Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 21st December 2007, 11:31   #16 (permalink)
A suggestion Gigy, you are using a normal desktop Hard Disk here and that too without any damping to protect it from shocks and jerks. I am not too sure about it as it will fail sooner or later. My suggestion is to add some shock proofing to it by using rubber or foam sheets. If possible, try to get hold of a Laptop HDD as it is designed to absorb some amount of shocks and jerks.
I will be following this thread closely. Keep us updated :-)
SumitB is online now   Reply With Quote
Old 21st December 2007, 11:44   #17 (permalink)
Thumbs up
Hello gigy,
Good going on the DIY, more power to you !
The case is a good effort, what motherboard & cpu are you using with it ?
Originally Posted by gigy
i will be pleased to receive support or information regarding obd support for baleno of 2000 make which is compatable with xp or me or win 95
The baleno is reported to be incompaitable with ELM based scantools. In case you want a ELM 327 based scantool to try out / test with your baleno, send me a pm.
Originally Posted by spadival
Also, DC to AC power inverter is a bad idea.. Inverters tend to generate heat and placing them so close to the MB isn't going to help. Check if you can source a DC-DC SMPS
. You will also require additional cooling, maybe 2 fans in a push-pull configuration depending on your case design. Not to mention the inverter won't survive engine cranks and does not have a shutdown controller. A DC-DC PSU would be a better option.
It sounds greek and latin to me, but they said PID's of Baleno's ECU are different.
Here's a head's up on the PID's, OBD-II PID's
shldn is offline   Reply With Quote
Old 21st December 2007, 12:54   #18 (permalink)
spadival's Avatar
Originally Posted by DirtyDan View Post
I was just trying to understand what you are doing.
DD, Hope this quote from another thread answers your question!!
http://www.team-bhp.com/forum/383822-post25.html (My First Car PC Install - Research and Planning Stage)
Hehe.. I had you in mind when I suggested to gigy that he try it out before he buys.
shutdown controller means that DC-DC acts like a mini UPS, providing power for around 20 seconds after the ignition is turned off, so that the CarPC shuts down or hibernates safely. I don't think an inverter can do that.. pretty soon, all those instances when power was cut off abruptly (in case u forget to shut down the PC before turning the ignition off) will mean that you will have OS software issues (whether its XP or Linux), if not, god forbid, hardware issues.
spadival is offline   Reply With Quote
Old 21st December 2007, 14:13   #19 (permalink)
gigy's Avatar
Thanks Sam bhai, i those threads were my inspiration for trying to make this project.
spadival, i know it might run bit hot; its rated at 150w and designed as a closed box with aluminium body for heat dissipiation. since its a celeron 1.7 + motherboard and one cpu fan i dont think the load will exceed 80w. so hope both the smps(designed for 350w) and inverter will stay in limits. may be i will switch on the system in hot afternoons after the ac has cooled off cabin to reasonable levels.
dirtydan, no worries. i just like to screw up things. sometimes i helps me do things better sometimes my bank balance goes down. part of my hobby since childhood. i had a pc to throw out, but why create e waste when i can still use it in car for better things.
OBD was an important consideration since occasionally i get engine control light when i do 0-100 little faster with lpg. i know it is because of the lpg kit its throttle connections and lambda sensor. just in case some day i get that light due to some other serious problem and i continue, this will help me out., else it might end catastrophic if i continue to think if the fault is the normal one associated with lpg.
i will be carrying all media items (music and video) in pen drive. if i have to go for a dvd player capable of this a jvc ****700 will still cost 23000k. dvd and cd will still be required. all my cd and dvd goes bad after 6 months lying in the car.
i am not a software professional and i know very little about computers compared to professionals. i know little about electronics.
rest i learn with experience.
__________________
Baleno1.6,Carputer:AMD Athlon 3000+,2gbram,80gb HD,centerfuse FE,satguide gps.
Old 21st December 2007, 14:19   #20 (permalink)
gigy's Avatar
sumit, i know about that risk, this hard disk of mine is 4-5 years old and make small noise while operating. didnt shock mount it fully due to lack of space, will go for mobile HD with 2.5 to 3.5 converter card once this fails.initial plan was to mount the whole cpu case on a foam padding but space restriction below the seat.once i get a slim case like the ofice ibm and hp pc will mount it in a good sponge base. once i go for a 2.5 hard disk the box can be made smaller also in case i dont manage readymade case.for the time i am not spending on the HD till it runs successfully.
one of my friend is geting linux software which is pen drive bootable. will try that also to see if i can remove HD forever. then a 4 gb pen drive will be more than enough.
shldn i will get in touch with you later after all is working fine.
__________________
Old 21st December 2007, 14:28   #21 (permalink)
gigy's Avatar
the inverter is going to be power directly from battery with a seperate fuse and switch. so cranking and shutdown should not be a issue. pc will have to be manually started and shut down.
startup shut down controller with 150w power rating of iride will cost 5500. may go for it later on.
Will try to link it to the beeper so that when key is removed i will be alerted. anyways i will be able to see that its not switched off before leaving.
6-32v is the input for inverter so should remain powered properly during cranks. it also shuts down in low battery condition.
__________________
Old 21st December 2007, 14:31   #22 (permalink)
NOTORIOUS's Avatar
Good work gigy, but i have some thing for you :
  • What is the model of your motherboard , does it support booting via usb.
  • if your friend has a linux which boots from cd, then i have xp too.
i am a computer hardware engineer and going to be a networking to. i am here for your help always. please ask questions when you feel like.
__________________
Want A Car , If Any One Has A Spare And want to donate PM ME....
NOTORIOUS is offline   Reply With Quote
Old 21st December 2007, 15:19   #23 (permalink)
I think you might be cutting it fine taking into account the design and efficiency of the inverter and smps. I would consider underclocking the cpu a bit. Please use caution and let us know how it goes.
Old 21st December 2007, 16:52   #24 (permalink)
gigy's Avatar
its a zebronics motherboard ITX size 845GV with AGP slot. supports boot from all sources. has cpu overclocking facility; i dont know much about its settings. its running at 17X by default. i did try to change it to 15X but on reboot its still 17X. may be i dont know how to do it, so everything in auto mode as of now. had loaded windows media center edition 2005 and there was no problem in its functioning. only problem i had was tv tuner radio was not recognized by windows media center. this is not a media center edition tv tuner card. tried in banglore chennai and mumbai. so now on xp home edition.
if gps and OBD will work with linux then i will be happy to go open source.
I have ubuntu 7.1, knoppix, opensuse 10.3 but have not played around with those till now.
i thought will install the monitor today but the whole day went in installing the cpu and its connections to power , amplifier, receivers and fm antenna. antenna has come up through the B pillar and both ends i have routed to a pillar and c pillar. hope it will not be a issue in receiving the signals. headunit and sub are out as of now.
__________________
Old 21st December 2007, 22:27   #25 (permalink)
gigy's Avatar
few pictures of wiring completed.
turn on signal for amplifier is taken from fan of smps.
__________________
Old 22nd December 2007, 12:23   #26 (permalink)
gigy's Avatar
latest update. managed to get xp live usb bootable software. installed it in my pen drive and booted . looks like a xp setup for booting up crashed pc to repair it than one which will load other softwares. i could'nt figure it out. does anyone know if this can be used to load other softwares like tv tuner , gps and obd?
__________________
Old 23rd December 2007, 10:23   #27 (permalink)
spadival's Avatar
I have a spare inverter lying around .. cant use it anymore because my car no longer has a cig lighter . PM me your address.. I can courier it to you.
Old 23rd December 2007, 11:57   #28 (permalink)
gigy's Avatar
thanks for the offer Spadival. i have bought the inverter few days back. the lcd display 7'' wide screen of necvox FD-7569(Rs5200) i bought yesterday is also mounted in dashboard. got a beige coloured one, so its going prety well with the center console. had to cout off the bottom plastic strip and trim the top a llittle to get it centered and keep AC controls clear. happy with its finish of installation.
cpu seems to have a problem and cant figure it out. works fine when re-tested in home but in car when inverter is powered up the cpu fan starts, and there is no video output, power led remains on. will work on it after a ew days due to house work. dont know if this has to do with isolation of dc ground and ac ground.
__________________
Old 23rd December 2007, 13:34   #29 (permalink)
most likely a power related problem. your inverter may not have enough juice to power your setup. what gfx card are you running ?
Old 24th December 2007, 07:37   #30 (permalink)
gigy's Avatar
the display installed-
__________________
Thread Tools
Need help for Palio Stile 1.1 ICE Setup,Budget < 40K. ramki067 Ask the Gurus 16 10th October 2007 16:26
Entertainment Setup required for Scorpio..! wolfinstein Ask the Gurus 0 1st April 2007 10:56
Car Entertainment + Screens indizen Ask the Gurus 2 31st May 2005 12:23
In-car entertainment... GreenHex The Indian Car Scene!! 6 29th July 2004 01:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
