Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 28th July 2009, 15:11   #226
gopinathann's Avatar
Thanked: 20 Times
Default White LED for SX4 Cabin Light
Today I added 30 (3x10 rows) LEDs, however 3 rows of LEDs didn't work. First only 1 row was not working, trying to fix that created problem for the other 2 rows. I checked the connection and could not find out what the problem could be. I have tested all the LEDs before soldering.
Benny's first DIY : LEDs on an Ikon-200907281307_248.jpg
Benny's first DIY : LEDs on an Ikon-200907281307_250.jpg
Benny's first DIY : LEDs on an Ikon-200907281307_252.jpg
Benny's first DIY : LEDs on an Ikon-200907281322_254.jpg
gopinathann is offline   Reply With Quote
Old 28th July 2009, 15:38   #227
abhijeetsng's Avatar
Thanked: 142 Times
Exclamation
Hello people,
Can anyone here give a step by step guide on how to set this led thing up. I have a santro, really want to do this thing in my car on my own. But, I have absolutely no idea how to go about it.
Please help!
Abhi
abhijeetsng is offline   Reply With Quote
Old 28th July 2009, 15:52   #228
greenhorn's Avatar
Thanked: 1,519 Times
1. find out an electronics spares shop
2. things you'll need -
a) soldering iron
b) solder
c) snipper ( to cut off leads) or any equivivalent tool
d) dot PCB
e) white LED's
f) 100 Ohm resistors.
3) solder them according to the circuits you see us discussing in this page
Old 28th July 2009, 16:01   #229
benbsb29's Avatar
Thanked: 4,281 Times
@Gopinathann : Is it possible that in the process of your experiment, you managed to short one of those circuits? Just wondering. Replace one of those non-working branches with new LEDs and check if they glow.
Old 28th July 2009, 16:22   #230
Thanked: 142 Times
a) soldering iron
b) solder
d) dot PCB
e) white LED's
Thanks greenhorn,
Will surely follow up on circuts and do it on my car.
Thanks again,
Abhi
Old 28th July 2009, 16:37   #231
Thanked: 20 Times
Could be the problem, I will check that. Thanks.
Old 3rd August 2009, 22:03   #232
Thanked: 20 Times
Default Blue LED strip for SX4 number plate
Added blue LED strip for the number plate. Looks bright in the night.
Benny's first DIY : LEDs on an Ikon-dsc06279-large.jpg
Benny's first DIY : LEDs on an Ikon-dsc06281-large.jpg
Old 4th August 2009, 00:33   #233
shyamhegde's Avatar
a) soldering iron
b) solder
d) dot PCB
e) white LED's
Also a simple digital multimeter will be handy .
I use a 'nail cutter' to cut the leads off, instead of snipper/cutter etc. Works well.
shyamhegde is offline   Reply With Quote
Old 4th August 2009, 23:19   #234
Jaguar's Avatar
Thanked: 151 Times
+1 to that. The slight current from the multimeter is enough to produce a faint glow to identify the colour of the LED (If you have mixed the different colour LEDs together)
Jaguar is online now   Reply With Quote
Old 4th August 2009, 23:22   #235
greenhorn's Avatar
from my experience with my DMM ( 'UNITY' brand), this works with only red and green. not too sure about white and blue, since their threshold voltages are higher
Old 5th August 2009, 08:52   #236
archat68's Avatar
Thanked: 290 Times
Yes , DMM will not work with blue and white LEDs.
If you are people are into DIY - build a variable power supply - those using LM317 - very useful.
If you can't build one - you can get a variable voltage mains adapter from market - it has output from 1.5V to 12V in steps of 1.5V. Should not cost you more than 150 bucks IMO. Try local repair shop - if they don't stock, ask them to procure one from market.
Or else you can get the kit from here (they are costly IMO):
[Aplus] Tiny 1.2 - 30V Regulated Power Supply - Lynx Chandigarh Largest Electronic & Computer Online Superstore In India
archat68 is offline   Reply With Quote
Old 5th August 2009, 10:15   #237
greenhorn's Avatar
You really dont need to build any adapter actually, Any DC source like a mobile charger/modem/router adapter etc can be used along with an appropriate value resistor
Old 5th August 2009, 11:56   #238
benbsb29's Avatar
Guys, what do you use to cut the dotted circuit boards? I bought a few to use, but trying to cut them to size has left me flumoxxed. i was thinking of getting an axe-saw blade for the same. Hope that works.
Old 5th August 2009, 12:06   #239
archat68's Avatar
Thanked: 290 Times
Yes that can be done. A mobile charger which has 5v output can be converted to 3.5V by adding two forward biased silicon diodes in series like 1N4001/4007 (two silicon diodes in series with create a voltage drop of 1.4V). Current output will be limited to 1 Amp. IMO this is better than resistors.
Use a small hacksaw. A small one with blade and handle can be obtained from hardware stores. Get one with fine teeth - tell them it will be used to cut aluminum channel. You can get one for around 50 bucks.
Old 5th August 2009, 12:11   #240
greenhorn's Avatar
I just make two cuts at both sides of the dot PCB where i need it to break, and then break along the dotted line, exerting pressure with my thumbs at the region near the cuts
file the sides by rubbing on a concrete wall if required
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Using leftover DRL LEDs for Home Lighting! Grr7 DIY - Do it yourself 12 17th June 2015 14:26
Skoda Octavia Angel Eyes and LEDs abhinav.gupta88 Modifications & Accessories 80 20th October 2014 16:09
Experiment! Replacing conventional headlights bulbs with LEDS! frankmehta Modifications & Accessories 18 8th December 2010 14:56
Quality Super Bright LEDs, where can I find them ? s0uljah Modifications & Accessories 20 20th February 2009 17:20
