Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 4th February 2008, 10:38   #16 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by clipto333 View Post
Whats a cordless drill "driver" janaab
A cordless drill-driver is a combination of drill and screw-driver: low/high speed drill with low/medium torque + low speed/high torque screw driver setting. Q.v. Cordless Drill Drivers
There are also cordless hammer drill - driver versions. Q.v. Cordless Hammer Drill & Rotary Hammer Drill : TOOLFETCH
Both come with keyless chucks for easy bit changing.
A cordless drill will be too expensive especially Bosch. For home use, a normal drill would suffice
Convenience costs, but lack of it pinches badly sometimes. Especially when you are on the last few holes and power goes off!
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
DerAlte is online now   Reply With Quote
Old 4th February 2008, 10:59   #17 (permalink)
Last few holes and the battery dies on you. Stick it into the charger and find there's a power outage! LOL. You can't win against Murphy.
IMHO, a corded drilling machine is well suited for the stated requirements. Cordless machines will ask for a new battery pack a few years down the line - a completely avoidable expense!
A 1/3 HP, reversible, variable speed, hammer drill should do fine.
Good bits are, of course, indispensable. For use in masonry or concrete, a hammer drill is a must along with good quality carbide-tipped masonry bits.
anupmathur is online now   Reply With Quote
Old 4th February 2008, 15:08   #18 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Very true, Mathur-sahab. (Well, you can have another battery, like most DIYers do, but that's not the point). I have persisted with a simple 2 speed hammer drill for the last 20+ years. Bought a Bosch cordless screw-driver, when I couldn't find one of those speed reducer screw driver attachments that were popular 10-15 years back. Before that, even I had stripped a lot of screw heads and threads using a screw-driver bit to tighten screws with a drill.
The cordless part is for the convenience of taking it wherever you go without needing an extension cord.
__________________
Old 4th February 2008, 16:21   #19 (permalink)
... when I couldn't find one of those speed reducer screw driver attachments that were popular 10-15 years back. Before that, even I had stripped a lot of screw heads and threads using a screw-driver bit to tighten screws with a drill.
Having closely observed carpenters in Delhi, I learnt (many years ago) that there is no need to tighten/rotate screws with a screwdriver. Simply make a 'pilot' hole and hammer the darned thingy in!!
I guess a screw-driver bit on a hammer drill would be very handy indeed!
Old 4th February 2008, 21:09   #20 (permalink)
Fillmore's Avatar
Default Drill
Got the Drill today.
Drill > Bosch GSB 10 RE
Cost after discounts - Rs 2,496/-
Has the following options
- Forward / Reverse rotation
- Hammer Drill
Also got a Bosch Drill bit kit
Cost after discounts - Rs 596/-
Includes
- 10 bits for Steel
1,2,3,4,4.8,5,6,7,8 & 10mm
- 5 bits for Concrete
4,5,6,7 & 8mm
- 4 bits for wood
4,5,6 & 8mm
The cordless drills were starting at 10k, So dropped the idea as this is all that I need.
Fillmore is offline   Reply With Quote
Old 5th February 2008, 00:19   #21 (permalink)
clipto333's Avatar
thanks for the link.
Deralte phappe, i suggested a normal drill because of the requirements.
although a battery powered drill will drill holes in concrete, the battery will discharge rapidly. and if one keeps on drilling in concrete, i don't know how long a cordless drill will last.
i have a corded drill machine for heavy jobs cause i don't wanna spoil my cordless drill.
IMO, cordless drill machined are best used as a screw driver or for minor drilling work(im talking about the not so expensive ones)
correct me if im wrong.
cheers
clip.
clipto333 is online now   Reply With Quote
Old 25th March 2008, 23:20   #22 (permalink)
KTC
Is there a Bosch showroom in Mumbai ?
KTC is offline   Reply With Quote
Old 3rd May 2008, 16:41   #23 (permalink)
Even I am looking for a cordless drill / Hammer. Saw few abroad but the charger came with 220V /60Hz. Any idea if ‘Black & Decker’ available in Bangalore / India?
Limpid is offline   Reply With Quote
Old 4th May 2008, 19:32   #24 (permalink)
The 220V/60Hz charger would have done just fine here!
Black & Decker should be available in Bangalore.
Do check out the generic Chinese imports which come at a fraction of the cost. If you're a light/weekend user, these would be fine for you.
Old 4th May 2008, 21:53   #25 (permalink)
adityamunshi's Avatar
I second that. I bought a Chinese drill (power colt) because i use it once every few months or so and it works just fine.
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is online now   Reply With Quote
Old 5th May 2008, 08:34   #26 (permalink)
Aditya, looking at your avatar, aren't you too young to be playing with power tools!?
LOL, just kidding!
Old 5th May 2008, 09:50   #27 (permalink)
That isnt me, its Schumi !!
LOL, just kidding!
__________________
Old 5th May 2008, 10:29   #28 (permalink)
Last 3 years, I am using some German made power drill with Hammer drill capacity, high/low speed control as well as reverse rotation.
It costed me Rs350 and (+ Rs400 for bits).
I bought at Hardware shop at SP Road Bangalore, just oppsite to copper wire vendor(Ambika).
omishra is offline   Reply With Quote
Old 5th May 2008, 18:07   #29 (permalink)
Sorry, cannot believe! There's a dreadful mistake somewhere!
Old 6th May 2008, 15:12   #30 (permalink)
No my friend! There is no mistake. That drill is serving me and I am using in concrete wall as well as my metal work (thick Aluminium and some 10mm Iron/steel too).
I am a DIY'ist.
Thread Tools
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 19:56
subwoofer power and battery power requirement smats Ask the Gurus 22 18th October 2006 11:51
Please suggest - power windows, power steering from one Esteem to another pramodkumar Technical Stuff 4 1st September 2006 09:19
Matching HU amp power with Speaker power? hitra Ask the Gurus 12 29th August 2006 11:27
Difference between Power Screwdriver and Drill? sbasak Gadgets, Computers & Software 6 16th December 2005 21:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
