| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #61 (permalink) |
| Senior - BHPian Join Date: Jul 2006 Location: mumbai
| if you are hibernating that means the pc is powered all the time even after switching off car. how do you start CF? is is set as system shell? if its the current setup try copying CF exe file to start menu folder of windows and see if there is the same issue with the usb sound card |
| | #62 (permalink) | |
| BHPian | Quote:
i mean if you are running CF or RR or any other fornt end and you hibernate your pc, after resuming it you will come back to the same position where you hibernate it.
__________________ NEVER GIVE UP, JUST DO IT !!!! | |
| | #63 (permalink) |
| I prefer switching it off completely when parking car. boot up & CF running from last point is less than a minute. If battery voltage drops below 11v the PSU auto logic anyways switch of pc to conserve battery. Dosen't it? When CF was loaded as shell, i used to get error of touch screen failing to load 30 times. then i copied it to start folder of windows. now all drivers load before CF starts. |
| | #64 (permalink) |
| BHPian | i'd say to go for hibernation process. aftre a computer is put to hibernation it dose not consumes current. so you dont need nay power at all when the pc is on hibernation. try hibernating and resuming while your car is fro repair.
| | #67 (permalink) |
| BHPian Join Date: May 2008 Location: Chennai
| Will a USB Hub with ON/Off switch work for you: Welcome to Usb.brando.com.hk
__________________ If Real is what you can feel, hear and see, then Real is simply electrical signals interpreted by your brain - TATASAFARICLUB.com Last edited by ibm_jennifer : 17th March 2009 at 21:44. |
| | #68 (permalink) |
| BHPian Join Date: Mar 2005 Location: Ahmedabad
| hmm..that would be good option. and it will definitely work. but why do i have to use that ? I am searching on intel site. it could be a bios problem. though i have upgraded it to latest BIOS yesterday. will update you if i find any solution. |
| | #69 (permalink) |
| I don't believe its a Bias problem! May be a USB Diver issue. Start the PC in Safe mode with the USB Card and let us know the status.
__________________ If Real is what you can feel, hear and see, then Real is simply electrical signals interpreted by your brain - TATASAFARICLUB.com |
| | #71 (permalink) |
| Then its better to upgrade the BIOS. Disable Boot from USB Devices and try.
| | #74 (permalink) |
| Your system may think it as a USB Keyboard(?) and trying to activate it(?). I heard lot of problems about USB sound cards & Windows. Have you tried the sound card in another sytem, is it fine? And another USB Port?
| | #75 (permalink) |
| BHPian | i have a solution probability of the same is 50-50 get the external hdd wire which as two usb connections one for the power and another for the data do try and let me know ,as per our knowledge it's the problem its sucking more power than the processor when booting up i think the same issue was posted by me on some thread or may be this one not sure though |
« How many of us have DIY CarPc in India?
Has anyone tried Direct to Car (DTC) using DTH receivers ? »
| Thread Tools | |
Similar Threads | ||||
| ICE installation - Clarion DXZ785 + CDT + Kenwood | santosh.s | Sound Off and Show Off | 70 | 27th July 2009 23:37 |
| Santro ICE - Installation & Tuning Queries | nura | Ask the Gurus | 178 | 27th May 2009 21:06 |
| I-10 ICE [equipment & installation] Pictures | BHAGWAN | Sound Off and Show Off | 125 | 6th September 2008 22:08 |
| My latest ICE Installation - NHC | AshOnTheRocks | Sound Off and Show Off | 21 | 20th March 2007 00:46 |
| GTO606ce installation for Swift | skiddyrow | Sound Off and Show Off | 10 | 8th July 2006 14:44 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
