Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 9th December 2008, 00:28   #1
badboyscad's Avatar
Thanked: 172 Times
Default DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)
I did a quickie DIY this evening. This DIY is relatively much easier than that of the alto.
Components:
2 5mm blue LED's
2 470 Ohms resistors
Tools used:
Soldering iron
file & blade
cutter
Unscrew the screws found in the places marked by the blue circles to open the bottom panel and the screw found in the place marked by red circle to remove the upper panel(which covers the speedometer console):
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-2.jpg
Unscrew the screws found in the places marked by red circles to remove the speedometer console. Blue circles are the twist-lock bulb holders with stock bulbs.
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-1.jpg
The part marked by blue is a box which holds the bulbs, push it upwards and pull to remove it.
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-08122008403.jpg
This pic shows the top view of the box. remove the paper circuit(blue thingy) before removing the box.
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-08122008400.jpg
The box, removed:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-08122008405.jpg
Inside facing side of the box (notice the transparent green plastic thingy):
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-08122008409.jpg
Box disassembled:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-3.jpg
Box reassembled without the green plastic thingy:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-4.jpg
The LED (filed to lose its glossiness) soldered with the resistor and inserted into the twist-lock holder:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-08122008440.jpg
The box(with LEDs) fixed to the console and the result is a Cool Blue speedometer:
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-08122008443.jpg
Will post more pics tomorrow.
badboyscad is offline   (1) Thanks Reply With Quote
Old 9th December 2008, 00:38   #2
Tejas@perioimpl's Avatar
Thanked: 5,475 Times
Nice. You should also change lights in the centre console to blue to give it a uniform look.
Tejas@perioimpl is offline   Reply With Quote
Old 9th December 2008, 00:38   #3
white_vdi's Avatar
Thanked: 18 Times
great job bbs!!!
looks real nice in the last pic. intensity of blue is uniform.
white_vdi is offline   Reply With Quote
Old 9th December 2008, 00:45   #4
badboyscad's Avatar
Thanked: 172 Times
Will try that tomorrow.
Originally Posted by white_vdi View Post
great job bbs!!!
Here, the intensity of blue is uniform because light is projected from the front onto the whole dial of the speedometer (unlike from behind, in the alto).
badboyscad is offline   Reply With Quote
Old 9th December 2008, 00:49   #5
white_vdi's Avatar
Thanked: 18 Times
and why do you file the LED before installation?
Old 9th December 2008, 01:16   #6
badboyscad's Avatar
Thanked: 172 Times
These are projector LEDs, normally(without filing) they emit only a beam of light in a straight line. When filed, they lose their projector characteristic and emit light in all directions like normal filament bulb.
PS: the idea of filing the LED was given by souljah. thanks to him, again.
Old 9th December 2008, 10:04   #7
live2drive's Avatar
Thanked: 25 Times
Nice DIY. Worth giving a try.
Speedo-console looks sporty now.
Great effort badboyscad!
live2drive is offline   Reply With Quote
Old 9th December 2008, 10:24   #8
getsurya's Avatar
Thanked: 967 Times
bbs, You are now declared as an 'inhouse DIY speedometer lighting expert'. Good job on this too. Blue speedo will go well with your car colour too! Have fun!!
getsurya is offline   Reply With Quote
Old 9th December 2008, 14:37   #9
razor4077's Avatar
Thanked: 258 Times
Nice work BBS. Tell me one thing - what colour is the original LED (or is it just a regular bulb)? If I remove just the green filter, what colour will the console light be? White?
razor4077 is offline   Reply With Quote
Old 9th December 2008, 14:59   #10
badboyscad's Avatar
Thanked: 172 Times
The stock bulb (not LED) is just a normal filament one which emits yellow light. If you remove the green filter alone, then you ll get very bright yellow light.
Old 9th December 2008, 15:40   #11
badboyscad's Avatar
Thanked: 172 Times
This is the stock lamp. It is used both in speedometer and parking lamp slots.
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen)-blb.jpg
Old 9th December 2008, 15:44   #12
so did you try it in the center console as well? it'll look good. I had once changed my OHC lights to orange in the speedo console and left the car center console yellow and it looked weird till i changed all lights to orange, even the ones in the power window buttons. Seriously give it a try.
Old 9th December 2008, 16:09   #13
ankitahuja's Avatar
Thanked: 46 Times
BBS: Good job, waiting for your DIY on the OHC now
Tejas, can you please post pics of the changed lights. Also, if you could give some details on the bulbs, how easy was it to open the console etc.
Old 9th December 2008, 16:15   #14
deadguy25's Avatar
Thanked: 42 Times
Awesome job BBS. Looks cool.
deadguy25 is offline   Reply With Quote
Old 9th December 2008, 16:16   #15
It was very easy to open the console. Only four to six screws in the speedo console if i remember well and no soldering, just push the bulbs in the sockets.
I'll post pics over the weekends with positions of the screws.
The lights where a little too bright at night and i had to take a black marker and put spots on the bulbs to dim them. I think, i'll change the bulbs again and try to attach a dimmer so in the late evenings they can be full intensity and i can reduce them to min in darkness.
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 29 21st March 2018 17:36
Dashboard / Instrument Cluster Warning Lights - What Each Symbol Means! sumathindra Technical Stuff 31 20th April 2017 06:00
Used Parts (Instrument cluster- dials) ..? gary_yuen42 Modifications & Accessories 38 9th April 2014 13:31
can the colour of the in dash instrument cluster lights be changed??? mclaren1885 Modifications & Accessories 23 22nd August 2009 16:04
Instrument cluster light change nikibusa Motorbikes 7 10th September 2005 09:26
