Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 21st December 2008, 23:33   #61
Jaguar's Avatar
Thanked: 151 Times
Inspired by the thread I have bought the LEDs (white and blue), Resistors and PCB. Have to search for the soldering iron lying somewhere
Originally Posted by vid6639 View Post
What's the wattage on the LED's. 3.5V is the voltage but what is the current they should be getting.
The stock bulb is generally 12V/8W = 1.5A current. Based on that I plan to add the LED's solder all these on a small PCB.
One electronics shop wala told me to use 2 white LEDs with 100 ohms resistor in series or 3 blue LEDs and the 100 ohms resistor.
Jaguar is online now   Reply With Quote
Old 22nd December 2008, 23:36   #62
benbsb29's Avatar
Thanked: 4,281 Times
The holder mentions the power rating for the cabin light at 10W.
I am not sure about the specific current rating for the LEDs i am using but i believe they have a rating of about 15-20mA.
Vid, what color LEDs do you plan on using?
For such a simple set-up, i dont think any soldering is even required. But then since you plan on using the PCB, you could as well do it neatly.
Let us know of your progress, Ramesh.
Old 17th January 2009, 18:03   #63
greenhorn's Avatar
Thanked: 1,519 Times
Light Emitting Diodes
should help folks thinking about trying out this.
I tried out an initial test with some LED's and twisted wire, and it doesnt look half bad . will take some pix of them in the dark and post
planning to get some more and do a proper PCB setup
Old 17th January 2009, 22:52   #64
benbsb29's Avatar
Greenhorn, thanks for the link.
Here is the circuit diagram of the setup which i had usd for the LED setup. The resistors used are for 3 blue LEDs in series on each parallel arm of the circuit.
Am posting this mainly as sanju.sreekumar tried the setup and got the series and parallel arrangement wrong.
Name:  Copy of led_diag1.jpg
Did anyone else have any success?
Old 17th January 2009, 23:34   #65
greenhorn's Avatar
bought an LM317, and was thinking of a setup with a fade in effect while turning on, as well as constant voltage to ensure the brighness remains the same...
but the quick and dirty setup works just fine , so thinking about sticking with this , probably 3x3 LED's and increasing the resistors value from 56 to something higher to reduce the max current to about 20 mA or so
Old 18th January 2009, 00:12   #66
greenhorn's Avatar
the spot lamps alone , to get an idea about the whiteness
with the LED's on
the view from below
and from the side
with the plastic cover removed
the wiring - i used a lot of plastic tape to reduce the chance of a short, and uset plastic tape since it was transparent - insulation tape wouldnt have looked as nice
sorry, I couldnt take any shots of the cabin ( or rather my cam couldnt), but its a lot brighter than it was with the bulb
Old 18th January 2009, 00:12   #67
benbsb29's Avatar
Greenhorn, what color LEDs are you using? If you are using the white ones with three in series then use a 82ohms resistor, and if blue, use a 47 ohms resistor in series with 3 LEDs.
Between, how exactly can we acheive the fading effect when the switch is turned off? I believe the Swift has such a fade-out effect. I would be quite interested in implementing something like that.
EDIT : Just saw the pics you'd put up. Good job!
Old 18th January 2009, 00:21   #68
greenhorn's Avatar
white
according to the article, the LED's should be 3.6V ( dont have a multimeter with me now :( ) , so 3X 3.6 = 10.8, then the remaining 1.2V divided by 25mA gives 50ohm
I used 56 Ohms
but at 14.4, i guess it should be running 3x the current. but I'm not planning to use them a lot with the engine on, and either way, am planning to replace this with a PCB setup , possibly next week. Fade out would be hard. fade in is easy, but you'll need a circuit for that - it was given in the LM317's datasheet
Old 18th January 2009, 16:16   #69
benbsb29's Avatar
Default Fade-in and fade-out effect
Will adding a capacitor in parallel to the LEDs help realize the fade-in and fade-out effect? If so, what would be the capacitor rating i would require?
Old 18th January 2009, 17:02   #70
_abhay_'s Avatar
courtesy light or theater effect
Dimmer's Ive got some links really helpful. I havent tried those as my cr is still under warranty and dont was to mess up thing . circuits tested fine on a simulator on my pc.
Voltage regulation can be effectively and economically archived using ZENER Diode. threy are like voltage regulators
check these links let me know if they work . i'll be at lamington road the next day
CircuitDB | Dome light dimmer (with delay)
Dome Light dimmer A useful operation for the cars is delayed extinguishing internal lighting cabin of passengers after close some door car Dimmer
_abhay_ is offline   Reply With Quote
Old 18th January 2009, 19:22   #71
greenhorn's Avatar
with just a capacitor, you'll need a big value ( several thousand microfarads) if you want a fade in time of ~1s, for just one string of 3 LED's , and in addition, it will overload the circuit which turns this light on for the first second while the capacitor charges.
and to add to that , the dimmer works well only on bulbs. LED's light:voltage curve isnt very linear, so it will not glow at all, then suddenly turn on. You'll need something like PWM to get them to fade in and out correctly.( even with a simple IC controlled circuit like the one abhay posted works nicely only on bulbs )
Old 1st February 2009, 15:51   #72
greenhorn's Avatar
benny was right. 56k aint enough. one of the LED's burnt out.
got a different colour LED this time. these look a violetish white, sort of like 10000k or more. got a Proper PCB setup made
the best part is that these LED's consume just .43W with the engine off, and 1.3W with the engine on. the bulb uses 10/14.4W correspondingly !
theres more
Old 3rd February 2009, 10:20   #73
greenhorn's Avatar
meh, the current ones arent bright enough. I cant find any high brightness LED's here in TVM. Will have to scout all the local shops and have a competition
Old 3rd February 2009, 10:40   #74
benbsb29's Avatar
Greenhorn, the PCB setup looks neat. Are these 5mm LEDs? Why dont you try the 8mm ones?
Old 9th February 2009, 23:50   #75
benbsb29's Avatar
Buoyed by the success of the cabin light setup, i am now working on the bootlight. Am trying to fit in three series connections in there, but the space constraint is an issue.
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Using leftover DRL LEDs for Home Lighting! Grr7 DIY - Do it yourself 12 17th June 2015 14:26
Skoda Octavia Angel Eyes and LEDs abhinav.gupta88 Modifications & Accessories 80 20th October 2014 16:09
Experiment! Replacing conventional headlights bulbs with LEDS! frankmehta Modifications & Accessories 18 8th December 2010 14:56
Quality Super Bright LEDs, where can I find them ? s0uljah Modifications & Accessories 20 20th February 2009 17:20
