Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
Thread Tools
Old 10th July 2009, 18:48   #106 (permalink)
Originally Posted by srikant View Post
Guys me and my friends are planning to install a carputer for my friends swift petrol. I have some questions on that.
1. Can we use his existing desktop for the project?
2. The existing SMPS shows 400 watts, isn't it on the higher side for carputer?
3. What modification should i do to drive the desktop CPU from car and what change should be made to SMPS?
Srikant
You'll Need a DC - DC power supply to run a PC in Car.
Modifying a AC SMPS to fit and serve a carputer is a Horrible Idea, cause it will not work the way DC-DC Power supply are designed.
You can use your desktop pc, but it will have multiple drawbacks
Size, Power consumption etc
Old 10th July 2009, 19:16   #107 (permalink)
gigy's Avatar
Originally Posted by nisarg86 View Post
GIGY. it is ON/OFF switch. have connected it directly to battery's + and -
It is the master power switch to on the PC.
As everybody pointed out two big pins are for "+" in from battery and "+" out to load. those two are not interchangeable. a smaller one will be for led "-".
A desktop pc can be used with a DC-DC psu if you make sufficient space available. A 2.5 hard disk is more shock proof. a solid state one is recommended. dont use smps, i have wasted lot of time and money on it, not practical.
Old 10th July 2009, 19:17   #108 (permalink)
DerAlte's Avatar
1. Can we use his existing desktop for the project? ...
A desktop PC will not be energy-efficient when used in a car, though it will definitely work the way it is supposed to. The SMPS rating is an indicative maximum, but need not consume that all the time. The easiest would be to minimise the hardware complement - throw out anything and everything that is not necessary
* get a car inverter of moderate rating to drive it OR
* modify the SMPS to accept 12V as input, instead of the usual 230V (this is not a simple modification) OR
* buy a higher power DC-DC converter for use in the car
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 11th July 2009, 01:08   #109 (permalink)
nisarg86's Avatar
Originally Posted by ghpk View Post
I am sure the "+ve and -ve" are going into switch only for L.E.D.
The circuit which switch will ON/OFF will have only one wire i.e. +ve.
there should be only two Large Points (connectors) on the switch which will toggle connectivity with switch position on/off.
EDIT: How many pins you have at the back of switch ?
If it has 3 in all, 2 goes to LED (+ve and -ve )and one goes to output taking current from One Terminal shared from L.E.D.
Yes . it has 3 pins on the switch.
nisarg86 is offline   Reply With Quote
Old 11th July 2009, 01:27   #110 (permalink)
gigy's Avatar
Since led is working you have got two pins connected right. the third one remaining will power the pc.
Old 11th July 2009, 01:29   #111 (permalink)
nisarg86's Avatar
yes. 2 pins connected.
and 3rd one should be connection to ignition wire ? right ?
Old 11th July 2009, 01:52   #112 (permalink)
gigy's Avatar
One "+" is connected to battery (must go through a fuse). second "-"one is grounded to car body. Led is glowing when switched on now.
The third pin of switch is to be connected to hot "+" pin of PSU(dc-dc power supply) to make it the master on/off switch for carputer.
Old 11th July 2009, 09:46   #113 (permalink)
Gigy got it exactly what i was trying to say.
Old 11th July 2009, 10:06   #114 (permalink)
nisarg86's Avatar
thanx ghpk and gigy. will post the pic.
Old 11th July 2009, 12:57   #115 (permalink)
srikant's Avatar
What alternative can i use for SMPS in the CPU?
I did plan for a car inverter and have ordered for a 300 watts Axiom car inverter. Things are just in planning stage as of now. Looking out for alternatives too. Any suggestions are welcome.
I am not an expert in Electrical and electronics. So would be great if someone could explain the procedure.
Sri
__________________
2001-Hyundai Santro 80k KMS
2005-Hyundai Accent CRDI 75K KMS
2007-Maruti Swift VDi 57k KMS
Swift VDI CARBON
srikant is offline   Reply With Quote
Old 13th July 2009, 04:52   #116 (permalink)
gigy's Avatar
A touch screen and a dc-dc psu are a must for trouble free integration to car. you can look at dual core atom for 5k in miniitx form.Put in a list of items you have presently, it will help in planning.
Old 21st July 2009, 18:59   #117 (permalink)
nisarg86's Avatar
New location of my GPS. Locked the position quite fast now.
Old 29th July 2009, 12:48   #118 (permalink)
Nice.. Whats the GPS receiver make and model. Also did u integrate it with CF2.0 or had to load different maps specific to India?
kiran1103 is offline   Reply With Quote
Old 29th July 2009, 23:58   #119 (permalink)
nisarg86's Avatar
Kiran. GPS Receiver is GlobalSAt BU-353. And yes i have purchased the Satguide Map.
all you have to do is copy the Map Folder into CF Dir. and load the MAP in CF.
Old 30th July 2009, 00:23   #120 (permalink)
Thanks Nisarg. Now is there any way that I can use the GPS receiver of Nokia N97/iPhone 3G/Blackberry Bold.
All of them have Bluetooth but its the question of using their receiver to transmit the data to the Car PC. Also I understand that it will drain the battery at an alarming rate.
btw I see the GlobalSat BY-353 is available for approx 3k. Hope its the right price?
Thread Tools
ICE installation - Clarion DXZ785 + CDT + Kenwood santosh.s Sound Off and Show Off 70 27th July 2009 23:37
Santro ICE - Installation & Tuning Queries nura Ask the Gurus 178 27th May 2009 21:06
I-10 ICE [equipment & installation] Pictures BHAGWAN Sound Off and Show Off 125 6th September 2008 22:08
My latest ICE Installation - NHC AshOnTheRocks Sound Off and Show Off 21 20th March 2007 00:46
GTO606ce installation for Swift skiddyrow Sound Off and Show Off 10 8th July 2006 14:44
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
