| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #77 (permalink) |
| Senior - BHPian Join Date: Jul 2006 Location: mumbai
| i have ordered for the satguide offer of 6k for bluetooth receiver + Mumbai+all India map. let me see how my experience with them works out. hope i get the item delivered soon else it can turn out like the dc-dc board which is still on the way. meanwhile installed the dual battery concept. used the kinetic battery itself. had problem with the diode as there was 1.8v drop across it. in night with AC on (and day stop & go traffic) inverter started to beep and shut down sensing low voltage very frequently.so removed diode and out in a relay which is powered by 'acc', PC is connected to small battery. problem solved now. connected the voltmeter also just to know the loading . will update once gps starts working. |
| | #78 (permalink) |
| Senior - BHPian | Hopefully, Satguide folks would provide you with better service this time. Gigy, Shldn - I have a AverTV USB 2.0 TV tuner lying around with me and thought that I might as well use it in the car (to watch Doordarshan ). The problem is that I have lost the RF to 3.5inch mini jack that came with it. Also, even if I had it, I don't think I'll be able to get good reception. Is there any place where I can source a Car TV antenna that has 3.5 inch mini jack? |
| | #80 (permalink) |
| as shldn said you might find such a adapter in the electronics market. alternate is to solder both types of jacks or else change the jack on your existing antenna to 3.5 one since i dont think you will be using it for anything else. there is the 'v' or 'y' antenna in market which is for tv signal but works only if the signal strength is good and i think it is directional one. i am thinking if i try tata sky or likes in car. then on camping on river side its live tv. |
| | #82 (permalink) |
| i can suggest you a diy antenna in case you want to try the reception quality before buying a branded thing. get two copper tubes, each of about 1 meter in length and about 1cm in diameter. flatten one end of both and make hole to connect wire. get antenna wire (flat type). place both tubes with flattened side facing each other at a gap of 15millimeters exact. use a wooden board and clamps for the support. connect this to required pin and check the reception quality. i used this in the 80's and had very good reception compared to those huge ones with 12 additional booster rods and stuff. may be you can do research using the sat tv receivers also. the challenge is to make a platform which can be made to rotate using , may be a stepper motor which operates on drop in signal quality. what say? |
| | #83 (permalink) |
| Senior - BHPian | Thanks Gigy, I will first try with a simple antenna by ripping the 3.5mm jack off the Kingfisher earphones (freebie ) that I got and then connecting them to something metallic.Boredarshan transmissions are sufficiently strong in most places.. I wouldn't wanna go great lengths like using stepper motors to actually catch their signal .Last edited by spadival : 30th January 2008 at 12:25. |
| | #84 (permalink) |
| stepper motor platform was for sat tv reception, tata or dish tv; definetly not for DD. that antenna i told you is a directional one. receieves best when kept at 90* to transmission tower in horizontal plane. (line of site setup). if your intension is to use while camping outside the signal strength might be less. same applies if used around tall buildings. if the car roof can be made to sat tv antenna many issues can be cleared, but i dont want to make a hole for the research. the car will start looking like the ndtv tata sumo's roaming around. ![]() |
| | #85 (permalink) |
| update on the project- received the satguide kit by five days of ordering. satguide bluetooth gps receiver with Mumbai map and all India map. spent two days trying to pair it with my phone. then paired with the car pc. my bluetooth 2.0 dongle was not pairing up, later managed to pair it with the older 1.1 lying around in junk. getting used to its various options now. the larger display is nice to look at. the painful thing about the order was the day after i ordered satguide with Mumbai and all India map with receiver for 6k+tax times of india gave a one day offer for 3999. that was real bad. next month will look at OBD and security and car travel data logging. installed the voltmeter on right side so that will have a good idea on the electrical loads . this came to use the very next day of installing. that night while driving headlights started to dim and after some time was flickering. later completely off. no fog lamps also. i was scared initially expecting some electrical goofup but the voltmeter was rock steady all the time. because of this didnt stop and followed another car till home. later on found the connection out. if voltmeter was not there i would have stopped on road and searched for a mechanic since my tool box was lying in palio some pictures through my mobile ![]() ![]() ![]() ![]() Last edited by gigy : 4th February 2008 at 18:15. |
| | #87 (permalink) |
| I am still with the inverter and dual battery. its actually working fine now, and i actually dont require the dc-dc converter. thinking about putting it in market for sale. yesterday received a letter from customs asking me to go to foreign post office with relevant documents and collect it by ten days. so hopefully it has reached, i am thinking its the usual chai pani for these customs guys. |
| | #88 (permalink) |
| Senior - BHPian | gigy.. re OBD, The info I got so far by searching around the net indicate that while the physicial connector is OBD II, the actual protocol itself isnt OBDII. :( redlinegti.com :: View topic - Baleno OBD II port Thats quite apparent because there are only 3 wires running to the OBD II connector and they are all connected to the wrong pins. If you need to just find the fault codes, I found out you can get the fault code by shorting a terminal and counting the number of times the check engine light blinks!! redlinegti.com :: View topic - 2001 Baleno Fault Codes |
| | #89 (permalink) |
| thats bad news. anyways let me see what else can be done with it. do you know if its a bosch ecu? can the ecu be changed? are there any aftermarket ones available which can be direct replacement?; if so any idea of cost? |
| | #90 (permalink) |
| Senior - BHPian | I think its far easier to replace ur car than to change the ECU !! I think our Baleno ECU is a victim of historic quirkiness.. I have a feeling the protocol is OBD 1.5 or GM OBD (Look up wikipedia for OBD 1.5). This is more or less confirmed because ETAS Tech 2 handheld diag tool used by M.A.S.S supports only 3 protocols - GM OBDI, OBDII and GMLAN protocols (from ETAS Tech 2 flyer in ETAS - Tech 2 (GM) - Diagnostic Troubleshooting - Service Diagnostics - Applications & Solutions - ETAS Products) What you probably need is some thing like this OBD Diagnostics, Inc. - ALDL (GM OBD1) Cable with 16 pin Connector . But better to check with a friendly M.A.S.S on what protocol they setup the Tech 2 scanner before actually buying anything !! Last edited by spadival : 5th February 2008 at 08:52. |
| Thread Tools | |
Similar Threads | ||||
| Hondaputer !! Carpc in my ANHC ! | netarchie | DIY - Do it yourself | 111 | 20th November 2009 13:00 |
| How many of us have DIY CarPc in India? | monty9991 | DIY - Do it yourself | 67 | 12th November 2009 19:51 |
| HCL MiLeap as a CarPC Discussion | sushantr5 | DIY - Do it yourself | 62 | 29th October 2009 13:56 |
| CarPC with Acer Travelmate 4150NLCi | aravinthrk | DIY - Do it yourself | 10 | 24th October 2009 07:16 |
| My Baleno (I)ride - CarPC / Carputer install | spadival | DIY - Do it yourself | 40 | 21st March 2009 04:04 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
