Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 6th December 2007, 07:05   #16 (permalink)
condor's Avatar
theMAG : The foremost characteristic would be no sound deadening happening.
I meant - anything on the inside ? Like side-effects of disintegration, possibly damaging the sheet from inside etc. No sound deadening would be a gradual effect.
The idea is - if the life of such material is say, 5 yrs, then it may be worth going in for it. Either I wont have the vehicle after that time, or I can get it re-done. Is it safe to go for such stuff, and re-do it periodically.
__________________
Life is Analog. Digital is an approximation.
Old 6th December 2007, 13:27   #17 (permalink)
adityamunshi's Avatar
Is it possible to get unbranded butyl rubber sheets and stick them ourselves with adhesive ? Or are branded ones like dynamat the only option ?
open cell foam will absorb moisture. even closed cell foam deteriorates over time. it is best to use material like butyl rubber which last longer inindian's hot/humid climate.
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is offline   Reply With Quote
Old 6th December 2007, 14:13   #18 (permalink)
Team-BHP Moderator
Technocrat's Avatar
Check out the Link Posted by Jeep.
You can start from this post as well, look at post#187 by Shrivz
. (The Damping Material and Sound Deadener Thread)
__________________
180, 225, 150, ??? -> 159?
Old 6th December 2007, 15:46   #19 (permalink)
spadival's Avatar
Originally Posted by ram View Post
You coat the inside with 1 cm thick, open-cell dense polyurethane foam weighing at least 4.5 to 5 kg per square metre. Paste it on the rear shelf, dikky insides, roof, flooring, inner wheel-arches, firewall... You get a special adhesive that will bond this material to sheet metal and plastic.
There is an anti-vibration polymer putty/paste called "Spectrum Sludge" by a company called Second-Skin. You need to brush on a 1 mm to 4 mm thick coat on dikky floor, sparewheel-well, front and rear quarter panel walls, metal inner-surfaces of doors, and dikky lid. It prevents vibration, noise and even rust.
Can you really get all this done here in India? If so, what are the costs involved... I have used a simple solution so far, turn up the ICE volume to drown out all the noise. I would be interested in the solution u have outlined, but I am skeptical whether it can be done here.
spadival is offline   Reply With Quote
Old 6th December 2007, 16:18   #20 (permalink)
arunkumar_rec's Avatar
I had this parcel tray rattling noise in my new GETZ 1.3 GLS for 10 months from my purchase date. Complained so many times to the service folks. But no fix at all. Useless people. Even just 2 days back they said the problem may be from the Tailgate release hydraulic assy and offered to replace it. But i told them it is the parcel tray and not the tailgate stuff. They didnt listen.
Finally you know what ?? I have fixed it with just Rs.3/-
Secret is my son's Nataraja pencil Eraser. I just cut the eraser longitudinally into 2 halves and inserted on both sides of my parcel tray in between the parcel tray and the adjacent platic piece on which the parcel tray is resting. I made it a press fit so that the parcel tray's movement is totally restricted(ensure this. else u wont get the expected result). The relative motion of the parcel tray with the plastic piece is now eliminated with the eraser doing the trick. Now the cabin is noiseless, no rattles. Absolute bliss.... Only drawback is the parcel tray can't be lifted now. But I need the parcel tray removed only for my long trips which i go once in say 6 months.
Try it. If there is any problem, PM me...
Arun
arunkumar_rec is offline   Reply With Quote
Old 6th December 2007, 22:33   #21 (permalink)
Team-BHP Moderator
navin's Avatar
Navin, would you have any info on the life of the foam - how long would it last, and it's characteristics when it starts to disintegrate beyond usefulness ?
open cell foam deteriorates a bit faster even UV grade Open cell foam lasts only about 4-5 years before it needs to be replaced.
Closed cell foam can last longer but with butyl rubber around why bother with foam?
Ram, thank you for the info on Neil Soft and FEA (I was aware of both as I work with FEA) as well as the info on the NHC vs Octavia. In my case I was comparing both cars after damping so maybe your info is right.
__________________
Scixelsyd Etinu
Old 7th December 2007, 00:32   #22 (permalink)
rohan_fonseca's Avatar
What would be the adhesive of choice for butyl rubber (especially when attaching to door panels) considering its weight when compared to foam?
rohan_fonseca is offline   Reply With Quote
Old 7th December 2007, 09:18   #23 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Usually those sheets are pre-coated with adhesive.
If not, good old rubber-solution would be the best - provided both the surfaces are clean. RS stays flexible despite aging, unlike (Araldite) and cyano-acrylate. Other adhesives would fail / be too costly in this application.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
DerAlte is online now   Reply With Quote
Old 7th December 2007, 13:05   #24 (permalink)
I was at a hardware shop yesterday to buy araldite and i saw cans of Fevicol - synthetic rubber adhesive. The instructions on the can said it was meant for sticking sheets of foam/rubber etc.
__________________
Old 7th December 2007, 14:47   #25 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Yes, all rubber-solutions are Synthetic Rubber Adhesives. Rubber-solution is only a colloquial term.
__________________
Old 7th December 2007, 19:15   #26 (permalink)
Are we talking about fevicol sr?
Old 7th December 2007, 20:00   #27 (permalink)
Not the usual fevicol but a rubber adhesive sold under the fevicol brand name.
__________________
Thread Tools
Car/SUV with low cabin noise msdivy SUVs, MUVs & 4x4s 32 3rd May 2008 11:58
So why all the noise making by the Car Manufacturers abt ICE ?? blueraven316 Product Discussions 15 22nd January 2008 12:49
Noise in the car prakashc Technical Stuff 3 1st February 2007 13:59
Need some input on reducing rattling noise in the rear due to the oval speakers partypest Ask the Gurus 4 5th January 2007 06:49
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
