Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 18th May 2009, 19:12   #181
gopinathann's Avatar
Thanked: 20 Times
I want to know whether I am doing is right or wrong. I first created a 3 White LED setup with 142 ohm resistor. I am going to do similar kind of sets like 5 rows or 10 rows of 3 LEDs each. Should I use 142 ohm for each row or is it going to be different ?
Also I want to create these kind of LED setup using AC power. Instead of using AC-DC adapter is there any kind of small transformer which I can connect to it.
gopinathann is offline   Reply With Quote
Old 18th May 2009, 19:34   #182
badboyscad's Avatar
Thanked: 172 Times
Buy a 220v to 12 v transformer(should cost around Rs:30) and add a bridge rectifier circuit to get 12 to 14 DC.
Below is a pic of the transformer with the bridge rectifier circuit.
The green wires are input(220v AC), the purple wires are output(12v AC) and the bridge rectifier rectifies the 12v AC to 12v DC.
Benny's first DIY : LEDs on an Ikon-18052009912.jpg
Bridge rectifier schematic:
Diodes - 1N4001 (4nos)
Electrolytic capacitor- 1000mf/35 or 40volts (1 no[s])
Pic source:XCircuit Schematic Capture Tutorial Page
badboyscad is online now   Reply With Quote
Old 19th May 2009, 14:54   #183
Thanked: 20 Times
Thanks BBS, I will try this out.
Any idea about my other question, setting up 10 Rows of LEDs. The LED calculator says 14 ohms 8 Watt. Should I use 14 ohms for each row of 3 LEDs ?
Old 19th May 2009, 15:56   #184
greenhorn's Avatar
Thanked: 1,516 Times
gopinathann, that circuit is exactly the same as what is used in adaptors. so if you find it hard to make/get an adapter cheaper, stick with the adaptor
the resistance value seems strange. I'd say 150 ohm resistor in series with 3 LED's in series, and wire 10 of these in parallel
Old 19th May 2009, 16:35   #185
Thanked: 20 Times
Your comment seems to be correct. For the following circuit 150 ohms is the correct value, however I am not sure how other calculator gives those strange values.
Input Voltage : 13
Forward Current: 3.3
Desired Current: 25 mA
Old 19th May 2009, 16:44   #186
greenhorn's Avatar
if this lamp will be run mostly on battery (~12V) and for short durations, you can use 100 ohms
On the other hand , if this is going to be used with the engine on (14.4V) , and a lot of the time , try going even higher, say 180/220 ohms - My numberplate lights have begun to die out - and this is the 2nd time in 4 months, so am planning to increase the resistance to 220.
Am sick and have been advised bed rest, + my soldering iron is dead, So my plans will be on hold for a while :(
Old 19th May 2009, 17:05   #187
abhijeetsng's Avatar
Thanked: 142 Times
Good work. It all worth the effort made!
Cheers!
abhijeetsng is offline   Reply With Quote
Old 22nd May 2009, 07:46   #188
srikant's Avatar
Thanked: 9 Times
the resistor is kinda like a fuse. it limits the current through the LED's. without it , the LED's will be using up a LOT more current (without much increase in brightness) , and they'll die out soon.
Thanks Greenhorn, I ll change the setup soon and add the resistor. What value of resistor should for my present setup?
Originally Posted by ghpk View Post
Using the short glass LED (which are used in china made torches these days) will help attain more illumination.
What are these LEDs called? how much do they cost?
BTW, here is the pic of the same
Benny's first DIY : LEDs on an Ikon-dscn1048.jpg
Uh Oh, take care greenhorn, hope you recover soon.
and you appear online on TBHP early morning??
Thats a perfect TBHP Mania
srikant is offline   Reply With Quote
Old 22nd May 2009, 08:16   #189
greenhorn's Avatar
srikant, add a 100 ohm resistor in series with each row of 3 led's , and then put them in parallel, like in gopinathann's pic above
Old 22nd May 2009, 11:54   #190
rahulya007's Avatar
Thanked: 35 Times
I tried putting 3 LED's in series with a 100 ohms resistor for the boot lamp and tested the circuit on a 5V adapter. The LED's would not glow but the same setup if made parallel would emit very good light...
Is it something that the current being 5V is inadequate for the 3 LED's in series since I guess each LED's takes around 3-3.5 V. However i have not tried this on a 12V setup.
I am doing the setup tonite by soldering the LED's on a PCB. Any reply before that would be really helpful..Anyways..i am thinking of trying out the same (series) setup on a 12V source..
Rahul.
rahulya007 is offline   Reply With Quote
Old 22nd May 2009, 12:05   #191
greenhorn's Avatar
rahul, you're thinking along the right lines
if you have one of them breadboards, try it out on that before soldering
and make sure you get the polarity right while soldering the LED's
Old 22nd May 2009, 14:14   #192
ghpk's Avatar
Thanked: 193 Times
Originally Posted by rahulya007 View Post
Rahul.
3 L.E.D. in series with a 100ohm or 150ohm resistor would work fine on a 12v source and not on 5volts.
Old 22nd May 2009, 15:31   #193
Thanked: 20 Times
I am surprised to see that the White LED doesn't glow on a 1.5 v battery but the normal bulb glows. Atleast the LED should show some light when connected to a battery. I have a torch which has 6 LEDs and runs on a single battery.
Old 22nd May 2009, 16:45   #194
greenhorn's Avatar
the torches have LED Driver IC's inside which step up the voltage. We dont have that luxury
Old 22nd May 2009, 17:36   #195
Thanked: 20 Times
I have a transparent LCD clock which runs on single AAA battery. I want to use the same battery to throw some light on it in the night. Which LED should I use for this ?
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Using leftover DRL LEDs for Home Lighting! Grr7 DIY - Do it yourself 12 17th June 2015 14:26
Skoda Octavia Angel Eyes and LEDs abhinav.gupta88 Modifications & Accessories 80 20th October 2014 16:09
Experiment! Replacing conventional headlights bulbs with LEDS! frankmehta Modifications & Accessories 18 8th December 2010 14:56
Quality Super Bright LEDs, where can I find them ? s0uljah Modifications & Accessories 20 20th February 2009 17:20
