| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #136 (permalink) | |
| BHPian Join Date: Sep 2006 Location: bangalore
| Quote:
Hey Divx, You can find the RAM just to the left of the CPU+Fan. ![]() | |
| | #137 (permalink) | |
| BHPian Join Date: Mar 2006 Location: goa
| Quote:
I have a KB and mouse cordless, which uses USB module , and I can type in the Password for Bios , so I think the USB gets power when the MB turned ON. | |
| | #138 (permalink) |
| Senior - BHPian Join Date: Jul 2006 Location: mumbai
| pictures are only for reference for harjeev to have an idea of locations possible in safari. dont know how long the 3.5 hard disk lasted in that setup or is it going strong still. one of our member is using 3.5 drive without problem.i think i can see the two sticks of ram in first picture.looks like a microATX board. Anyways why should carputers be powerless, the limiting factor presently is only the power supply. i have seen upto 220watts available. if you can do it go for a high definition setup with 5.1 speakers. safari looks like has lot of potential for this. rest is as per actual requirement. try using single hard disk, power fans directly form car power supply.use number of usb ports as per requirement.mini ITX boards for core2duo are also there with lot of features. Thanks dinar, will look out for some other way to do it, may be use parallel port. i am having serious mechanical problems with engine, let me sort it out(expecting a huge bill for the repairs) Last edited by gigy : 22nd May 2008 at 17:47. |
| | #139 (permalink) | |||
| Senior - BHPian | @Shldn Gigy Thanks for you reply I am still not able to decide on the motherboard. Please execuse me for the long post and thanks for your patience. I totally agree with Shldn that the 965 M/b will demand more power and with give more heat and at the same time I don’t have to run any serious applications to run. What basically I need is Music, Videos, GPS s/w and On Board Digonastics for my car, occasional internet surfing using GPRS on my cell phone and/or any other application that would be possible in the car. How I would execute all of this I don’t have the faintest idea and I would definitely be needing a lot of help from you guys. I don’t know what car navigation s/w to use, don’t know how to connect the car speaker systems to the PC, what maps, etc I am totally totally clueless, But I just need it! I think that I can go with the D201GLY2 M/b initially with 1GB RAM and the max HDD that I can find. I will most probably start with this config initially, get the hang of it for about a couple of years and then, if I feel the need for a more powerful system, I could shift this in my other car and assemble a new system for the Safari. OR Quote:
The form factor is the same as the DG201GLY & GLY2A. So I think that fitting it wouldn’t be an issue. Please advise? As this M/b supports upto Code2Duo & 2GB of RAM, would the DC2DC power supply, once again supplied by iRIDE, be compatible with this motherboard. If yes I think that I would go in for this M/b and a mobile core2duo processor with 2GB of RAM After giving thought to the above I think that my first preference would be the Jetway J9F2 with Mobile Core2Duo and the second preference would be the Intel DG201GLY2A with Celeron. Though, if I go with my heart I want the first option. Quote:
But still I like this idea too. But just worried about the safety of the system from dust etc. Quote:
iBall – Your eyeball view. Our technology new. If yes I will note the dimensions and see where can I fit this in my car. I think that there is enough space below the front passenger seat, but still have to see. But in any case there is ample space in the boot(the safari is like a room), But putting the cabinet there would involve a lot of cable laying, etc. Alternatively there is space near the leg space of the front passenger seat, under the glove box. I think that the cabinet can be mounted there too. Will try to post pics about the space I am talking, later on. Sorry for the long post.
__________________ 2007 Tata Safari 2.2 VTT 2000 Ex-Army MM550 1985 Ex-Army CJ3B 1963 WILLYS CJ3B Wishlist 2011 Gypsy 1.3 MPFI Last edited by harjeev : 22nd May 2008 at 18:42. | |||
| | #140 (permalink) |
| iride has readymade cpu in box with 80gb hard disk, 1gb ram and power supply if i am not wrong. its a good one to start with and comes for 14k. you will have to decide on the display and interface with music system only. gps antenna + software extra.internet browsing in the small display is a pain. if you are going for microATX board or ITX board zoom from zebronics is better. i will recommend buying normal amplifier case like mine for Rs150. sure you can make few precise holes to fix board in it. if you get the jetway mini ITX board then IRIDE case should do. get the dimensions and talk to iride guys. one more option is get a laptop motherboard itself or old laptop and modify suitably board like asus P5S-MX SE, P5N MX or BioStar GF7050V-M7 or Palit N73V or Intel DG31PR(size9.6x7.2'') support core2duo and come for less than 3k Last edited by Technocrat : 27th May 2008 at 13:38. |
| | #141 (permalink) | ||||||
| BHPian Join Date: Dec 2005 Location: Mumbai
| Quote:
? Sorry, your post was a little confusing.Quote:
![]() Quote:
| | #142 (permalink) |
| Senior - BHPian | @shldn Thanks for the info My 1st option is to use the jetway M/b with Mobile Core2Duo and 2GB of RAM. The 2nd option is to use the Intel DG201GLY2A M/b with Celeron processor and 1GB of RAM. I have told my H/w vendor to inquire about the availability of the Jetway M/b and a Mobile Core2Duo processor. After I get the M/b & the processor, I think from there on I will start planning the rest of the system. What do you say...
__________________ 2007 Tata Safari 2.2 VTT 2000 Ex-Army MM550 1985 Ex-Army CJ3B 1963 WILLYS CJ3B Wishlist 2011 Gypsy 1.3 MPFI |
| | #145 (permalink) |
| Senior - BHPian | IMHO, you really dont need powerfull CPU's with even more powerfull Graphics card. I have been running Google Earth, Front end and DVD simultaneously without any issues. All of these are CPU intensive and graphics intensive programs. Of course, I dont have Vista bloatware on my CarPC. Just Windows XP. |
| | #146 (permalink) |
| Senior - BHPian | Hi After almost 10 days of sleepless nights/ Searchinng, Reading, posting etc etc and with lots of everyones help and special help from Sheldon I have finalised the configuration for my Car PC. I would be assembling the following Quadrant-Fx CarPC Enclosure (Iride) IRV-070SE Touchscreen Monitor (Iride) Motherboard & CPU Intel D201GLY2A with Celeron 1.2Ghz (Iride) SB-160D DC-DC Automotive Power Supply(Iride) GPS Receiver (this would be either Iride's PS 648 USB ) or SatGuides Product Details::. I am not able to decide between the two, therefore have posted on http://www.team-bhp.com/forum/techni...tml#post844688 (Using a GPS Receiver in the Car) 1 GB DDR2 RAM (local vendor) 160/320 GB SATA HDD (local vendor) Everything would be going into my Tata Safari 2.2 DiCOR (which I think would be a 1st on T-BHP). I also plan to do away with the Cars Head Unit and control everything with the Car PC. Here again I would be requiring support from you all. I dont have the faintest idea how to go about. ![]() Though I have a spare P-IV 2.8 Ghz CPU and 845 chipset M/b I decided against it as it would be too much for a CAR PC. Also I had trouble matching the power supply. P4 consumes about 70 Watts and that leaves very little margin for the rest of the equipment like HDD/ USB equipment and the power supply(160D) give about (12VDC * 8A)=84W max. I calculated with this method http://www.mp3car.com/vbulletin/faq-emporium/68636-faq-will-insert-psu-model-power-supply-work-my-system.html (i hope I am right). this is where I plan to install the screen. Any Suggestions/ Comments??
| | #148 (permalink) |
| Senior - BHPian | 1st option doesnt look very promising. Its seems too low and the gear knob will come in the way, especially since you are using a touch screen. I suggest you get a spare centre console and do the mods. Get in touch with Team-BHP - View Profile: ankur, who has done similar mods on his Innova. |
| | #149 (permalink) |
| Senior - BHPian | @gigy @spavidal I have asked for advise from Ankur. I too am more interested in the 2nd location, but don't know how to go about the modification front. Lets wait and see
| | #150 (permalink) |
| BHPian Join Date: Oct 2006 Location: New Delhi
| Hi Harjeev, Its really nice to see more and more people jumping onto the carpc bandwagon, i dont look like an idiot now .As far as central console is concerned, i made it myself so i wont be able to recommend a modification vendor. For the actual installation i have faith only in the Gunbir/JB duo (i am not associated with them in any way) , you may ask them if they can do the console modification, they do a good job with custom work. As mentioned earlier, i did all my customization using spare parts and not my actual car console, then i just replaced the modified parts with the ones in my car. I still have the original parts that i can put back for a back to the factory look. For your console i strongly suggest you use option 1, option 2 will be a nightmare to shift all the controls down. That said, open up the console and see how much extra wiring you have to play with and if it will allow moving to the spot below. I would not advise you to make extensions and use those, i dont see them lasting long. Lastly i would VERY strongly advise you dont skimp on the wiring and power requirements. I am here if you need any more pointers. cheers. Last edited by ankur : 28th May 2008 at 12:56. |
« DIY - Now Add USB Support to your Old Head Unit/Amplifier
ICEing the Honda Civic - Part II (Carputer) »
| Thread Tools | |
Similar Threads | ||||
| Hondaputer !! Carpc in my ANHC ! | netarchie | DIY - Do it yourself | 111 | 20th November 2009 13:00 |
| How many of us have DIY CarPc in India? | monty9991 | DIY - Do it yourself | 67 | 12th November 2009 19:51 |
| HCL MiLeap as a CarPC Discussion | sushantr5 | DIY - Do it yourself | 62 | 29th October 2009 13:56 |
| CarPC with Acer Travelmate 4150NLCi | aravinthrk | DIY - Do it yourself | 10 | 24th October 2009 07:16 |
| My Baleno (I)ride - CarPC / Carputer install | spadival | DIY - Do it yourself | 40 | 21st March 2009 04:04 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
