Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 17th April 2008, 15:15   #106 (permalink)
cud'nt you able to find the cause of mobo being dead?
monty9991 is offline   Reply With Quote
Old 17th April 2008, 18:20   #107 (permalink)
gigy's Avatar
i am not discarding the whole thing, only the motherboard and processor. honestly i dont have free time now a days due my exams and baby. so cant do much research on new motherboards.
for my level of knowledge i isolated everything and used home smps and monitor to power up the motherboard ,cpu combo. there is no response except the cpu fan. dont have a spare celeron or p4 to swap and see. if i have to change the motherboard will prefer a dual vga one now.
__________________
Baleno1.6,Carputer:AMD Athlon 3000+,2gbram,80gb HD,centerfuse FE,satguide gps.
Old 19th April 2008, 15:16   #108 (permalink)
gigy's Avatar
changed plans and installed my home pc motherboard into the car pc case. its a mATX MSI RS480 motherboard with AMD Athlon 3000+ processor. Three advantages with this board is ,it has a direct tv out and now its 2gb memory and has 5.1 audio out. many of its usb ports have gone bad, so using the internal ones with extension cable.
will upgrade home pc to intel dual or quadra core later and make it a htpc.
__________________
Old 21st April 2008, 09:32   #109 (permalink)
gigy's Avatar
The picture of logitech wireless numeric keypad which has made life much easier now. most of the controls are on steering.stuck with double sticking tape. volume, bass treble, track, menu, mute,navigation change.
__________________
Old 21st April 2008, 09:52   #110 (permalink)
Team-BHP Moderator
DerAlte's Avatar
What does the red LED (on the steering wheel) indicate?
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 21st April 2008, 10:09   #111 (permalink)
revvedup's Avatar
gigy that numeric keypad integration on the steering wheel is uber cool, but tell me how do you control your music via it.
@ Der Alte-Maybe it is some sorta shift light
__________________
R.I.P Rtech
The journey is more important than the destination
Chief Test Driver, Porsche*
revvedup is offline   Reply With Quote
Old 21st April 2008, 10:16   #112 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by revvedup View Post
...@ Der Alte-Maybe it is some sorta shift light
Counter-intuitive to have a shift light on the steering wheel - you would have to look down to see it.
__________________
Old 21st April 2008, 10:23   #113 (permalink)
Keep a watch on the power drawn by your new motherboard, processor, DDR...I'm not sure about Athlon's power consumption figures but I get a feel that you are pushing the M2-ATX to its limit.
M2-ATX's has a bad reputation of suiciding and killing the connected peripherals if they are overloaded!!!
Please ensure that the M2-ATX has enough head room, i.e, individual voltage rails are not loaded more than 80-85% of the rated capacity.
The following is the rated maximum power rail capacity for the M2-ATX
5V - 8A
12V - 8A
3.3V - 8A
5V SB - 1.5A
-12V - 0.15A
__________________
dentalteam.org
Digital Vampire is offline   Reply With Quote
Old 21st April 2008, 10:53   #114 (permalink)
gigy's Avatar
DerAlte, its a horn switch. the old baleno had the four spoke steering wheel with horn in center, it was distracting & pain to take out your hand off steering, particularly while driving faster to pump the horn, so made this alternate arrangement to use the thumb. wanted to put two on both sides but was not sure i can make it symmetic. now after the numeric pad deactivated the center horn switch.
revvedup, centerfuse has option to assign hotkeys to keyboard. i assigned it to the numberpad.
digital vampire , not sure of the load but i have tried to keep it minimum possible. hope the 160watts power board handles it. didnt have any issue till now.
__________________
Old 12th May 2008, 17:27   #115 (permalink)
gigy's Avatar
plan to incorporate security into the carputer . enter password to start the car. there will be no prompt to do it but anyone try to just start the car there will not be any fuel, ignition and crank. additionally can wire the horn to blast. of course there will be a hidden override in not so convenient location. whats you view on this.
__________________
Old 12th May 2008, 18:56   #116 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by gigy View Post
plan to incorporate security into the carputer . ... whats you view on this.
Unless you are able to emulate the Immobilizer route (logically, via CAN or some such bus) direct to the ECU, you would land up reducing system reliability by adding points of probable failure (I am not even talking about M$Windoze and cars!). For example, to account for the override switch, you will have to add a relay, and so on and so forth.
Now imagine you have to make a quick start, wouldn't you find that a nuisance if you are not able to start the car?
On the other hand, cars which have a push-button start (true keyless entry types), logic is implemented in the ECU which validates all permittances before allowing Starter command and Ignition permittance to go through. In such cases, additional alternates are provided (in hardware as an ECU pin) which count towards that permittance, and one can wire one's own enablers / disablers.
__________________
Old 12th May 2008, 20:29   #117 (permalink)
Well your override will have to be in a very convenient location, if you are to use your current setup with Windoze for this .
Look at StevieG's Access Control instead. While it doesn't really meet your objective it still is pretty nifty, with the latest version supporting Video recording and access via M$ fingerprint scanner. Oh and there are some nice skins to go with it too.
shldn is online now   Reply With Quote
Old 13th May 2008, 10:22   #118 (permalink)
gigy's Avatar
sure reliability of the system will go down but will try to keep it as reliable as possible.the carputer will be the weakest link i think. any info on the ecu connections where if i give a high or low to any of its pins i can disable ecu functioning or making it go into off or standby mode. i think i am risking many things!
__________________
Old 13th May 2008, 11:19   #119 (permalink)
spadival's Avatar
Better buy an immobilizer instead. Otherwise, the time it takes for the system to boot up, you'll be twiddling your thumb!
There are other useful stuff like remote tyre pressure monitoring system that you can implement.
Oh..Another update. An English guy on another forum has started deciphering the Suzuki ECU's. redlinegti.com • View topic - Baleno OBD II port ..
spadival is offline   Reply With Quote
Old 13th May 2008, 11:30   #120 (permalink)
gigy's Avatar
have a immobilizer in car but not connected it since, looking at the way wiring is done for the security system i fear one day it might develop wiring problem.
wanted to fiddle around a diy security system so that no one will be having idea of figuring it out.
nowadays i dont think any thief will be interested in baleno anyways
__________________
Thread Tools
Need help for Palio Stile 1.1 ICE Setup,Budget < 40K. ramki067 Ask the Gurus 16 10th October 2007 16:26
Entertainment Setup required for Scorpio..! wolfinstein Ask the Gurus 0 1st April 2007 10:56
Car Entertainment + Screens indizen Ask the Gurus 2 31st May 2005 12:23
In-car entertainment... GreenHex The Indian Car Scene!! 6 29th July 2004 01:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
