Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 9th December 2008, 16:24   #16
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by Tejas@perioimpl View Post
It was very easy to open the console. Only four to six screws in the speedo console if i remember well and no soldering, just push the bulbs in the sockets.
I'll post pics over the weekends with positions of the screws.
The lights where a little too bright at night and i had to take a black marker and put spots on the bulbs to dim them. I think, i'll change the bulbs again and try to attach a dimmer so in the late evenings they can be full intensity and i can reduce them to min in darkness.
That'll be very helpful since I plan to do a DIY for this myself. What bulbs were used? And how many?
Old 9th December 2008, 16:29   #17
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
I frankly don't remember the amount of bulbs. had done it 2 years ago when i wanted the orange BMW look. I think 6 in the speedo. I'll reopen and check. Hardly takes 10-15 minutes. Over the weekend though..
the bulbs were regular dashboard bulbs used in the orange lights of the NHC.
I think costs around Rs.3 per bulb
Tejas@perioimpl is offline   Reply With Quote
Old 9th December 2008, 16:37   #18
anujmishra's Avatar
Thanked: 345 Times
Nice work badboyscad, it is tempting me to change lights of my 800 from dull green to white or orange.
Could you tell me where I get orange or white LED? Would White LED will give sufficient illumination to the speedo?
Blue LED's has very good illumination but I like Orange or White.
anujmishra is offline   Reply With Quote
Old 9th December 2008, 17:39   #19
benbsb29's Avatar
Thanked: 4,281 Times
Excellent work once again, BBCad! Seeing you so successful at this, really makes me wanna go and try out this on my car.
Between, i didnt know the Scorpio came with a frontlit display for the speedo console.
benbsb29 is online now   Reply With Quote
Old 9th December 2008, 19:06   #20
badboyscad's Avatar
Thanked: 172 Times
i think the speedo light change process might be VERY similar for the ford ikon too because the speedo unit of the 2003 scorpio was also made by ford. it has ford logo embedded in some places.
badboyscad is online now   Reply With Quote
Old 9th December 2008, 19:39   #21
benbsb29's Avatar
Again, thats news for me! How much we get to learn daily.
Between the process is quite similar. Here's an attempt by bugboy.
Ford_Ikon
Old 9th December 2008, 21:42   #22
Thanked: 41 Times
kool.. hope you change the lights on all the cars and help changing other on their car.
anyways all the best in advance for next car's DIY
monty9991 is offline   Reply With Quote
Old 9th December 2008, 21:51   #23
badboyscad's Avatar
Thanked: 172 Times
hi, decided to try and make the whole instrument cluster blue.i ve started with the switches.
The A/C switch:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-09122008457.jpg
Stock bulb(in the twist lock holder) with green cap removed from the switch:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-09122008458.jpg
The twist lock holder without the bulb:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-09122008459.jpg
Same process(as for the speedo) was repeated to fit the LEDs to the holders and voila.!
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-09122008460.jpg
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-09122008464.jpg
Will continue to change remaining green lights to blue.
Old 9th December 2008, 23:00   #24
SYJ
SYJ's Avatar
Thanked: 35 Times
Man! that looks awesome, will have to try this on my scorpio sometime!!!
SYJ is offline   Reply With Quote
Old 10th December 2008, 08:46   #25
getsurya's Avatar
Thanked: 967 Times
bbs, once you change all the interior lights, show them to M&M guys and tell them that they can customize the lighting to customer's liking and car's color!!
Good job done!!
getsurya is offline   Reply With Quote
Old 11th December 2008, 02:01   #26
badboyscad's Avatar
Thanked: 172 Times
Update:
i tried to remove the A/C control console but ended up unsuccessful. the A/C console is fixed from the inside such that you cant pull it out, instead you have to remove the dashboard itself to remove the console. Moreover the A/C control console is partially mechanical(cables are connected to the center rotary control, so i didnt want to mess with it.
red circles are where the screws go in.
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-11.jpg
Then i found out that one of the rear numberplate lights was not working so decided to turn them blue.
The numberplate light:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-22.jpg
The holder unit (notice the amount of oily dust):
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-33.jpg
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-44.jpg
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-55.jpg
Cleaned with paint thinner:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-66.jpg
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-77.jpg
The LED fixing procedure was the same as in the alto(note: i covered the numberplate with a piece of tissue paper):
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-11122008475.jpg
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-11122008476.jpg
Old 11th December 2008, 14:43   #27
ankitahuja's Avatar
Thanked: 46 Times
BBS that's a lot of DIY
You name should read bluebadboyscad!
@Tejas: Eagerly waiting for the OHC DIY pictures, hopefully very early Saturday since I really want to do this. Does anyone know where can I get the LED/bulbs in Delhi? (bright ones)
Old 11th December 2008, 15:04   #28
i will try to click pictures tonight itself.
Don't get bright ones, i had installed them and they really interfere with night driving and gets very distracting. i had to darken mine with a black marker.
Use the orange ones used in the NHC.
I'm planning to change to white lights now. what say should i? or stick to the orange?
Old 11th December 2008, 20:44   #29
ankitahuja's Avatar
Thanked: 46 Times
Definately white, that's exactly what I plan to do as well. A tinge of blue/red should be nice and add a bit colour.
Since you say there are 6 bulbs used, maybe we can mix like 5 white bulbs and 1 blue bulb at a certain location, which makes it look cool
Sorry BBS for hijacking this thread.
Old 11th December 2008, 21:17   #30
so did you try it in the center console as well?
fatherlover is offline   Reply With Quote
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 29 21st March 2018 17:36
Dashboard / Instrument Cluster Warning Lights - What Each Symbol Means! sumathindra Technical Stuff 31 20th April 2017 06:00
Used Parts (Instrument cluster- dials) ..? gary_yuen42 Modifications & Accessories 38 9th April 2014 13:31
can the colour of the in dash instrument cluster lights be changed??? mclaren1885 Modifications & Accessories 23 22nd August 2009 16:04
Instrument cluster light change nikibusa Motorbikes 7 10th September 2005 09:26
