
Mugen_Power is offline   Reply With Quote
Old 28th November 2007, 13:38   #17
Thanked: 294 Times
Originally Posted by hellspawn View Post
the projector setup looks good.so do these projector setups come with hid's or do you have to buy them seperately or did you install the previous hid's that you had installed.
The HID does not comes with the setup one has to buy them extra. Earler I had H4 bulbs so they cannot fit in the new setup which uses H1 bulbs. So I had to bought new one for the same.
Old 28th November 2007, 13:38   #18
Thanked: 294 Times
In one of the three Led slots.
Old 28th November 2007, 13:55   #19
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by low_bass_makker View Post
In something of 13k range.
where would the decimal come> before 13, between 1 and 3 or after 13
Nice job LBM
Did you confirm with anyone about how it should have been in real world, ie, like your first post or last one?
Old 28th November 2007, 15:50   #20
m4ugr8's Avatar
Thanked: 123 Times
LBM congrats,and i am coming to you for the things you corrected,even i am facing the same prob.The hid's are oriented towards the left.I am also not liking that....i also want \____/.Also what wiring kit did you use? Even i want the projectors to glow when i turn the high beam on??
BTW those new h1 hid is also philips?? its looking great!!!
Last edited by m4ugr8 : 28th November 2007 at 16:03. Reason: missed on a dew things
m4ugr8 is offline   Reply With Quote
Old 29th November 2007, 12:41   #21
Thanked: 294 Times
Sure welcome...that can be done no issues..
No it is not philips they are the general Taiwan brands.
Old 30th November 2007, 14:41   #22
ram_hyundai's Avatar
Thanked: 48 Times
hey lbm,maybe out of topic.which alloys in the car.looks great.i am in search of one.model and price ,can you pm me.
ram
ram_hyundai is offline   Reply With Quote
Old 23rd April 2008, 16:29   #23
sameer_dg's Avatar
LBM, Let me know can only the projectors fitted in to the Fog lamp area for the Swift VDI. The setup am looking at is stock headlamps with 100W bulbs + projectors in the fog lamps area still maintaining the stock look from outside except for the lens.
sameer_dg is offline   Reply With Quote
Old 23rd April 2008, 21:46   #24
Thanked: 53 Times
Hey low_bass_maker, nice lights great DIY job, the beams are really good after the job..... just wondering do you get only the projectors seperatly [ as they are mounted with screws]
dinar is offline   Reply With Quote
Old 23rd April 2008, 22:13   #25
yayaati's Avatar
well yes you can do that but it would be a totally DIY stuff , but firstly you have to get the projectors.
give me ideas BHPans
How are you creating the base ?? to attach the projectors
yayaati is offline   Reply With Quote
Old 14th May 2008, 00:38   #26
Thanked: 13 Times
LBM, could you please highlight the what needs to be done so that when the high beam is turned on the low (projector) also remains on?
Old 14th May 2008, 11:04   #27
Thanked: 294 Times
You need two wiring kits for this.
One to wire the projectors which can be done by the xenon wiring kit which has high/low option. which will keep the projector on on both high and low.
And for the high beam the normal headlight wiring kit will do.
Old 30th November 2009, 17:54   #28
kingofmyworld's Avatar
Thanked: 249 Times
Nice, Neatly done, But how did you manage to open the headlamp? Aren't those sealed with some kind of a sealant?
kingofmyworld is offline   Reply With Quote
Old 30th November 2009, 18:15   #29
furioussphinx's Avatar
Dug up an old thread from the grave eh?
All you need is a heat gun to heat and slowly and carefully pry open the cover. And once you are done, you can seal it back using the epoxy resin sealant.
furioussphinx is offline   Reply With Quote
Old 30th November 2009, 18:20   #30
NOTORIOUS's Avatar
Thanked: 89 Times
Awesome Setup LBM JI .
NOTORIOUS is offline   Reply With Quote
Projector headlamp setup for my SX4 prince85 Modifications & Accessories 10 3rd January 2014 20:28
Projector setup for Fiesta, that's already has HID? fiesta_21 Modifications & Accessories 17 3rd December 2011 11:47
Projector setup on my Honda city noidaboy Modifications & Accessories 114 26th June 2011 22:05
Projector setup for Esteem type-III viky_s Modifications & Accessories 12 3rd August 2009 12:06
DIY Swift Audio Setup.with the help of some friends. navpreet318 In-Car Entertainment 76 13th January 2008 16:38
