Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
Thread Tools
Old 26th July 2009, 18:45   #46 (permalink)
gigy's Avatar
Good screen but its looking slightly big to me. I have doubts if it will go under a double din without fiberglass work.
Old 7th August 2009, 21:21   #47 (permalink)
ST7677's Avatar
Ordered following this week
Opus 360W PSU
Zotac 9300 ITX mobo
1 gb RAM x 2, dual channel
Seagate Momentus 7200.3 2.5" 320gb HDD
Winsis case with 200W PSU
Already ordered earlier
Asus DX low profile sound card
And Lililput 8" widescreen touchscreen
Yet to order Processor, with that, I should be good to set up the rig at home at least.
Planning to go for Intel E7400 core two duo processor
__________________
Honda Civic 1.8 MT 2006 (1st lot)
Audison LRx4.300 & LRx1.400 + Hertz HSK165 + Adire Brahma 15" Sealed Sub
Stanley Nappa Leather
ST7677 is offline   Reply With Quote
Old 8th August 2009, 01:02   #48 (permalink)
nisarg86's Avatar
@ST.
Will Opus 360W firmly sit with mootherboard and asus card on WinSIS case ? Did you check the dimensions ?
nisarg86 is offline   Reply With Quote
Old 8th August 2009, 08:40   #49 (permalink)
gigy's Avatar
You are sure going to have tough time putting the opus 360 (186mm x 96mm x 18mm) in winsis case with 200w psu(265mmx90mmx270mm).
Old 8th August 2009, 15:05   #50 (permalink)
gigy's Avatar
Did you ask this guy for the dash kit you wanted in case you have not got it till now?
Team-BHP Classifieds - Installation Kit/Frame/Fascia for all Cars - Powered by PhotoPost Classifieds
Old 11th August 2009, 16:40   #51 (permalink)
ST7677's Avatar
Thanks Gigy, will check it out with him.
Will Opus 360W firmly sit with mootherboard and asus card on WinSIS case ? Did you check the dimensions?
I know, but there aren't too many choices, as this is the max size I can get under the seat!!!
There is at least 100mm overlap between the PSU and the Mobo. I am hoping that there will be enough vertical space available to allow the overlap, else I might have to look at a separate enclosure for the PSU.
__________________
Old 11th August 2009, 16:45   #52 (permalink)
gigy's Avatar
May be then you can mount the psu on the top cover inverted rather than on the default psu area. overlap will be taken care of then.
Old 14th August 2009, 22:13   #53 (permalink)
linuxtechie's Avatar
Default Nice going there.
Hello OP
Well for beginning, I have gone through all the posts. I am also in process of making a Car PC and just like you I am also stuck at the damn thing called monitor.
I am not convinced at all with the options available there, agreed, you get what you pay for. But yeah, cant pay all the bunch for it. My home ministry will surely frown.
Monitor is something that will be visible to everyone and if its not good enough, I am sure I will be laughed at all the efforts made.
So question to all the posters being:
Isn't there any monitor that gives decent visibility inside car? Let keeps the touchscreen part aside, I am planning to use a MCE remote for same. Nothing's out there?
~LT
__________________
www. linuxtechie. net
linuxtechie is offline   Reply With Quote
Old 14th August 2009, 23:19   #54 (permalink)
ST7677's Avatar
If you leave touchscreen aside, there are plenty of screens with even upto 1000nit brightness. And then you can do upgrades like change your backlight etc. It will be darn cheap too. But do you really want to have a carputer without a touch screen? Using a remote will not be safe while driving your car!
__________________
Old 15th August 2009, 01:52   #55 (permalink)
Please let me know the options, I have been searching for quite some time now. If its from US, then a friend is flying back in couple of weeks, I can hopefully order through him.
Very true, hence I wont be handling it, it would be used by someone who is using the entertainment. I will be ofcourse driving. Also the remote makes sense cause the back seater dont have to ask someone to change any options.
Thanks for the reply.
~LT
__________________
Old 15th August 2009, 18:17   #56 (permalink)
gigy's Avatar
for non touchscreen version you can have a look at this option from usa for 115$. i dont think there can be a better offer but grab it as for ltd time only.
U70 7in LCD widescreen secondary monitor, VGA monitor screen USB display
it has usb power and source input, alternately vga is also retained if usb dont suite the requirement.
Old 15th August 2009, 18:52   #57 (permalink)
ImmortalZ's Avatar
ST, did you testfit your LCD yet? Eagerly awaiting your results.
__________________
Honda - Providing the least Kilo per Lakh since 1948.
Old 15th August 2009, 23:09   #58 (permalink)
ST7677's Avatar
Well you can have another touchscreen installed in rear also
I am contemplating having second touchscreen for rear so that my wife can control, but also worried it will become a toy for the kids...
No haven;t done it yet.
That would be the last step when the computer is all setup and ready to go in the car. I really doubt it would fit, I don;t expect it to.
I am looking for a good rear view camera, any options with prices?
__________________
Old 16th August 2009, 00:03   #59 (permalink)
ImmortalZ's Avatar
From a couple of threads at 8thCivic, an 8.4" screen is a perfect fit for the OEM navi bezel. If the 2DIN facia adapters we get are a clone of this bezel (which they probably are), you might actually have no problems fitting the LCD in - you might have to make some sort of bezel edge in case it is actually too small.
Re: cameras - I've seen rear cameras for JVC and Alpine units. They were both simple RCA output cameras, so they might be easy to wire in. Prolly expensive though - brand names.
__________________
Old 16th August 2009, 09:25   #60 (permalink)
gigy's Avatar
Do post your camera find once done. even i am looking out for one with night vision. prices are starting from 2k, one of which we had bought for a friend's dezire but they dont have any technical details mentioned.picture is ok.
I am looking out for this design
Thread Tools
Lateral Movement - Skoda Octavia to Honda Civic? EDIT : Bought Civic! Jay5150 Sedans 44 19th August 2009 07:07
Arya Honda v. Apex Honda | Honda Manual v. Auto Civic Axe77 Indian Car Dealerships 12 21st July 2009 08:22
Honda City Vs Honda Civic E Vs Honda Civic V (pre-owned) drkunaldas Sedans 3 16th March 2009 01:27
Peninsular Honda sells me a *new* repainted Honda Civic 1.8 V jmathew Indian Car Dealerships 299 21st October 2008 15:52
2003 Honda City part dealers 1729 Technical Stuff 7 31st October 2007 17:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
