| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2008 Location: Bangalore
| Before starting off with the DIY story, let me clarify a couple of things... [1] Every DIY has its own inherent risks. I considered the 'worst-case-scenario' and decided that if I ended up with damaged speakers / blown HU or Amp, I was ready for it. [Acceptable risk] [2] I have been using the setup in my cars since 2002, first in a Santro [with the rear-speakers running off a single Sony XM222 - 2 channel amp], then in 2004 the system was transplanted into a M800, then in 2005 the system was transplanted into the Xing, and an extra amp was added. Over the past 6 years, the speakers have worked great. [3] My initial concern was around degradation of the speakers due to heat, since my car would be parked in sun for long hours. The only precaution I would take was to cover the speakers with a cloth to prevent direct sunlight from falling on them. They continue to work fine till date, so I can say that this is a 'tried and tested' DIY. [4] The longevity of the speakers, the performance of the system etc. may depend on what you are starting with and how well-made the speaker boxes are etc. [5] The only damage I have experienced is that one of the speaker metal grills is slightly dented due to a suitcase being placed on it. [No change in sound quality though] [6] Before embarking on any similar DIYs, just ensure that you get the full tech specs of the amp / HU in your car and the ratings of your speakers to ensure that they match. [Look at the RMS, Impedance ratings etc. Preferably post them on T-bhp so that the ‘Audio-gurus’ can tell you whether they match or not.] Current maintenance: [1] Before I give the car for service, I disconnect and take out the boxes. [2] Once every few months I use a vacuum cleaner blower to blow out dust from the speaker cones. [Not at full blast, might damage the speakers, I reduce the wind speed with a gauze / mesh cloth.] How does the system sound? [1] Sweet! Really sweet!!. Since the rear speakers are full-range speakers, with built in cross-overs etc. the sound quality is quite good throughout the volume range that I use. [2] The bass is quite good, without the 'dead-bass' beats that come from a sub-woofer and powerful enough to require some mild-damping. (See my DIY damping story. http://www.team-bhp.com/forum/diy-do...-yoga-mat.html (A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????) ) [I avoid sub-woofers since I tend to get a headache after a few minutes of being subjected to the 'dead-bass’ frequencies.] What kind of music do I listen to? Everything - from Bryan Adams to Eminem, Bhimsen Joshi to Jagjit Singh, the latest Bollywood hits to the old Hindi classics, KennyG to Infected Mushroom... so the system has been tested for almost all kinds of music. Now for the DIY story... Think about it, for an average Joe like me, buying a decent home audio system is a relatively painless exercise. Just walk into any good electronics store and I can walk out with a system that suits my budget and taste. Be it a Sony, Philips or a Samsung, they all make complete and ready-to-use systems. But look at a typical car audio system buying exercise; first choose a head-unit, Pioneer or Sony or Blaupunkt or XYZ. Then choose the front speakers - components or coaxials? Next move onto the rear speakers - there must be atleast 100+ options available on JC Road, in all shapes, sizes and brands. Other decision points include - should I just connect everything to the HU or should I use an amp? Do I need a sub-woofer?? Adding to all this complication is the fact that for every original component, there must be atleast two counterfeit ones in the market. With all these variables thrown into the equation, will the final result be what I want? Depends on luck I guess... lots of it. When I got my first Santro in 2002, I did a lot of R&D, checked out all my friend's cars and then finally went JC Road thinking that I was ready to get my car ICEd. After deciding on the HU, I got a pair of Pioneers fitted in the front. Now the crucial rear-speakers, I bought a pair of Sony ovals (The pre-Xplod series). Since I did not want to sacrifice on the usable boot-space and did not want a rear plank either, I got a pair of slim 'side-boxes' fitted in the rear - the kind that fit on the wheel arches. All connections done and system switched on... and it sounded really crappy. I had used better sounding '2-in-1s' in the past! :-) The dealer suggested using normal boxes and adding an amp, a Sony XM 222. That done, the sound did improve a lot, but I was still not satisfied. The next option was adding a plank, the system sounded decent with the speakers mounted on the plank. Since it was already past 9.00pm and I was quite tired, I decided to call it a day and returned home, with a not-so-happy feeling. All the way while driving back I was thinking, why don't these audio companies make good and easy-to-use car audio kits? Give me a good HU, with matched front speakers, a decent amp, rear-speakers pre mounted in good boxes - designed specifically for each popular car model. Throw in all the different wires and connectors required and you have a ready to use kit. [Sony / Philips, are you listening?] For the next couple of months I drove around with the system, all the while thinking that there should be a better way of doing things. I had a Sony MHC-VX501 HiFi system at home that I was not using much. The system has an amplifier rated at 120w +120w RMS @ 6ohms. The speakers are SS-VX333 boxes, 3-way, 3-unit bass-reflex type [See the spec sheet for full system details. Sony systems normally have a tendency to be 'Bass-rich' and the same was the case with my HiFi. Since I was catching up on my music more during my commute than at home, the system at home was under utilized. One day, I was wondering about what if I use the Sony speaker boxes in the car... was it possible? I pulled up the spec sheets for the speakers and the car amp and the numbers looked decent. The single amp would still be quite under-powered compared to what the speakers could take, but it should work... Went down to the car, took out the plank, placed the boxes in the boot, connected them to the amp and viola! it sounded good!!! The main argument against using home-audio boxes in a car seemed to be whether they could take the heat and vibration. Considering that the speakers were not being utilized fully at home, I thought that even if they last for a year or two, it should still be 'paisa vasool'. As mentioned earlier, the system worked flawlessly in the Santro from 2002 to 2004. Then I had a M800 for about a year in the interim, the system was transplanted and worked fine... when I got the Xing in 2005, the system was again transplanted. This time a second amp was added for more juice. Since the XM222 amp was not available, I picked up the nearest alternative, the XM502Z. Currently each amp is powering one rear speaker in a bridged mode. [The HU rear-speakers selection is set as 'full range' and the band-pass filters on the amps are set to 'off']. Recently I changed the HU to a Pioneer 6050UB since my previous HU did not have USB connectivity. The front speakers are JBL GTO426e 4” 2-way units, fitted into the stock receptacles, running directly from the HU. I got the amps wired as follows; the left rear channel from the HU is split into two using a 'Y' type RCA splitter cable, fed into the left and right channels of the amp and the speaker is connected in a bridged mode. [So both the channels of each amp are getting the same input.] Similar setup with the other amp. [See diagram below in this post for clarity. Why this type of wiring? It sounded better than running just one input into each amp in a 'bridged' input mode. i.e. like when a sub-woofer input is connected.] There are also a pair of JBL CS265e's fitted in the stock speaker receptacles in the rear. On rare occasions where there is a lot of luggage to be carried in the boot, I take out the speaker boxes, put in the detachable plank and switch-over to the JBLs. I had thought of fabricating some sort of fasteners / Velcro belts etc. to hold the boxes in place. But each box weighs 4.3kilos and they don’t move around, so no fastening required. I have placed them on a thick cloth / mattress. Currently I am quite happy with the system and see no need to change it in the near future. Though I did consider picking up a more powerful 2 channel amp, it has not moved from ‘wish-list’ to ‘action-item list’ as yet. Specs & Pics of the DIY: How things are connected... ![]() The speakers are normally placed like this... ![]() The speakers look like this when placed upright... ![]() The XM222 amp under front driver side seat... ![]() The XM502z amp under front passenger seat... ![]() The front speakers... ![]() Full Tech specs... ![]() Just in case you are wondering what happened to the Sony Music System after the speakers were taken away. Well, the system is still in use occasionally... it is connected to the DVD player for use as a home-theater setup. It now sports a pair of Jamo E370 floor standing tower speakers.
__________________ v drive...! |
| | #2 (permalink) |
| BHPian | nice dude i had connected my home wooden speakers to my car audio player long long back in 1989 in my maruthi suzuki 800 they were so huge i had to keep 1 in the boot and another on the rear seat those days i was in II puc and max money in my pocket used to be 20 or 30 rupees no funds for amp equaliser good speakers for the car |
| | #3 (permalink) | |
| BHPian | Quote:
I used to do exactly the same to the smae car (1989 maruti 800) ![]()
__________________ Cheers! Shreyas "Two Wrongs don't make a Right, but three Rights make a Left!" | |
| | #5 (permalink) |
| BHPian Join Date: Oct 2008 Location: Mumbai
| Have you checked what ohms are all your speakers? From what I know different ohms generate heat in the ic's of the amp and headunit thus resulting in damages. ![]()
__________________ YoYo... Live n Let Live! :D |
| | #6 (permalink) | |
| Quote:
Rear boxes are rated at 6ohms, the specs for both the amps state that they can be used with speakers rated between 4 to 8ohms. So they are in the safe range. But then again, even if the speakers were rated for 8ohms (as many home audio boxes are), it would still be ok. The thumb rule that I follow is that as long as the speaker impedence matches the amp ratings or even slightly exceeds it, it is still ok. And I never mix speakers with lower impendance with amps rated higher. i.e. a 4ohms speaker, with a 8ohms amp is absolutely no-no.
__________________ v drive...! | |
| | #7 (permalink) |
| BHPian | totally unrelated question... I need speaker grill like this: ![]() I do not intend to use it on another speaker but rather in the cavity of my front bumper. so I sill need a big sheet. free treat to anybody who helps me find a sheet.
__________________ who mod-ifie-s the mod-ification-s? - Venkat Last edited by blacmagic : 15th July 2009 at 21:12. |
| Thread Tools | |
Similar Threads | ||||
| Car HU for home audio use? | jaibir | Ask the Gurus | 16 | 21st June 2009 01:18 |
| Help with DIY 3 way speaker setups for fronts | greenhorn | Ask the Gurus | 17 | 25th March 2009 15:21 |
| need help and advice - Car Audio install DIY | patkim | DIY - Do it yourself | 8 | 15th December 2008 20:52 |
| Diy Car Audio Preamplifier for Aux-in | _abhay_ | DIY - Do it yourself | 8 | 1st June 2008 13:31 |
| Need a good audio speaker system (SPL+SQ) for home | Nos007 | Gadgets, Computers & Software | 31 | 13th February 2008 15:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
