Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 23rd January 2009, 11:42   #61
akshay_b's Avatar
Originally Posted by tanwaramit View Post
Hi Akshay,
Putting Bulbs and LEDs is a different thing, as bulbs have a socket where it fits in easily. While LED needs to be connected at both ends with either a socket or PCB of the Instrument panel.
1. How did you connect LEDs in the instrument panel ?
2. Also, if I choose white LEDs do I need to use the same resistor value?
3. Sand Papered - u mean u rubbed the LED using sand paper ? How does this help? Cant I use LED without Sand Paper ?
1.
3LEDs' connected in series were placed in the holes where the stock bulb was present, I used some sticky tape to keep the LEDs in place
And the terminals from the LEDs were connected to the socket/plug on either side which used to carry current to power up the stock blubs.
2. For correct value of resistor required check this:
Current limiting Resistor calculator for leds
3. As told as badboyscad
akshay_b is offline   Reply With Quote
Old 24th January 2009, 05:22   #62
_abhay_'s Avatar
@ tanwaramit , this link should help you with ideal diode specifications, a White LED will have a Vf of 3 to 3.5v (typically 3.5v ) If should be 25-30mA .
led specs - Light Emitting Diodes (LEDs)
calculator - LED series parallel array wizard
_abhay_ is offline   Reply With Quote
Old 24th January 2009, 22:27   #63
diiesoline's Avatar
Default Awesome Stuff
Originally Posted by akshay_b View Post
Here comes
The Blue guages The needles kind of disappear on the cam, But can be seen clearly.
Really awesome work akshay_b. The blue illumination looks great.
A few questions for you buddy -
How much did the LED's cost?
Where did you purchase them?
Any specific brand you picked up?
diiesoline is offline   Reply With Quote
Old 26th January 2009, 14:34   #64
akshay_b's Avatar
Thanks diiesoline
2 bucks a peice
In a general electronic/electrical store
No buddy the usual transparent LEDs' will do just great
Old 27th January 2009, 11:02   #65
tanwaramit's Avatar
Thanked: 387 Times
1.
Hi Akshay,
Thanks for the link, however, I am confused with the following two.
1. Source Voltage -- How much it would be for Santro Xing ?
2. LED Voltage -- Assuming it to be 4V (am I correct on this assumption (for white LEDs?)
3. Current -- 25 - 30 mA (as told by Abhay)
Please help on the numbers, couldnt do last weekend as was out of town for 3 days chutti, will do this weekend...
Looking for white color as it looks great on Honda Accord.
Thanks in advance.
tanwaramit is offline   Reply With Quote
Old 27th January 2009, 16:20   #66
akshay_b's Avatar
Hi Akshay,
Thanks in advance.
1. Source voltage will be 12v inside the instrument cluster.
2. LED voltage- I'd prefer 3.5v for white leds. (U wouldn't want the LEDs to heat up)
3.Current- 20~23mA
To-buy list:
6 White leds(3 on each side), buy 2 more in case if u break the terminals while connecting
two 82 Ohm resistors
A meter of insulated thin wire.
Insulation tape
Scissors
sand paper
Old 28th January 2009, 11:31   #67
tanwaramit's Avatar
Thanked: 387 Times
3.Current- 20~23mA
To-buy list:
Insulation tape
Scissors
sand paper
Thanks a ton, will try it out this weekend n will upload pics
Old 20th January 2011, 18:27   #68
Default Re: DIY Santro Instrument Light Colour Change (New Process)
Please somebody tell me the type of bulb and if possible put some pics also.
necro is offline   Reply With Quote
Old 8th February 2011, 12:17   #69
motomaverick's Avatar
Thanked: 868 Times
Good DIY let me try the same on the Zen, any idea why the LEDs are sandpapered?
Old 8th February 2011, 18:40   #70
akshay_b's Avatar
You can use the regular transparent LEDs that you get in a neighborhood electric shop.
Or else you can try this
LED Bulbs, LED Light Bulbs, LED Light Bulb & Car Parts for Sale - DealExtreme
Plug&Play.
So that the focused light beam doesn't fall only on one part.
Try the link that i mentioned.
DIY - Swift Interior Light Change from stock to White LED sonirohit DIY - Do it yourself 26 27th March 2010 16:16
can the colour of the in dash instrument cluster lights be changed??? mclaren1885 Modifications & Accessories 23 22nd August 2009 16:04
Orange light "ON" Palio 1.6 S10 instrument pannel -what is it ? photo attached karizma_devil Technical Stuff 7 25th June 2009 13:17
Is it possible to change the instrument cluster display? passion4cars Modifications & Accessories 41 15th March 2009 22:54
Instrument cluster light change nikibusa Motorbikes 7 10th September 2005 09:26
