| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | Time to replace the much maligned Soomoku sub in my Baleno! Current setup has Pio 4950, EL62 coaxes in front door and rear tray. Speakers driven by a 75.4. Planning to add a GZTW10MK2 or GZTW12MK2 sub (Ajay here I come !) and new speaker wires. Now the reason this is in the DIY section. It used to bug me that if I'm able to wire a home theater, why do I need to go to someone to wire the ICE? Note that I'm not using the term install since I believe that involves more than just connecting some components. All I wanted was to be able to connect the ICE myself. The biggest bottleneck seemed to be removing and putting back the various panels in the car. Over the last couple of months, I have managed to learn this. Now I am fairly confident of taking out the HU, removing and putting back door panels, door sill panels, rear sear etc. Of course there are still grey areas, hence this thread. Since I am a noobie in this DIY thing, my intention is to detail out apparently simple steps so that I'm prepared when I start putting things together. Please bear with me. Specific queries are in italics. Steps for connecting. Dismantle existing setup - Disconnect the rear and front speaker wires and general cleanup - Do I need to disconnect the AMP power to do this? Or should I just keep it switched off? Rear Speakers - Connect rear speakers first ie before the front and the sub - Connect speaker level out from HU to rear speakers. The rear speaker wires will be run along the right door sills to the HU. - The speaker level out wires connected to the 'harness??' plug on the HU are very thin and have multiple colours. Questions. - How to identify the rear left and right from among the 8 speaker out wires? I was thinking of connecting the new wire to the rear speakers and then at the HU end, play some music, and find out by trial and error, by connecting the speaker wires to the speaker out wires one by one. Is this ok? - As I said there are multiple colours for the 4 pairs (8 in total) speaker out wires. How do I identify the -ve and +ve? Is there a colour code? - I plan to get 16gauge speaker wire. The short length (10cm approx) speaker out from the HU are probably 24 gauge. Is there any problem in connecting these two types of wire? Front Speakers - Front RCA from HU to Front Input in AMP. AMP is fixed to the rear seat and this RCA is already in place. It runs along the left door sill. - Connect front speaker out from AMP to front speakers. These wires will run with the rear speaker wires along the right door sill. - For the right door speaker, run the wire to behind the panel below the steering and pass it into the right door through the pipe near the door hinges. - For the front left speaker, run the wire from the AMP along the right door sill, to behind the steering wheel, then behind the HU across to the left side. Pass it through the pipe into the left door. Questions - Is it difficult to pass the speaker wire through the pipe? Any techniques that might help? Sub - Connect Sub RCA from HU to Rear Input of AMP. This RCA is already in place and is being used for the rear speakers. It runs along the left door sill. I believe I'll just need to take the RCAs out from the rear speaker sockets and plug them into the sub outs of the HU? - Bridge the rear out from the AMP and connect it to the subwoofer. Questions - Bridging would mean connecting the +ve of the sub speaker wire to the +ve of the rear left speaker out on the AMP and the -ve of the sub speaker wire to the -ve of the rear right speaker out on the AMP? - Is a sub-protector grill necessary? Are they expensive? - Will there be a significant difference between a 10" (300W) and a 12" (400W) sub, both driven by a 284W bridged AMP? I'm not looking to wake up the neighbours. Just clean and decent punch. Connectors - What connectors are required for connecting the wires to the speaker terminals? - I'll try to get banana plugs for connecting the speaker wire to the sub. Length - I would need 5 metres on an average for each of the speakers? Say 20mts, 60ft approx? - Sub wire should be long enough to move the sub around in the boot. So I guess 1.5 metres should suffice? Misc - FYI, The AMP power cord runs approx along the centre of the car under the carpet. The AMP remote wire runs along the left door sill,with the RCAs. What do I need to buy and from where ? - Sub and box with banana connectors (banking on Ajay) - Say 20-25 mts 16 gauge speaker wire (any place where I can buy relatively cheap, online?) - Wire connectors; where do I get them? if not will have to make do with twist-and-tape :(
__________________ PIGZILNKILJBSCOMB Last edited by shuvc : 9th January 2008 at 13:37. |
| | #2 (permalink) | ||||||||||||
| Senior - BHPian Join Date: Mar 2006 Location: Dubai (3-10 July)
| This DIY thing is becoming quite a fad, lol! Quote:
)Quote:
__________________ Operator! Give me the number for 911! Last edited by Bass&Trouble : 9th January 2008 at 15:29. | ||||||||||||
| | #3 (permalink) | |||
| Senior - BHPian | Well till you appoint a decent dealer/installer at Kolkata, DIY seems to be the way to go if one wants Illusions and GZ ![]() Quote:
Are fuses sold separately? Cost? How do I fit one? Aha. Then I want it ! Quote:
Ok lets put it this way. I don't want to touch the power wire which runs through the centre of the car. I also don't want to touch the remote wire that runs along the left doors. That leaves the RCAs (currently along left side) and the speaker wires. Whats the best route for the speaker wires? The left speakers along the left and right along the right?
__________________ PIGZILNKILJBSCOMB | |||
| | #4 (permalink) | |||||
| Quote:
All the more reason to put fuses. Quote:
![]() Quote:
__________________ Operator! Give me the number for 911! | |||||
| | #6 (permalink) | |
| Senior - BHPian | Quote:
- It is probably a 8gauge wire. Not sure. Hope I'll be able to cut it with a standard wire cutter? - Where do I get fuse replacements? - Do I need to drill any holes into, say the engine firewall, to mount the fuseholder? Or can I anchor it with some wire, say on the top of the strut? Crimp & Spade terminals - Does it require any special tool to fix the wire to the terminal? Right - now onto damping. - Do the sheets have adhesive on one side? Or do I need to get adhesive separately? - Can they be cut with normal pairs of scissors? Or is it easier with knives, paper cutters etc? - Given that I don't want to go into the process of removing power window, central locking assemblies, how much can I realistically damp? - The OEM plastic sheet covering the door needs to be removed? Will this have any effect on water seeping through during the monsoons? - I was wondering, the door is made of metal. The door pad of plastic. Wont the plastic need more damping? Will it not be more VFM if the inner surface of the door pad is damped instead of the metal? - Do damping material become brittle in the long run? How long do they last?
__________________ PIGZILNKILJBSCOMB Last edited by shuvc : 9th January 2008 at 23:40. | |
| | #7 (permalink) |
| Senior - BHPian | My 2 cents on some of your questions. - It is probably a 8gauge wire. Not sure. Hope I'll be able to cut it with a standard wire cutter? Yes - Where do I get fuse replacements? Accessory shops like Glix should have it. If not, I'm sure you can source them from Mumbai, Delhi etc. - Do I need to drill any holes into, say the engine firewall, to mount the fuseholder? Or can I anchor it with some wire, say on the top of the strut? No drilling required. You can anchor it to existing structures, for example, the fuse box. Right - now onto damping. - Do the sheets have adhesive on one side? Or do I need to get adhesive separately? They do have adhesive. - Can they be cut with normal pairs of scissors? Or is it easier with knives, paper cutters etc? Knives and paper cutters are easier to use from what I have seen, though scissors can be used as well. Let me know when you're doing this. Would be glad to lend a helping hand where I can ![]() |
| | #10 (permalink) | |
- an ICE guru who has to call up people to find out how to connect -ve and +ve terminals !??Thanks for the helping hands though. But not sure when I'll do it. Preferably take a day off from office, else wifey is going to be pretty cross, if I spend all Sat/Sun downstairs in the garage. To summarise, I still have these doubts/queries. -Is it difficult to pass the speaker wire from the footwell, through the pipe that goes into the front doors? Any techniques that might help? - To connect the fuse, before splitting the cable I guess I need to disconnect it at either the battery end or the Amp end? Which is preferrable? I'd prefer Amp end. - Does it require any special tool to fix the speaker wire to the Crimp & Spade terminals? - The OEM plastic sheet covering the door needs to be removed for damping the metal? Will this have any effect on water seeping through during the monsoons? - How many sq ft of damping required for the front doors? Say I damp the door pad inner and bits of the metal. 7-10sq ft each door? - What would be the approx weight of a 12" sub in a sealed box? I'm wondering if it'll topple over, like the 'golu' Soomoku used to when taking sharp corners or during hard braking.
| | #11 (permalink) | ||||||
| Quote:
__________________ Operator! Give me the number for 911! | ||||||
| | #12 (permalink) | ||
One thing I did not get. Why detach the tube? Quote:
Will have to make do with a regular then. I'm hoping, you'll take care of that aspect ![]()
__________________ PIGZILNKILJBSCOMB Last edited by shuvc : 10th January 2008 at 16:32. | ||
| | #13 (permalink) | |||
| Quote:
| | #14 (permalink) |
| Senior - BHPian | DIY is fun. Managed to hook up everything. Apologies upfront. No snaps. I worked alone, against time and the hands got really dirty, so dropped the idea of taking snaps. Primary lesson learnt. Newbie DIYers, should factor in a lot of extra time. I had planned to complete the following in 1 day. 1. HU to rear speakers wiring 2. Amp to front speakers wiring 3. Damping front doors 4. Connecting amp power cable fuse in the engine bay 5. Fit the Neutrik Speakon in the box, connect the sub and fix it to the box, Fix sub protector grill 6. Connect the sub to the Amp I received the parcel from B&T on Thursday 17th Jan. Planned to finish the setup on Friday. Thursday night Status Completed Step 5 above. Did not fix protector grill, since did not have proper washers/screws. Friday morning started work around 11:30ish. Connected the rear speakers to the HU quickly. Then got stuck. It took me 3-4 hours to pass the speaker wire from the driver footwell to the right door. In the process sprained my left arm/shoulder. At one point of time I had almost given up and resigned to sticking the stock wires. But the Illusion Reference wires looked/felt so good, they kept me going. I just HAD to use them. So went to a nearby hardware store, bought a few feet of stiff wire ('taar') and finally met with success. I was getting late in picking up wifey from office, so hurriedly connected the sub and called it a day.Status Completed Step 1, Step 6 and 50% of Step2. So much for my project plan. Saturday morning, had just enough time,amidst other household chores, to fix the fuse and attend to a bit of static that had crept in. I realised India was faring better when I was not watching the match, hence had a quick lunch and went back to the garage. With the confidence of having cracked the wiring for the right door, I attacked the left door with gusto. This time it was a lot quicker. Managed to wire the left front in an hour and a half! Cleaned up some wiring. Then went onto damping the left door. Finished the inner metal frame around 6pm. Went home for tea with the left door panel. Damped the door panel at home and fixed it later at night. Status Completed Step 4, step 2, 50% of step 3. Sunday morning was spent at the doc (Son's throat infection and viral). Completed damping the driver side door in the afternoon. Took me another 3 hours approx. Tried to do a neater and more comprehensive job compared to the left door. Then spent some time tuning the setup. Status Competed Step3 PHEW ! Started off for work this morning and realised for the first time how different the music sounded compared to Saturday morning, ie. post damping. The depth has increased a lot. It sounds so full now. And am loving the sub, more for the bass guitar pieces than the drums. Lovely. Pending tasks. 1. Cleanup wires in the boot. 2. Fit sub protector grill. There's one issue though: The rear ELs are very faint. Barely audible at a volume level of say 30 (the Pio 4950 goes up to 60 odd). Even when I fade it fully to the rear. Doesn't seem to affect the listening experience, but am just wondering why it is so. The current settings are: - EQ Flat - Sub LPF 100hz from HU, HU boost 0 - Speakers HPF 100hz from HU - Fader at centre/0 - SLA set to 0 - Amp gain for both sub and fronts are at around 2-3V - HU speaker level out directly connected to rear speakers. I have tested that the correct wires are connected. This has been done using janta local speaker wire that the car acc shops use. Ajay ! A truckload of thanks to you ![]()
__________________ PIGZILNKILJBSCOMB Last edited by shuvc : 21st January 2008 at 15:26. |
| | #15 (permalink) |
| BHPian | ooh! awsome - though i am not much into ICE - i would love to get a demo of the setup! ![]() congrats man! i was like hmmmmm - when you first told me about your project last week. never thought you were serious - bindaas! jaa-taa! ![]()
__________________ Planet, Sonja, ETC - "Elements of Life" |
« Making of a budget car entertainment, navigation, diagnostics setup
DIY Guide : How to remove door panels - Tata Indica »
| Thread Tools | |
Similar Threads | ||||
| Connecting ipod to car speakers?!! | babe_on_wheels | DIY - Do it yourself | 43 | 17th December 2007 11:36 |
| <Newbie Alert> IronWolf Baleno Bangalore <Newbie Alert> | IronWolf | Introduce yourself | 26 | 21st June 2007 20:28 |
| Connecting Laptop and LCD. | VMG | Gadgets, Computers & Software | 12 | 8th June 2007 14:52 |
| Problem connecting Laptop to TV | RX135 | Gadgets, Computers & Software | 13 | 25th May 2006 10:16 |
| Connecting Sub to HU? | kvish | Ask the Gurus | 4 | 25th April 2006 11:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214
