Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 17th December 2008, 09:10   #31
Vid6639's Avatar
Thanked: 21,086 Times
3 blue LED's means 3*3.7V which is approximately 11.1V. The car provides 12V to the bulbs.
I'm not sure how much current these can handle. You may need the current limiting resistor.
Old 17th December 2008, 11:07   #32
benbsb29's Avatar
Thanked: 4,281 Times
Originally Posted by Rocky_Balboa View Post
Benny,
Nice job man, are you not thinking of disco lights for headlamps?
Rocky.
Nopes, thats not even an option.
Originally Posted by Bluu View Post
You've forgotten to mention an important step, Ben:
How does one go about convincing one's wife that a blue light in the car is a cool thing?
Get her to watch FnF.
Originally Posted by hellstar View Post
benny boy thats a very nice DIY, one question here last time i tried something like this the lights heated up too much on leaving the cabin light on for a couple of minutes . How is you setup doing with respect to the heat ?
Would LEDs generate so much of heat? I doubt it. Someone please correct me, if wrong. I havent left the cabin light on for long durations, as i have the switch placed at the door open position.
I was advised to use a limiting resistor, but decided to just try it out this way. Lemme see.
Been really busy with work that it leaves little time to fiddle with this for the time being.
Old 17th December 2008, 11:32   #33
badboyscad's Avatar
Thanked: 172 Times
Yes they can produce heat before burning off. That is exactly why i keep stressing to use a resistor.
Please dont do LED circuits without resistors because by getting the LEDs over nominal current you make them overheat and rob them their extraordinarily long lives. A 20mA LED working at 50mA will be giving out slightly below double its normal light emission (the overheating makes it far less efficient), but it will only live between 100 and 500 hours (4 to 20 days), contrary to its theoretical mean life of 50,000 hours (5.7years).
badboyscad is online now   Reply With Quote
Old 17th December 2008, 12:36   #34
WhiteKnight's Avatar
Thanked: 76 Times
Just curious. How would you connect the resistor? Parallel to the LEDs or in series?
WhiteKnight is offline   Reply With Quote
Old 17th December 2008, 12:42   #35
badboyscad's Avatar
Thanked: 172 Times
i connected the resistor in series with the LEDs(in my DIYs). But parallel connection can also be done.
Old 17th December 2008, 12:44   #36
benbsb29's Avatar
Now that badboyscad has spoken with reason, i will do accordingly.
The other problem for me is that in order to buy a resistor of a different rating, i will need to go all the way to SP Road.
OT : Do any of the Bangy guys know a place which sells these electronic items near Marathalli?
Old 17th December 2008, 14:03   #37
Thanked: 76 Times
Folks, it is a bit more complex than that.
First of all you need to connect a resistor in series to the LEDs. Job of the resistor is obviously to bring down the current to the optimum operating current rating for the LED.
For any electrical circuit, OHM's low is applicable, which says
I = V/R
where I is current, V is potential in Volts and R is resistance.
Unfortunately, in a LED, the rule doesn't apply, and LEDs doesn't seem to offer any real resistance. So, bottomline is, any variation in Voltage could bring an exponential variation is current (unlike Ohm's law) if LED alone is connected across the potential. In Car batteries, Voltage does vary.
Here is a good source to calculate the Ohms for the resistor.
Old 17th December 2008, 14:29   #38
shyamhegde's Avatar
You mean a resistor parallel to LED ?
shyamhegde is offline   Reply With Quote
Old 17th December 2008, 15:36   #39
gigy's Avatar
Thanked: 41 Times
best way to connect is a resistor for each led in series to it and put them together for maximum life. going series with all leds powered by a single resistor is not recommended by experts, but i know it makes the whole thing whole complex. did you keep the lights on for sometime with the engine running, quite possible they will fail in a day or two. my experience.
Old 17th December 2008, 16:03   #40
benbsb29's Avatar
Nopes, i have had the lights turned on with the engine running, but not for prolonged durations.
Old 17th December 2008, 22:39   #41
benbsb29's Avatar
I tried out an arrangement this evening using white LEDs in series.
I connected the 3 white LEDs in series with a 47 ohms resistor. Didnt click any pics as this was a crude arrangement as well. Will try and get a PCB this weekend and fabricate a better set-up.
Old 17th December 2008, 22:48   #42
badboyscad's Avatar
Thanked: 172 Times
no no. use 82ohm 1/4 watt resistor for white LEDs.
Old 18th December 2008, 12:59   #43
lightpower's Avatar
Thanked: 15 Times
I = V/R
But in my experience R=V/I works very well where V=Voltage drop across the resistor and I = working current of the LED.
If we connect a LED of 3v with 20mA of nominal current across a 12 Volt source then the Value of the resistor should be (12-3)/0.02 = 450ohms with 1/4watts.
Also I think the voltage may vary between 11.5-12.5 or 13.0 I believe depending on the battery and alternator output.
lightpower is offline   Reply With Quote
Old 18th December 2008, 13:04   #44
mjothi's Avatar
Thanked: 216 Times
Benny, that's a neat and sweet job. It does look cool. Does it feel cool too
About the resistor and LED. Yes, its always suggested that they should go both hand in hand. Do not separate them and make any sin. Lol.
mjothi is offline   Reply With Quote
Old 18th December 2008, 13:22   #45
esteem_lover's Avatar
Thanked: 451 Times
I might think in terms of changing the silly green color of the speedo console.
That would be interesting. What colour do you think will look good on the console, considering yours is front lit ?
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Using leftover DRL LEDs for Home Lighting! Grr7 DIY - Do it yourself 12 17th June 2015 14:26
Skoda Octavia Angel Eyes and LEDs abhinav.gupta88 Modifications & Accessories 80 20th October 2014 16:09
Experiment! Replacing conventional headlights bulbs with LEDS! frankmehta Modifications & Accessories 18 8th December 2010 14:56
Quality Super Bright LEDs, where can I find them ? s0uljah Modifications & Accessories 20 20th February 2009 17:20
