Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 30th May 2009, 16:33   #91
sabret00the's Avatar
Thanked: 45 Times
Originally Posted by amit_mechengg View Post
got the parts
but at the double cost
82650M79G00 - is the correct striker part no. 82650M79G10 is wrong.
the dealer in mumbai had scratched off the MRP. the dealer in pune showed me the receipt and charged 40 Rs for courier.
1. striker : Rs90
2. Lever : Rs 90
3. Cable : Rs 150
Total : 330 + 40 = 370.
Going for a DIY right now. will post the pics if i am successful. i think i have to tear off the mat a bit.
That's almost twice as much as I paid for the parts .
sabret00the is offline   Reply With Quote
Old 30th May 2009, 16:55   #92
ASHISHPALLOD's Avatar
Thanked: 286 Times
man,
that is the difference between market oriented free economy of Maharashtra and communist led sociological economy of West Bengal.
do tearing of mat required?
@amit,
do it fast and post the pics of step by step activity. do tear off the mat as many places as you wish but show us the exact place where to tear off the mat.
ASHISHPALLOD is offline   Reply With Quote
Old 30th May 2009, 18:43   #93
Thanked: 16 Times
Default remote boot opener for alto lxi
Hi Members,
I got the parts needed that is stricker:82650M79G00,Lever:83310M76G50,Cable:83350 M79G20 ,from ESSARR AUTOMOTIVES BANGALORE,today .
This was after a wait of 5 days,it costed me rs 200 and extra rs 20 for courier,regarding the courier charges it was mentioned earlier when i booked my parts,so it was fine with me,he said if you dont want to pay i will have to wait fifteen days,i immediately called Mr Lokesh from SURAKSHA ,bommanhalli ,and explained about the work ,he asked me to call Mr Girish from Body works ,spoke to him ,he said he will do the fitting on Monday ,he said its a long procedure have to remove seats and carpet to do so ,so will see how it goes on monday,tHANKS to all the members in this thread for the guidance ,will keep you updated once the work is done .bye Chetan
chetan5678 is offline   Reply With Quote
Old 30th May 2009, 20:26   #94
amit_mechengg's Avatar
Thanked: 1,556 Times
Originally Posted by ASHISHPALLOD View Post
man,
@amit,
dont worry man. the next order can be at MGP mrp .i paid the price of sourcing it in 24 hrs flat that too due to the third party dealer. but i saved on labour. this is how:
it was not a 20 min DIY as i thought. it took 2 hours of continuous labour for me
i had to remove the rear seat, the rear mat, the hatch trim, the woofer, the speaker box in short i stripped half of the car.
the cable took a toll on me as the bud(gundi) which has to be hooked in the lever was not going easily. i dint have a polish paper, nor did i have the filer. then an idea struck me. went upstairs and got the nail cutter and filed the bud all round. this took almost 20 min.
the most critical thing is routing the cable. you have to neatly route it throug the same port through which the fuel lid opener cable goes from. the fuel lid opener cable then bifercates towards left of the car from the rear seat and the boot opener cable to the right, from beneath the trims to the striker. you have to push pull and adjust many times.
then came the bugger original strikers turn. it just refused to come out. broke 2 screw drivers for the same. it was damn tight. then went to the neartest bike repair shop on my bike and got his huge T shaped screw driver with the help of which i was able to give more torque and open them.
see the circled part in the snaps. i had to tear out the mat where the lever is fitted. i will stitch it back.
so after bruises on my hand a few cuts, aching back and what not finally the DIY ordeal was over. but it was a great satisfaction when just at the flick of the lever the hatch door opens. the opening and closing of the hatch door is smoother than before now.
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11504.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11505.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11506.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11507.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11508.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11509.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11510.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11511.jpg
Remote Boot Opener in ALTO LXi - Edit: Info on Pg 3 & 8 and a Detailed DIY on pg 13-sdc11512.jpg
Old 30th May 2009, 21:14   #95
SLK
SLK's Avatar
Thanked: 192 Times
Nice, work.
It's do-able, but the cable laying work is a pain I think.
BTW - its a car you were operating on, those screwdrivers look like they are suited for computers , that's why they gave way.
SLK is offline   Reply With Quote
Old 30th May 2009, 21:31   #96
Originally Posted by SLK View Post
Nice, work.
yes fitting the cables to the lever then routing them and the adjusting the striker is a pain.
yes those screwdrivers are chinese make but they were hardened ones, yes you are right they need to be used for home appliances.
i am planning to get the bosch kit. costs about 5k
Old 30th May 2009, 21:49   #97
Thanked: 16 Times
Default Remote Boot Opener
Congrats Amit,Good Job ,The cable you have doesnt look like a mgp,is it a good brand?
Old 30th May 2009, 22:24   #98
the cable is of some brand called NEW ERA with some genuine hologram on it. its sadly not MGP. but looking at the finish and the quality of plastic and the outer cover it seems that quality is good. also the cost printed on it is 170Rs.
generally a 2 wheeler cable of half the length also costs more than 100 bucks. however mgp is more cheaper. but i couldnt find it anywhere in pune.
Old 30th May 2009, 22:33   #99
Thanked: 286 Times
thats what i was expecting about timing.
nice work.
btw, had you teared off the mat? where? is it shown in the last pic?
Old 30th May 2009, 22:59   #100
Thanked: 45 Times
@ amit_mechengg : congrats dude. Now there are 2 ALTOs in TBHP to sport a remote boot release. I'm sure you'll agree it is worth the pain. Anyways in my case the pain part was taken care off by the mechanic at MASS.
Old 30th May 2009, 23:03   #101
SLK
SLK's Avatar
Thanked: 192 Times
ALTOs [Not just Lx_], well yeah then mine too! So when are you getting power window? .
Interesting actually! No one here's got a Vxi?
EDIT: went back and searched the member list. 23 Vx/Vxis + mine. Out of the total Altos totaling to 671 + mine
Old 30th May 2009, 23:21   #102
nice work.
yes the last circled part. i tried hard to fix the lever without tearing the mat. but my hand wouldnt go inside the cavity. also got a cut on the finger. so finally i cut about 40-50 cms of the mat.
Old 31st May 2009, 09:37   #103
Thanked: 286 Times
oops!! 40-50 cm tear off!!
in the pic, it looks barely 4-5 cm.
@ashishpallod-do tear off the mat as many places as you wish but show us the exact place where to tear off the mat.
ohho, i got it. you had teared off 50 cm but shown us the exact place of 5 cm to tear off. thanks.
Old 31st May 2009, 11:17   #104
Thanked: 45 Times
Nah scrapped the idea of Power Windows for the time being since "Home Ministry" didnt approve the funding for the same .
@ amit_mechengg: Dude seems like we have the same rear speakers but which JBL amp is that?
Old 31st May 2009, 12:39   #105
Technocrat's Avatar
Thanked: 2,589 Times
Congrats Amit
Seems like its not really a small DIY but nevertheless looks like the effort is worth it all.
So when can you order the next lot? Let us all know, we will pay you first then you order them.
Looking forward to get this mod done for my car
Honda Jazz DIY: Reducing rattles and custom lighting for the cabin & boot naikameya DIY - Do it yourself 19 7th December 2017 01:28
DIY - Remote Boot Release for 118 NE EDIT - Got Alloy wheels Now ilangop DIY - Do it yourself 20 10th July 2017 19:11
DIY: Adding a Remote level control/ Bass remote to your Amplifier HimuraKenshin In-Car Entertainment 8 11th April 2012 16:59
WagonR (2006 and before) gets a Remote Boot Release paragsachania Technical Stuff 4 16th July 2010 11:48
Which Central Locking with keyless entry and remote boot opener sabret00the Technical Stuff 6 27th April 2009 16:18
