Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 25th November 2016, 11:00   #61
ilangop's Avatar
Thanked: 581 Times
Default Re: DIY tacho for a car, using a bike's tacho
Originally Posted by Aslamjaffer View Post
Is it possible to mount a Ritzís tacho in a santro and get it to work? This is for my friendís car and we are not going to try any DIY here but wanted to go to the mechanic with some basic knowledge on how likely this will work.
Hi Aslam, In theory I wouldn't say it is impossible. But you need to do some homework. Does you santro ECU wiring have a Tacho signal out? If so, is the relation between the number of pulses produced per rpm same as that in Suzuki ECU. Though this would need some internet study or a test with an oscilloscope, I would recommend you to fit an aftermarket stuff if we are not able to decode the relation between the pulses produced by the ECU tacho output signal and the tachometer needle deflection.
ilangop is offline   (3) Thanks Reply With Quote
Old 25th November 2016, 11:20   #62
Mr.Boss's Avatar
Thanked: 2,411 Times
IIRC "NO" (except for some special edition which came with tacho in India, whereas the export model or the one in abroad came with factory fitted tacho)
EDIT:
discussed here (Tacho for Santro)
Mr.Boss is offline   (1) Thanks Reply With Quote
Old 25th November 2016, 11:20   #63
Aslamjaffer's Avatar
Thanked: 71 Times
Thanks for your swift response ilangop.
As this is my friend's car, need to visit his place to check the ECU wiring and in parallel we are trying to understand more about the concepts.
While scanning, just came across the below post
http://www.team-bhp.com/forum/modifi...ml#post1492156 (Santro Specifics Mods and upgrades !)
Now, we are giving a second thought to go for an aftermarket stuff as this looks much hassle free to get it up and running.
I will surely keep the thread updated on whats happening.
Cheers!
Aslamjaffer is offline   (1) Thanks Reply With Quote
Old 25th November 2016, 12:24   #64
Mr.Boss's Avatar
Now, we are giving a second thought to go for an aftermarket stuff as this looks much hassle free to get it up and running.!
Not every aftermarket tacho is compatible with Santro. Look for the one which could be calibrated for 2 Cylinder
Old 25th November 2016, 14:59   #65
Thanked: 71 Times
Sure thing Boss. Will surely validate for the compatibility before freezing into a particular model.
Recommendations appreciated for some compatible and best tachos available in the market.
Cheers!
Aslamjaffer is offline   Reply With Quote
DIY Project: Automatic headlamp control using Arduino audioholic DIY - Do it yourself 32 2nd July 2017 11:22
DIY: Handmade Scale Models, using Thermocol Sagz Shifting gears 69 12th December 2015 11:17
DIY: Using a Saddlebag with pillion on the Ninja 300 ani_meher Motorbikes 7 10th February 2015 14:32
DIY: Tacho Install in Maruti WagonR vishwaschettri DIY - Do it yourself 45 17th November 2013 15:35
