| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Nov 2007 Location: mumbai
| Need a preamp to connect between the Aux port and the audio source. I usually connect my cell phone to the HeadUnit in Aux mode, i have to pump up the volume to make it audible hence the need for a preamp arises. I Also tried to change the stereo to stereo cable to a better quality thinking that was dropping the voltage but it didn't help. I believe there is a impedance mismatch which is restricting max power o/p, hence a preamp is my requirement. After searching the net for a while I came across a car preamp on ESP [ elliot sound products] . I am not able to understand the concept of Artificial earth and why it is required. Is getting signal earth [ ground ] so difficult in a car or its just the body ? If any one has came across this problem and found a DIy solution please share. HU - Pio 5950 audio source - SE W580 or MP3 player
__________________ DONT RIDE FASTER THAN YOUR GUARDIAN ANGEL CAN FLY |
| | #3 (permalink) |
| Senior - BHPian | yup, a single op amp based stage should be more than adequate, I'm not sure whether the aux input and the PSU share the same ground. I think it will be simpler to use a battery instead. one 9V battery, One Dual channel OP amp IC ( preferably FET, since they are lower power) and some resistors to set the gain. ![]() PS : google for CMOY to find out more ![]()
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 24th May 2008 at 23:32. |
| | #6 (permalink) |
| The cable I am using is a Stereo to stereo cable, one end goes into the HU and other in the handsfree connector [ I disconnect the earphones ] 5950 HU has an aux-in port on the rear panel. SLA is at max for auxin Dhar are you getting a good bass response, as good as playing a CD ? i doubt using the IP-bus port will be any good ?
| | #7 (permalink) |
| BHPian | @abhay, I am using a IP-bus to RCA cable. I couldnt get a RB10 or RB 20. Hence it was custom made. The bass response is good. Maynot be as good as playing the same track from CD but the difference is negligible. If interested in DIY the following link might help. Gutterslide.com - Pioneer IP-BUS Hack |
| | #8 (permalink) |
| I also have a carputer project in pipeline. Hence was looking for a preamp with channel switching. switching is not an issue , preamp is as am not well versed with analog circuits. Preamp should enhance the bass response dhar can you post some pics of your ip-bus connector cable if you have on your pc.I had 1 failed attempt I should soon get PCB etched for Rod Elliots car pre-amp ckt . not sure if it will work good
| Thread Tools | |
Similar Threads | ||||
| A DIY Story: Home Audio Speaker Boxes in a Car??? Yes!!! | hotstuff | DIY - Do it yourself | 6 | 15th July 2009 21:06 |
| DIY blaupunkt Aux adapter | greenhorn | DIY - Do it yourself | 8 | 18th April 2009 23:51 |
| need help and advice - Car Audio install DIY | patkim | DIY - Do it yourself | 8 | 15th December 2008 20:52 |
| DIY Swift Audio Setup.with the help of some friends. | navpreet318 | Sound Off and Show Off | 76 | 13th January 2008 16:38 |
| Blaupunkt audio aux in problem? | merve_extreme | Ask the Gurus | 24 | 18th May 2006 00:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
