Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 5th August 2009, 13:46   #241
gopinathann's Avatar
Thanked: 20 Times
Originally Posted by greenhorn View Post
I just make two cuts at both sides of the dot PCB where i need it to break, and then break along the dotted line, exerting pressure with my thumbs at the region near the cuts
file the sides by rubbing on a concrete wall if required
You can use a scale and Knife to mark it twice with some pressure and then break it, it comes out easily.
Sometimes I mix the LEDs, to find out the color I use a 3V button battery to quickly sort and test them before fixing it in the circuit board. It works for Blue and white LEDs also.
gopinathann is offline   Reply With Quote
Old 5th August 2009, 13:47   #242
Thanked: 20 Times
@Gopinathann : Is it possible that in the process of your experiment, you managed to short one of those circuits? Just wondering. Replace one of those non-working branches with new LEDs and check if they glow.
Planning to fix it this week.
Old 5th August 2009, 13:50   #243
benbsb29's Avatar
Thanked: 4,281 Times
Smart, i also thought of the same modus operandi. The question once again being, with what do you make the cuts? :P
Old 5th August 2009, 14:03   #244
greenhorn's Avatar
Thanked: 1,519 Times
I use the wire snipper (same thing used to cut leads)
Old 5th August 2009, 21:35   #245
Thanked: 20 Times
Though I thought there was a short citcuit which could have burnt the LED , I tested each LED and all are working. It seems there was a loose connection which I have fixed it. Now all the 10 rows are working
Old 7th August 2009, 08:14   #246
benbsb29's Avatar
Thanks to the person who suggested using a nail cutter to snip off the leads. It works perfectly!
For cutting the PCBs, i use a plyer. I apply pressure at one point of the board, and then break the circuit board accordingly. Thankfully, didnt need to get myself a hacksaw blade. Am in the proces of making a PCB set up for the cabin light using white LEDs, replacing the makeshift arrangement i made last time using cardboard and blue LEDs, which arent really practical.
@gopinathann : What is the resistor value you have used on each of the branches?
Old 7th August 2009, 09:21   #247
archat68's Avatar
Thanked: 290 Times
If you are into DIY - try to invest in some tools - like a mini hacksaw, a good wire snipper, a good soldering iron, a good plier, a file, a multimeter etc.. Each of them except the soldering iron and the multimeter will cost you around 50 bucks and will come to use in long term. Once you get these things- you will thank yourself in future. I was also using jugad in my early days instead of proper tools - but once you get proper tools the job becomes very easy.
archat68 is offline   Reply With Quote
Old 7th August 2009, 10:31   #248
greenhorn's Avatar
and learn proper solder application and removal while you are at it. Any electronics assembly will become a piece of cake
Old 7th August 2009, 10:50   #249
shyamhegde's Avatar
Agree with you. Proper tools allow you to complete the project the same day you started it. Otherwise, lot of time is wasted doing jugaad.
I use nailcutter to cut the leads of components after soldering on the PCB not because to save on snipper/cutter, but it reaches all the places without much effort compared to the cutters. Especially while making LED clusters.
shyamhegde is offline   Reply With Quote
Old 7th August 2009, 12:30   #250
archat68's Avatar
Thanked: 290 Times
+1
Soldering is the most critical part of any DIY. Most DIY projects fails for the newbie just because of poor soldering.
Get a piece or two of veroboard and practice soldering with it -Most people don't apply enough heat for the fear that excess heat will kill the components. The trick is to use right amount of heat for right duration of time. When you do it good - the result should be a shiny, smooth solder.
Also use desoldering wicks (braided wire coated with resin) for desoldering - they work best - far better than desoldering pumps.
For cutting copper tracks of veroboards with parallel tracks use a small drill bit. It cuts off the tracks neatly.
Actually a nail cutter and a wire snipper costs same - around 30-40 bucks - so there is no saving. But the problem with the wire snipper is that it is available only in the specialized hardware shops whereas nail cutter you can get anywhere.
Old 7th August 2009, 12:43   #251
greenhorn's Avatar
I use an old soldering iron (which i got in my second year of college). Its tip is worn hollow with use and sucks up solder then shake it to remove the solder!
Old 7th August 2009, 13:11   #252
archat68's Avatar
Thanked: 290 Times
Nice trick .
BTW not trying to steal the thread - but if anybody is into serious DIY - you can look into this thread:
http://www.team-bhp.com/forum/modifications-accessories/25692-diy-microcontroller-based-digital-tachometer.html
Old 9th August 2009, 20:48   #253
Thanked: 20 Times
I did a LED strip this weekend for a testing purpose and it has come well. This can be used for home lighting or for car lighting.
I bought a wall fitting (used to hide wires in the wall) available in hardware store (Rs. 17 for 6 feet). I cut it for a 2 feet length marked with equal space and put holes in that. Then placed 12 LEDs (white & blue with 100 ohms resistor) so that only a portion is seen out. Solder the wires and connect it to 12V adapter to test it.
This can be used as a water proof LED light for car underbody or for number plate light.
Benny's first DIY : LEDs on an Ikon-l1.jpg
Benny's first DIY : LEDs on an Ikon-l2.jpg
Benny's first DIY : LEDs on an Ikon-l3.jpg
Benny's first DIY : LEDs on an Ikon-l4-large.jpg
Old 9th August 2009, 21:02   #254
archat68's Avatar
Thanked: 290 Times
Nice. Came out very well.
For waterproofing you can try using clear acrylic tubes (can be sourced from aquarium shops) - make a hole on one side of the tube - insert the LEDs and then fill the hole with silicone adhesive (available with the aquarium shops for 100 -150 bucks) or hot glue. Also fill the end holes with silicon adhesive or white M-seal. The LED leads after required connection can also be covered with silicone adhesive - this will make a 100% water proof assembly.
Old 10th August 2009, 10:08   #255
Thanked: 20 Times
Thanks for sharing it. I have already used M-seal in my Numberplate light to prevent water. Next I am trying to create flexible LED strips.
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Using leftover DRL LEDs for Home Lighting! Grr7 DIY - Do it yourself 12 17th June 2015 14:26
Skoda Octavia Angel Eyes and LEDs abhinav.gupta88 Modifications & Accessories 80 20th October 2014 16:09
Experiment! Replacing conventional headlights bulbs with LEDS! frankmehta Modifications & Accessories 18 8th December 2010 14:56
Quality Super Bright LEDs, where can I find them ? s0uljah Modifications & Accessories 20 20th February 2009 17:20
