Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 12th August 2008, 13:12   #1 (permalink)
Default need help in configuring and installing a car pc
hey i have a honda civic and i want to install a car pc in it.I saw the Iride technologies computer i somehow dont like the way the touchscreen looks and all so i am planning to configure my own computer and install some other touchscreen which looks good so i want u guys to help me out in this thing
my cpu will go below my front passenger seat and the touch screen will go into my dash
The things i want to use my car pc for are:
1.listen to songs
2.play videos and watch movies
3.internet browsing
4.GPS Receiver
5.OBD Scantool to connect to my engine
so could u please suggest me a good configuration for my computer and it would be better if u could give the price of the individual items and the place where i can get these in bangalore. I asked a guy about installing a car pc he said that the mother board has an onboard sound card and said something like the computer sound signal is a flat signal and the signal which the head units send to a speaker in a car are RC signals so he said that the quality of the sound might not be that good so could someone tell me what i can do regarding this like can i put a external sound card and will this solve the issue if yes which sound card should i put or else what can i do regarding this.I wanted to know which OBD Scantool to buy which is suitable for the honda civic and which gps reciver should i buy which can fit into my computer preferably a usb gps reciver and from whom should i buy the maps i am from bangalore so if u could give me the details regarding all the things i asked and a place in bangalore with the price of the items from where i can get these stuff it would be good
sandeeprao_86 is offline   Reply With Quote
Old 16th August 2008, 01:36   #2 (permalink)
DerAlte's Avatar
@sandeep, there are at least 2 other threads discussing this subject already. Please do take time to read those threads.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 16th August 2008, 11:08   #3 (permalink)
Thumbs up idea
look bro there are already two threads and i respect what mr DerAlte has to say. but here's an idea if you have about 1.5 to spend you could do this. i wanted to do this project but don have the funding. go to SP road and get the following...
1) ASUS M3 series motherboard for about 4k. has an onboard audio setup far better than most others along with major support for audio and video coz its an AMD-NVIDIA-ASUS motherboard.
2) AMD tricore for about 6k.
(these two are keeping in mind the nature of your usage AMD is far better with graphics and video and misuse)
3)2GB RAM ddr800 or 1066 for about 2k.
4) 360GB sata Seagate for 3k.
5) nvidia 8500 1gb for 5k.
7) cabinet smps and wire harnesses will be 1k.
next i was thinking instead of a head you can get this audiobahn ADD51T the link is here.. Audiobahn :: Accessories :: its the last one in the list so here you can connect everything. a touchscreen is given here which you can use as your front panel. all video connects half din audiobahn will take along with an optical in which the motherboard provides. so no need for a head. it also has 6 9v preouts which is more than enough for your amps.
the speakers can be deicded later
i was thinking of a 4 amp setup. 2 amps of two channel to manage front and back seperately. it is a dolby capable system you know. so you need two separate amps. then one amp for the sub. now your gonna be slightly short on the mid bass. so one amp will be a 4 channel. one channel will take pure bass in a 2ohm config for an 8 or 6 inch woofer and the other will power your center channel. it will be a lot of panelling work but this is one crazy *** system. in case you decide for some reason to not put on the system you can connect an i pod to it via the RCA. best o luck. i would love to see this setup i have PM you my number in case you wanna know more.
valhallen.282 is offline   Reply With Quote
Old 18th August 2008, 12:13   #4 (permalink)
gigy's Avatar
have a look at this config:
a touch screen of your choice
jetway motherboard NC62K-LF (Prior J6C2) from newegg.com
this board has dual display and dual audio support and blueray capable.
AMD 4850 processor from newegg.com
2gb ram ddr 800 or 1066
cabinet of your choice. from iride
dc-dc power supply 160w or 250w(recommended)
80gb sata hard disk
5.1 channel amplifier with speaker setup.
minikeyboard with touchpad.
pinnacle usb tv tuner with fm radio and video input for cameras.
__________________
ATR 72-212A; BNG737-700/800/900
Old 14th November 2008, 12:45   #5 (permalink)
ST7677's Avatar
Does any one know which OBD interface is there on Civic? I guess it should be ISO 9141 protocol. Can someone confirm?
ST7677 is offline   Reply With Quote
Old 16th November 2008, 15:40   #6 (permalink)
nc1bad's Avatar
Default odb
hey i have the OBD ELM 327 multiprotocol scanner, it works fine with it.
__________________
3.0 Safari Dicor
1.8 V AT Civic
1.5 OHC
1.6 Corsa Royale
nc1bad is offline   Reply With Quote
Thread Tools
Installing Sub and HU in INNOVA sirilvasudev Ask the Gurus 2 24th August 2008 18:01
HELP-Configuring Limewire in a Proxy environment esteem_lover Gadgets, Computers & Software 0 27th May 2008 18:28
Installing Springs Riki Technical Stuff 0 19th May 2008 15:24
need help configuring my ICE rider60 Ask the Gurus 31 2nd January 2008 23:12
HELP - configuring email on Nokia 7610. normally_crazy Gadgets, Computers & Software 6 4th August 2005 19:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489
