Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 29th November 2007, 15:56   #1 (permalink)
Thumbs up Reducing in car noise
Folks
Is there any way I can reduce the ambient noise that filters through into the cabin of my Swift ? I just love tomb like interiors especially while cruising on the highway - goes a long way in reducing stress and enjoying the music.
Any DIY options that are inexpensive ?
varadha_r is offline   Reply With Quote
Old 29th November 2007, 19:45   #2 (permalink)
Try to damp using some good stuff and thats the only way to get rid of noise. Try materials like dynamat extreme, fonomat, wurth etc.
swathyd is offline   Reply With Quote
Old 29th November 2007, 21:53   #3 (permalink)
Team-BHP Moderator
navin's Avatar
damping will reduce quite a bit. to much is not good as you can tell engine noise nor get a sense of the traffic around you.
__________________
Scixelsyd Etinu
Old 30th November 2007, 12:30   #4 (permalink)
Check this link
http://www.team-bhp.com/forum/produc...tml#post635683 (The Damping Material and Sound Deadener Thread)
Jeep is offline   Reply With Quote
Old 4th December 2007, 22:04   #5 (permalink)
MillionSwords's Avatar
I thought we are discussing about DIYourself methods here.
Anyone tell can we dampen using some locally procurable material.
i guess some sponge? will do the job? Rubberised sponge? that kinda material that we use in sofa cusion etc?
WHY only use a dampening material to do the job - any specific reason?
What is the original dampening material made off? why it is used?
__________________
Cheers,
MillionSwords
[Zen Estilo, 2007] IllusionICEd n Rocking!!!
[Yamaha 5 Speed RX-135, 2000]
MillionSwords is offline   Reply With Quote
Old 4th December 2007, 22:42   #6 (permalink)
CrAzY dRiVeR's Avatar
Guys, i had used some extra carpetting for the floor of the WagonR for rainy season. After removing it, i am finding that the carpetting did help in removing road noises filtering into the cabin. The noise seems to be on the higher side now.
I dont want the carpetting inside the car, as it hurts the interior looks pretty well. Also, dont have the budget for a proper damping job. Any DIY job to insulate the cabin from underbody and suspension noises over bad roads?
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 4th December 2007, 23:48   #7 (permalink)
Sankar's Avatar
varadha_r, Swift has a bad case of cabin rattle issues. Pm theMag, he recently got done a vibration damping job in his Swift. It's a lot better in his Swift now.
Dynamat & Wurth are the expensive options. You might get satisfied with a cheaper alternative as well.
__________________
"Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games."
Ernest Hemingway
Sankar is online now   Reply With Quote
Old 4th December 2007, 23:57   #8 (permalink)
mobike008's Avatar
Damping is the only way out. Its your choice if you want branded stuff or procure materials and DIY
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 5th December 2007, 07:23   #9 (permalink)
Ram
Ram's Avatar
Default What makes for a quiet car?
Careful handling and top maintenance
Properly run-in/broken-in engines are quieter than those that have been over-revved and abused when new. Bad driving habits -- upshifting gears before reaching the peak torque zone (ostensibly to maximize economy), leads to dramatically increased rattles and vibrations. These vibrations over time, play havoc with your engine and its mounts.
Regular timely maintenance is all-important: air-filter changes, oil and filter changes, gear and differential oil changes... (IMHO, it doesn't hurt to do it ten percent more often, than less often, compared to what the manual recommends -- they don't know how hard you drive your car, over what terrain and in what dusty conditions).
How do you quieten your existing noisy car?
You fix all existing mechanical problems -- slipping belts, dirty injectors, ... .
You coat the inside with 1 cm thick, open-cell dense polyurethane foam weighing at least 4.5 to 5 kg per square metre. Paste it on the rear shelf, dikky insides, roof, flooring, inner wheel-arches, firewall... You get a special adhesive that will bond this material to sheet metal and plastic.
Any plain sponge will not do! You must use anti-rattle padding. This is a semi closed cell acoustic foam designed to absorb the rattles between your car's plastic trim and metal panels.
There is an anti-vibration polymer putty/paste called "Spectrum Sludge" by a company called Second-Skin. You need to brush on a 1 mm to 4 mm thick coat on dikky floor, sparewheel-well, front and rear quarter panel walls, metal inner-surfaces of doors, and dikky lid. It prevents vibration, noise and even rust.
Use gas-charged shock absorbers.
Then there are better cars...
The heavy European cars (Mercedes, Volvo, Saab, Audi, Volkswagen, Jaguar, Lancia) cars and American cars (Cadillac/Buick/Pontiac/Chevrolet, Lincoln/Mercury/Ford, Chrysler/Dodge/Plymouth) tend to be plusher and quieter
...than the Japanese cars ( Honda, Toyota, Nissan, Suzuki/Daihatsu/Subaru ) and Korean Cars (Daewoo Nubira/Chevrolet Optra, Daewoo Kalos/Chevrolet Aveo, Isuzu Panther/Chevrolet Tavera)
Traditionally the European and American car emphasized more on comfort. It used higher quality materials (leather, oak veneer, mahogany veneer, deep-pile carpeting). Imagine a large, spacious, smooth, and incredibly quiet sedan or station-wagon built for long drives on an endless expressway.
Oriental cars on the other hand emphasized fuel economy.They used thinner sheet metal, cardboard, cheaper plastics, less sound deadener. Imagine a cramped, noisy 4-cylinder hatchback built for getting the groceries.
Prestige comes from price, and in our nation, pricing and taxation decide which cars command prestige. Large, spacious, smooth, and silent sedans are another thing altogether.
Ram
__________________
Before you begin scrambling up the ladder of success,
make sure that it is leaning against the right building.
Ram is offline   Reply With Quote
Old 5th December 2007, 09:20   #10 (permalink)
Team-BHP Moderator
navin's Avatar
open cell foam will absorb moisture. even closed cell foam deteriorates over time. it is best to use material like butyl rubber which last longer inindian's hot/humid climate.
Wurth makes an under body spray on damper which does a pretty good job on road noise. you will need atleast 2 cans for a mid sized sedan. more for larger cars.
Our NHC and Octy have about the same quietness. So there is not hard and fast rule. Besides the Hyundai Embera is not noisy either.
__________________
Scixelsyd Etinu
Old 5th December 2007, 21:03   #11 (permalink)
Team-BHP Moderator
theMAG's Avatar
..and in our nation, pricing and taxation decide which cars command prestige.
Ram
Tell me about it. How much would it have costed Maruti to have provided some functional damping on the Swifts door pads? 200 bucks (mass production)?
__________________
If you lose your temper, you’ve lost the argument
Old 5th December 2007, 21:09   #12 (permalink)
condor's Avatar
navin : even closed cell foam deteriorates over time.
Navin, would you have any info on the life of the foam - how long would it last, and it's characteristics when it starts to disintegrate beyond usefulness ?
__________________
Life is Analog. Digital is an approximation.
Old 5th December 2007, 21:20   #13 (permalink)
Ram
Ram's Avatar
Back in the days when Fiat 1100Ds and Padminis were new and current, companies like "Rubbaseal" did rubberized body undercoating in volumes.
That deadened noise and provided corrosion protection too. At Larsen & Toubro Ltd., hundreds of managers like me, bought new Padminis each year and it was de rigueur to get a epoxy coating plus a rubberized body undercoating done before taking delivery of the new car.
Naturally, those "treated" cars rode more silently and lasted much longer than expected.
Our NHC and Octy have about the same quietness. So there is no hard and fast rule. Besides the Hyundai Embera is not noisy either.
You're right. There is no hard and fast rule. Then again, parameters like NVH (Noise, Vibration and Harshness) are not measured subjectively any more. Precision instruments exist to measure these.
And companies like Neilsoft, Pune, are in that space. They use finite element analysis software like ANSYS, ABAQUS and NASTRAN, LS-Dyna -- a transient dynamic finite element program for simulating panel noise and other complex real world problems. And LMS SYSNOISE simulation software for vibro-acoustic performance troubleshooting and design optimization.
It is their area of specialization to produce quiet comfortable designs for the Fiat-IVECOs and Lotus Engg's of the world.
Finally precise noise and vibration measurements prove the quality of their analysis and design.
NHC, Baleno and Toyota Corolla measure noisier than Palio and Octavia.
However I don't know enough about the Hyundai Embera's measurements.
__________________
Old 5th December 2007, 21:26   #14 (permalink)
Team-BHP Moderator
theMAG's Avatar
The foremost characteristic would be no sound deadening happening.
__________________
Old 6th December 2007, 00:35   #15 (permalink)
rocksterraghu's Avatar
That sounds like 'Japanese cars' are noisier than 'European cars'. Something to do with build quality?
__________________
Everything should be made as simple as possible, but not simpler
Thread Tools
Car/SUV with low cabin noise msdivy SUVs, MUVs & 4x4s 32 3rd May 2008 11:58
So why all the noise making by the Car Manufacturers abt ICE ?? blueraven316 Product Discussions 15 22nd January 2008 12:49
Noise in the car prakashc Technical Stuff 3 1st February 2007 13:59
Need some input on reducing rattling noise in the rear due to the oval speakers partypest Ask the Gurus 4 5th January 2007 06:49
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
