| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: May 2007 Location: Baroda
| Hi all, Here's a little guide to remove the door panel in your Indica. Although a very simple thing to do, it can be a daunting task the first time. It is best to watch someone do it before you try to DIY. But if you're careful, there should be no problems. BTW, just in case... a new door panel costs 1.4 K ![]() 1. ![]() Unscrew and remove the door handle 2. ![]() Remove the two screws shown and gently take out the little 'frame' by extending the lever as seen in the pic 3. ![]() Gently push a flat screw driver in between the panel and the window winder. Push it in the direction of the arrow in the pic to remove the retention clip. These pics should explain this better. ![]() ![]() 4. ![]() ![]() Gently remove this piece of plastic. The OVRM rubber handle can be squeezed through the hole. If it does not come off, gently pry between the panel and the plastic. Do not use too much force. remove the screw behind it. 5. (Pic taken from maximum size of speaker in Indica thread) Remove the OE Speaker Grill and the screw beneath it. 6. ![]() Lift up the rubber strip near the window glass and remove it gently. 7. ![]() (Rear panel shown) The panel is held by little connectors like these. They pop out with gentle pressure. The key is to use gentle pressure at the right spots. IMO its best to start from the Upper front corner near the OVRM adjuster. the first one is the most difficult, but the rest will come out easily. Put your fingers between the door and the panel and try to push them apart gently, it should release with a pop. ![]() Approximate locations of the 'connectors'. Putting it all back together. : Align the panel, apply pressure at all the points until you stop hearing 'pops'. For the window winder, place the retention clip back in its usual position and push it back into its place. Everything else is just about reversing the steps. Hope it helps.
__________________ And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker |
| | #3 (permalink) |
__________________ And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker Last edited by Rehaan : 23rd June 2008 at 00:32. Reason: No more "twenty twenty" please as it is against the rules. |
| | #5 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
Infractions: 0/1 (4) | Good show Aditya! Very helpful post. Should be helpful to ALL DIYers since some of the processes are common with other cars.
__________________ Operator! Give me the number for 911! |
| | #7 (permalink) | ||
| Quote:
The best thing to do would be to go to the service centre and watch someone do it. That way you'll learn it in a jiffy.
__________________ And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker | ||
| | #8 (permalink) | |
| Senior - BHPian | Aditya thanks for sharing this , however what was the reason for doing this? Quote:
__________________ Cheers rjstyles You never really learn to SWEAR until you learn to DRIVE. | |
| | #12 (permalink) |
| BHPian Join Date: Feb 2008 Location: Bangalore
| Its easier than Indica.I have removed couple of times.Smiler procedure like Indica. 1)Remove screws at A&B 2)Open lock at C 3)Remove winder knob (D) same as Indica. 4)Remove knob (E) 5)Remove rvm cover(?) (F) you have to pull right side and slide to left. After removing door latch screw (B) you have to take slide the assembly and takeout connecting rod. Pull the panel,there are about 6 locks from inside so little pressure is required. Hope this helps,if required i can post pics but only in the weekend. Last edited by mohang_j : 23rd June 2008 at 09:55. |
| Thread Tools | |
Similar Threads | ||||
| DIY Guide: How to repair a Tubeless tyre puncture! | iraghava | Tyre & Alloy wheel Section | 33 | 3rd October 2008 01:10 |
| Sound Damping on Indica front door | viper_711 | DIY - Do it yourself | 19 | 15th July 2008 23:13 |
| Swift: How do you remove the door panel | theEnd | Ask the Gurus | 14 | 25th January 2008 08:36 |
| door panels and dash | redsfx | Modifications & Accessories | 4 | 4th July 2007 07:57 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
- can I have a shot of the bare metal of the door as well
