| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() | guys, in the skoda is it advisible to mount the sub-W on the tray itself or should i get a sub-w box made and keep it in the boot ? i know having a box in a boot gives me the flexibility of removing it whenever there is luggage but then what i want to know is about the music part ! how will the bass be affected in both scenarios ? which is a better option musically ? the sub-w is a 12 inch pioneer 340..... waiting............ |
| | #2 (permalink) |
| Senior - BHPian | music wise the woofer in the box is the best way to go for sure. orelse u got 2 ways to do this. either put on the tray or behind the rear seats. free air you should know how the music is since in the ikon you had the same setup i think. go for the box one and install another woofer as well for the best outcome
__________________ Јєşåł Åŕỳā Modifying Gone Mental |
| | #3 (permalink) |
| Senior - BHPian | Subs on the tray in a skoda can never give the kinda bass that boxes can. Did two skodas yesterday, one with 3 x 12" woofers in a box, and another one with 2 x 15" on the tray. And the box sounded so much better anyday. The tray doesnt provide any kinda enclousre to subs at all inspite of the big boot and the end result is weakened bass. And like jesal said, id suggest a second sub too. What amps are u planning to use anyway?
__________________ "I drive a Mitsubishi 3000GT, and I live a 1/4 tank at a time... For those 50kms or less, I'm free." |
| | #5 (permalink) |
| Senior - BHPian Join Date: May 2004 Location: Bombay
| I have a sub woofer box fitted in the trunk of my accord.... no ways was i going to cut the tray so this was my best option...have mounted the amp on the woofer box too.... just wonder sometimes which is the correct position to place the woofer in the trunk? Also the good part abt having the box is that i can have it detached (i have the clip system plug)whenever i want to increase boot space.
__________________ ______________ __________ ______ __ _ |
| | #6 (permalink) |
| BHPian Join Date: Nov 2004 Location: India-Mumbai-Colaba
| hey buddy ive installed an audio system in a skoda and no way are you going to get the punch out of the woofer when its on the tray...get a box with two air vents on each side and the woofer in the middle..since your installing a pioneer woofer then 944 is the way to go...hehe...cheers...!! ![]()
__________________ oVaBoosT - Performance Unleashed...!! |
| | #7 (permalink) |
| Senior - BHPian | hey dude...don't mount the sub on the tray...the effect won't be good and the tray will keep vibrating making noise..or replace the OE tray with a wood or something like that... i my octy tho'..the sub is in the boot...or keep the sub in the boot and remove the tray..i think it'll be better |
| | #8 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| tray's are usually flimsy (though made of fiberglass the section is too thin and the tray too large). you would have to make a tray of MDF or marine ply and i doubt if the hatch's hydraulics will be able to carry the weight of the wood board and the sub(s). the advantage of tray mount is that it occupies little space. and you dont have to remove the sub everytime you need the trunk. besides for a tray mount you have to choose a sub that is designed for free air operation. a box offers a more controlled enviroment. this usually translates to better defnied bass. not i say defnition not volume. however a box takes up room and it is not always convienent to remove the box and put it back when you need the extra room. 3 other alternates. make a fiberglass mount fot the sub and reinforce the tray with resin bonded fiberglass mat and sheet. this is messy but you can learn more from http://www.glassmanscustomforum.com/ Use 2 8" bass tubes. this would offer you almost the same response as 1 12". the 8" bass tubes can be tucked into the sides. lastly if you can lay your hands on MTX's thundeforms the one they make for the Jetta will work for your Octavia. see http://www.mtxaudio.com/caraudio/pro...es/JETTA10.cfm what i have done.... Opel Sail - reinforced fiberglass tray with resin bonded fiberglass. the tray now supports 4 6" woofers. Octavia RS - 2 8" bass tubes. you might have other choices too. see caraudio.com and carstereo.com for installs done by other car audio accifionados. Last edited by navin : 28th April 2005 at 10:52. |
| | #10 (permalink) |
| Senior - BHPian | guys, can i use a 12" 305F pioneer (free air) sub woofer on an mdf tray in my ikon. the amp wud be a pioneer 6000F. or shud i go for the mdf box. i'm thinking about the tray fitment because the subwoofer is a free air type one. pls. help
__________________ Maruti - Everyone comes home with rattles! |
| | #12 (permalink) | |
| Senior - BHPian | Quote:
__________________ Maruti - Everyone comes home with rattles! | |
| Thread Tools | |
Similar Threads | ||||
| Advanced Installation technique - mounting tweeters | Sam Kapasi | DIY - Do it yourself | 34 | 22nd October 2007 14:58 |
| Rear speaker mounting options in Zen estilo | choolan | Modifications & Accessories | 1 | 19th July 2007 04:23 |
| Help Needed : JBL 1000 10" subwoofer in a tube | AshOnTheRocks | Ask the Gurus | 10 | 10th April 2007 11:41 |
| Uniball joint suspension mounting? | Sankar | Technical Stuff | 0 | 31st January 2006 14:47 |
| mounting a audio system,neons etc in any car | TEAM R.A.R | Modifications & Accessories | 5 | 13th October 2005 09:46 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
