Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 8th January 2009, 20:26   #1
Default DIY Santro Instrument Light Colour Change (New Process)
Hey Guys was bored today with nothing to do, so opened up the instrument cluster of my santro and changed the lights colour to red, albeit in a different process. want to know what I used to change the colour of the light bulbs ?? it is.. Yes now go ahead change them to any colour you want. All you need to do is remove the bulbs and give them a coat of glass paint and voila have the instrument cluster in any colour you like.
Friends if you liked my idea, encourage me by posting pics of your instrument cluster whose colour have been changed using my idea.
cheers
lifewater
Lifewater is offline   Reply With Quote
Old 8th January 2009, 20:50   #2
Fountainheader's Avatar
Hehe. Thats a nice idea there pal. So everytime you get bored, you can change the colors of the bulb... and there you go with a new dash!
Fountainheader is offline   Reply With Quote
Old 8th January 2009, 20:51   #3
badboyscad's Avatar
Thanked: 172 Times
Hmm. i never knew that using glass paint would return such good results. Good work.
badboyscad is offline   Reply With Quote
Old 8th January 2009, 20:56   #4
MontyKING's Avatar
Excellent idea there. It is a bit of surprise as to how easy it is.
MK
MontyKING is offline   Reply With Quote
Old 8th January 2009, 21:05   #5
bblost's Avatar
Thanked: 6,974 Times
Good job.
also check out this thread
http://www.team-bhp.com/forum/modifi...board-diy.html
Old 8th January 2009, 23:06   #6
aZa
aZa's Avatar
Thanked: 17 Times
nice job there. How difficult was it to open the cluster ? Pls post pics of WIP if you have them.
Old 8th January 2009, 23:59   #7
noidaboy's Avatar
Thanked: 260 Times
Paint's/Caps fade away after a wile under usage.Due to heat.I think you will need to re-do this after a while to sustain that kinda red.
noidaboy is offline   Reply With Quote
Old 9th January 2009, 07:24   #8
Yes now I am bored already, want to change it to blue, umm no to orange, no to chocolate or... phew let me see will have to toss and find out.
You bet it it is one of the simplest way to change the instrument panel's light.
Not difficult at all four clips and 3 screws thats all you need to remove. I dont have the WIP pics, will post soon when i can decide the colour of the Instrument panel to change next
Sorry friend have done the same to my bro-in-law's car about 2 months ago, but the light intensity is still the same. please note I am using GLASS paint not the normal household paint.
Old 9th January 2009, 10:42   #9
Tejas@perioimpl's Avatar
Thanked: 5,475 Times
Those small bulbs do not generate that much heat so as to cause the paint to flake off.
@ Lifewater
How many coats of paint did you apply? How do you remove the paint? Acetone? Thinner? Or scraping it off?
Tejas@perioimpl is offline   Reply With Quote
Old 9th January 2009, 10:51   #10
getsurya's Avatar
Thanked: 967 Times
Hi Life water, Thats a good DIY. Pretty easy too!. Just need to wait and watch as to the longevity of this exercise. If this works fine, then it saves us from the effort of replacing the bulbs.
getsurya is offline   Reply With Quote
Old 9th January 2009, 10:58   #11
benbsb29's Avatar
Thanked: 4,276 Times
Good job, lifewater! A rather simple way of doing it, i must say.
Personally, i would still prefer playing around with LEDs.
benbsb29 is online now   Reply With Quote
Old 9th January 2009, 14:36   #12
faithless_1984's Avatar
Thanked: 217 Times
God job Lifewater.!
Cant wait to try this now.
faithless_1984 is offline   Reply With Quote
Old 9th January 2009, 18:15   #13
ankitahuja's Avatar
Thanked: 46 Times
Good job there. Gives me ideas now!
I think you should stick to Red, since your HU is in Red too.
The small bottle nozzle will give a good coat in one time. Make sure you keep drying the paint while applying since it has a tendency to bleed.
You can just wipe off glass paint with a wet coth. It comes off easily.
Old 10th January 2009, 07:40   #14
@ Lifewater
Two Coats of paint. Dried the paint coat in approximately 2-3 minutes by keeping the bulb in front of a room heater (Blower type). To remove the paint, just wipe it with a wet cloth - may need some effort though.
As of now, I can vouch for two months without any fading of colour (My Bro-in-Law's car. Lets see how long it lasts.
Thanks. Your call - I like this process as I have no time or patience to solder the L.E.Ds.
Originally Posted by faithless_1984 View Post
God job Lifewater.!
Thanks buddy. Please do and post the pictures, cant wait to see your pics. All the best.
O.K. will stick to it. However will paint two three sets in different colour just to see.
Right - absolutely right. I have mentioned above how I did it.
Yes it does. But not so easily.
Old 12th January 2009, 01:28   #15
_abhay_'s Avatar
Default great job !
Even i was planing one for my car, but was a bit hesitant.
After seeing this I sure will try it.
Can you please post some pics of "How to remove instrument cluster of Santro Xing" (if any)
after pondering what color will look good, came across an excellent idea. Here it is . PS Job !
Wondering if White will be possible , @Lifewater are there LED's or bulbs (incandescent) ??
saved images at a lower quality to reduce size
_abhay_ is offline   Reply With Quote
DIY - Swift Interior Light Change from stock to White LED sonirohit DIY - Do it yourself 26 27th March 2010 16:16
can the colour of the in dash instrument cluster lights be changed??? mclaren1885 Modifications & Accessories 23 22nd August 2009 16:04
Orange light "ON" Palio 1.6 S10 instrument pannel -what is it ? photo attached karizma_devil Technical Stuff 7 25th June 2009 13:17
Is it possible to change the instrument cluster display? passion4cars Modifications & Accessories 41 15th March 2009 22:54
Instrument cluster light change nikibusa Motorbikes 7 10th September 2005 09:26
