Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 1st March 2009, 22:46   #106
greenhorn's Avatar
Thanked: 1,516 Times
hey, but the caution light looks like its lit up by a bulb...... you thinking what I'm thinking
Old 1st March 2009, 23:27   #107
shreyasma's Avatar
Originally Posted by badboyscad View Post
@shrey : That "caution" thingy is quite an idea. It looks good too.
ya..Tbhp is the place for innovative ideas. How can I be here without new thoughts (I say crazy at times)
Ha ha....gotcha mate. Lets see how things work out. I first have to go shop for 3mm leds and some resistors and finish the fogs. Else, cant sleep peacefully. Then will look into the brake lights .
shreyasma is offline   Reply With Quote
Old 1st March 2009, 23:39   #108
greenhorn's Avatar
In that case , prepare for sleepless nights to be honest, i dont think LED's are practical for illumination.Even the proper options arent that good. there are proper LED bulbs available , and they still suck.
Old 1st March 2009, 23:51   #109
shreyasma's Avatar
Hey no man. I am not looking at getting the bulb output. Just need a little bright light compared to existing LEDs. Because of the size of the LED, i couldnt use more. So just want to decrease the size and increase the number. I am sure the output will be satisfactory to be used as angel eyes even with my 100/130 headlamps ON.
Okay now tell me if i can use 3x3mm white LEDs in series and a 100 ohms resistor?
Old 1st March 2009, 23:54   #110
benbsb29's Avatar
Thanked: 4,276 Times
Shrey, the illumination for the number plate looks like a stadium with floodlights!
benbsb29 is online now   Reply With Quote
Old 2nd March 2009, 00:10   #111
shreyasma's Avatar
As i mentioned earlier, it was supposed to be for the headlamps. But my 3rd gen esteem doesnt have the headlamp and the indicator at the same level. so chucked the idea. Then came the stadium with floodlights!!
Old 2nd March 2009, 00:11   #112
greenhorn's Avatar
Thats what I use - 5 mm led's though. have used 3mm ones also , but they started dying after a month or so. not sure what the problem was. the LED's should be able to handle that much current....
Old 2nd March 2009, 00:17   #113
shreyasma's Avatar
I shall try and see if they stay alive
Old 18th April 2009, 22:29   #114
greenhorn's Avatar
finally , after several failed attempts ( mostly failed due to my own laziness ) and one blown cabin fuse later, I've managed to upgrade my rear hatch light also to LED!
And its damn bright. too bad my cam batteries are still dead. I think only the front lights are left. else I'll have to add unecessary bling. I do have that LED VU meter board lying around.... lets see
Old 3rd May 2009, 23:25   #115
rahulya007's Avatar
Thanked: 35 Times
Default Need some guidance on LED and resistor selection
Greenhorn,
I had been to a electronics shop locally and bought 4 10mm white LED's for Rs. 6 a piece. Don't know whether it was a good deal or bad.
The guy suggested me to use a 1 watt register in parallel with the 4 LED's since i am using them with a 12V supply. Also for single LED he asked me use the same 1watt register.
Pls. suggest.
I am planning to replace the stock yellow bulbs in the indigo cabin lamp (this lamp has a separate reading light for passenger and driver each apart from the center lamp which operates on door closure/open) in front with the 10 mm LED. I am replacing the reading lamp bulbs here.
Can you pls. suggest the resistor i should use with the 10mm LED to provide the maximum light. Is 1 watt resistor ( bigger one) OK or needs to be replaced with some other wattage.
in the testing process, I have already blown the cabin lamp fuse twice
rahulya007 is offline   Reply With Quote
Old 4th May 2009, 07:02   #116
greenhorn's Avatar
i had trouble acessing the reading lamps - i think we share the same unit. I suggest you use a 100 ohm resistor in series with three LED's. thats what I'm using.
If you want to use a single LED, I'd suggest a 470 Ohm resistor.
THe price is a good deal. they cost me about 2 rs for the regular , and 3.5 for the high brightness.
Opening the fusebox is a pain in the you know where right? I couldnt . Read about my adventures here
http://www.team-bhp.com/forum/techni...t-replace.html (Help!busted something in the electricals: what to replace?)
Old 4th May 2009, 08:12   #117
benbsb29's Avatar
Good to see more converts around here.
Greenhorn, he was referring to the 10mm LEDs, and not the usual 5mm ones. Are you sure you took the ratings of the 10mm LEDs into consideration, when suggesting the resistance values?
Old 4th May 2009, 11:20   #118
greenhorn's Avatar
from my experimentation, 20mA seems like the sweet spot. ( I've tried only 3mm and 5mm ones, and even between those, the emitters seem to be of the same size, and there wasnt a significant difference in brightness). You can run 30 mA or even upto 100 mA, but longevity will be suspect. And the light output does not increase linearly with current (check the graph below. Notice that the axes are logarithmic)
Image Courtesy The Perfect Light - Its a good read , if you are interested in the tech behind this
Rather then getting bigger LED's , I think the better option is to use a greater number of small LED's. For example, for the reading lamp, i think 3x3mm LED's in series at 20mA will do a better job , than say a 10mm running at 100mA, last longer, and draw less current from the car
Rahul, If you find an easy way to access the bulbs in the reading lamps, do post how
Old 5th May 2009, 00:05   #119
rahulya007's Avatar
Thanked: 35 Times
Question LED help
Greenhorn,
I have attached a small pic of the LED's and the registers along with the stock bulb from the reading lamp. Its actually very easy to remove the reading lamp after you remove the complete assembly from the roof top. You need to unscrew the circuit plate from the lamp and then unscrew the reflectors around the individual lamps. Unfortunately, i have not clicked a pic yet. I guess there's one available on the this same thread.
In the pic, the bigger registers are the 1 watt registers which the shop guy told me to use with the LED's, either single or 4 coupled together in parallel.
Those seen below are the ones i got a couple of days back which the guy gave me as 1K registers. The guy mentioned above said they were 1/4 watt.
Among the LED's first two are filed and rest are new. the reflection clearly shows this.
To test the light output of these LED's, I am using the TV remote batteries..rather the remote itself..i get the ready made +/- points ..
Connecting the LED directly to the terminals gives out bright light.
Connecting with 1watt register gives very poor light..may be the register is itself eating up most of the current.
Connecting with the 1K register, the light output is between the 1st and 2nd case although close to the dimmer side.
Can you suggest a way out since I want to use 1 10mm LED as far as possible for the reading lamp. what type of register should I get to use with the LED so that it gives out bright light.
I may not be able to do a LED circuit for the light located in the center of the lamp assembly ( the door opener/closer lamp) since the button is not working. Let me know (if at all you know) where can I find one, cause I don't want to spend 500/600 bucks for a new lamp assembly. I enquired, but the button is not available separately.
Awaiting your reply
Warm Regards,
Rahul
Benny's first DIY : LEDs on an Ikon-led_reg.jpg
Old 5th May 2009, 05:22   #120
greenhorn's Avatar
simple doubt - how do you remove the entire assembly from the rooftop?
like i posted earlier, use 470 /330/ 220 ohm 1/4W resistors in series. I'd say try the 330ohm one , and see how long it lasts.
the brightness in the car will be a lot more( since the car runs at 14.4V as opposed to 3V from 2 batteries) . use a 12 V adapter to test.
when you remove the thing, check if the switch for the center is working - it should at least light up in the left extreme position
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Using leftover DRL LEDs for Home Lighting! Grr7 DIY - Do it yourself 12 17th June 2015 14:26
Skoda Octavia Angel Eyes and LEDs abhinav.gupta88 Modifications & Accessories 80 20th October 2014 16:09
Experiment! Replacing conventional headlights bulbs with LEDS! frankmehta Modifications & Accessories 18 8th December 2010 14:56
Quality Super Bright LEDs, where can I find them ? s0uljah Modifications & Accessories 20 20th February 2009 17:20
