Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
Thread Tools
Old 1st December 2008, 16:19   #1 (permalink)
Default need help and advice - Car Audio install DIY
With basic knowledge of electronics, computers and eletricals and familiarity with general DIY activities related to Computers assembly etc, is it possible to install, setup car audio system by own. I am interested in install the audio system and connect two front speakers.
I am beginner here. I tried to search the net but looks like could not get much info on this topic. Any suggestions or advice would be great.
Thanks,
patkim is offline   Reply With Quote
Old 1st December 2008, 18:34   #2 (permalink)
gigy's Avatar
you must also know your car. paneling, wiring, safety. for initializing yourself into this i would recommend you associate with some of the gurus and see how basic setup can be done. later on you can sit and improve upon it.
Old 1st December 2008, 18:36   #3 (permalink)
abhinav.gupta88's Avatar
What all are you adding.
From the thing i could make out , its a Head Unit and a pair of Front Speakers.
What ride are you looking to play it in.
Also if going for only front , i would advice you to use some components than the regular co-axs
__________________
vRs(q)® | ECLIPSE CD7200 MKII | Illusion Carbon ND-6 | Harman/Kardon CA470 | Harman/Kardon CA1500M | Stereo Integrity MAG D2 V4
abhinav.gupta88 is online now   Reply With Quote
Old 1st December 2008, 18:39   #4 (permalink)
ramie2400's Avatar
Juat pay a Rs.150 labour to the installer,when he starts the work ask him i want to do it myself and he will guide you thru the process and you will come to know your car better in opening and fixing it properly without damaging the console panels
__________________
___________
Old 1st December 2008, 19:00   #5 (permalink)
greenhorn's Avatar
thats what i did myself. go to a good installer - heavy emphasis on good - when you learn, you learn it right. most local installers would rather use some easy jugaad than do something right . watch the master work, and you'll figure out what needs to be done next time
__________________
'07 Indica DLG - Almost a DLX
Old 7th December 2008, 00:27   #6 (permalink)
Thanks for your response. I realize that even apart from electrical aspects this will be a bit tedious job with small space inside Alto. Even when I just opened the portion of dashboard to see the wiring harness or even the front speaker grill, I could not easily look inside!
Anyways I guess I will get it done from some professional and will just watch how he does it.
I am thinking of Sony CDX GT270S as HU & speakers in front and back. So would be great if you can suggest some suitable speakers or even if you have any comments on this HU. As such I am not looking for much expensive systems.
Old 12th December 2008, 13:02   #7 (permalink)
The palio comes with wiring for speakers. Are all cars provided with wiring for 4 speakers?
If thats the case, DIY would be much simpler. Else wee need some custom tools. To start with I know that I should disconnect the negative battery terminal
ritz830 is offline   Reply With Quote
Old 12th December 2008, 16:04   #8 (permalink)
thirst4torque's Avatar
No, not all cars come with wiring for speakers. Even if they do, the stock wiring is not of great quality.
__________________
Regular naps prevent old age, especially if you take them while driving.
thirst4torque is offline   Reply With Quote
Old 15th December 2008, 20:52   #9 (permalink)
Just wish to know what’s the wrench size, typically used for loosening the car battery terminals nut-bolt. I just plan to have one..just in case I am not going to use the car for longer period, then can disconnect the battery.
Thx.
Thread Tools
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi Ask the Gurus 9768 22nd November 2009 13:26
A DIY Story: Home Audio Speaker Boxes in a Car??? Yes!!! hotstuff DIY - Do it yourself 6 15th July 2009 21:06
Diy Car Audio Preamplifier for Aux-in _abhay_ DIY - Do it yourself 8 1st June 2008 13:31
Need some Advice on my Car Audio satishri Ask the Gurus 11 15th February 2006 09:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
