| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #16 (permalink) |
| Senior - BHPian | I have a Hertz Dieci DSK 130 component. the Matching 6x9's - DCX690 were damaged recently in an accident. I'm planning to add the mids used in the oval to the comps. Current plan is to leave the comps as they are. Connect the mid via a first order HPF ( capacitor) at a cutoff of about 700 hz or more. I assume the mid should be fine as it was connected directly to the input in the 6x9 where it was used earlier, but there is a capacitor , there, so i will confirm and get back. Planning to go all passive. - all I have is an HU - the comps are not amped, and there are no fancy settings on the HU , and i cant afford anything exotic either. the need is to compensate for the loss of mids from the mid bass mounted in the door due to the reduced off axis response. The other person is greenh0rn, who i believe is trying to tune his illusion comps ![]()
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 23rd September 2009 at 15:33. |
| | #17 (permalink) | |||
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
I see one problem... if the mid is XOed at 1kHz and the tweeter is operating from 4K on given their relative position I see some comb effect creeeping in from 5K onwards maybe even earlier. Still I say go ahead. Try it. Use the original dash grill for the mid. At best you can always bypass the mid and leave it inside the grill (non-operational).
__________________ Scixelsyd Etinu | |||
| | #21 (permalink) | ||
| Quote:
Once we have the cap value we will know what the safe 6db XO point is. Then we can push the XO point an octave lower by going 12db instead of 6db. making a small 18/20 SWG inductor (about 1.5-2mH) using a soft iron or ferrite core wont be that difficult you might even be able to get one in the market. Like I said before 2.5" drivers can go very low. Bose uses them as low as 150Hz. Ofcourse not all 2.5" drivers are equal. take these 2 made by the same company FR070WA01_02 SW070WA01_02
| | #22 (permalink) |
| Senior - BHPian | Ok, I'm a bit confused. connecting a multimeter across the two leads from the assembly showed open circuit. connecting to one of the leads, and the point after the capacitor yielded 4.2 ohms. the capacitor appears to be a 6.8μF non polarized one which translates to about 5.5khz cutoff which probably means that the cap is for the tweeter ![]() ![]() ![]() here are some close up shots of the assembly. ![]() ![]() So i thought that the midrange might have been damaged, and could have gone open circuit, but tried it as the center channel of my home stereo, worked fine - both the mid and tweeter. ![]() I'm beginning to wonder if there is some sort of internal crossover within the driver
__________________ '07 Indica DLG - Almost a DLX |
| | #23 (permalink) | |
| Quote:
Is there only one cap? If the tweeter is XOed at 5.5kHz/6db the mid should be XOed atleast 2 octaves lower so probably less than 1kHz/6db. I cannot see how the 2.5" driver can handle power below 150Hz so there has to be some XO somewhere.
| | #24 (permalink) |
| Senior - BHPian | navin, I'm just as stumped as you are. The pics show all the connections there are in the speaker. Next stop, I'll try disconnecting the capacitor and see if the mid works. I'm beginning to wonder if the 'mid' is really a mid, or just a cone tweeter, in which case I'll have to shop around for something else. I didnt hear much vocals out of it during the trials
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 25th September 2009 at 10:44. |
| | #25 (permalink) |
| Greenie, At first glance it looked like the $1.50 cone tweeters Bose used to use on their 301s. If there is no other cap then try this... disconnect the cap (hence also disconnecting the other tweeter) and only connect the cone tweeter/mid and see what emanates. Unless the 6.8uf is being used by both tweeters in parallel.
| | #26 (permalink) | |
| Senior - BHPian | Quote:
seems the 'midrange' (as claimed by the spec) is also crossed over at 5.5Khz and is in parallel with the other tweeter. some midrange ![]() let me see if i can get a separate driver
__________________ '07 Indica DLG - Almost a DLX | |
| | #27 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| No, greenie, there must have been some error in measurement. In pic 2 and 3, one can see that the terminal to which the 2nd leg of the cap is soldered is not connected to anything other than the red wire going to the tweeter. It is just a terminal to ensure that the cap and lead to tweeter are soldered well and mechanically stable. Possibly, when you desoldered the 1st leg of the cap, the tinsel lead joint must have been disturbed, resulting in neither the mid nor the tweeter playing. You could try measuring the DC resistance from the 2nd leg of the cap to either tinsel lead - it should be OC. The mid VC is fed directly through the tinsel leads on the right (pic 3). Try once again by disconnecting the tweeter red wire from the terminal (with the 2nd leg of the cap), without disconnecting the cap.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #28 (permalink) | |||
I think the first terminal is just there to have a landing place to connect the cap and the leads from the main terminal Quote:
__________________ '07 Indica DLG - Almost a DLX | |||
| | #29 (permalink) | |
| Quote:
Anyhow, we should see resistance between the white terminal (where the tinsel and black wire is soldered), and either the red terminal (tinsel) or orange terminal (straight leg of cap). Would be easier if you measure with nothing connected to these terminals.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| Thread Tools | |
Similar Threads | ||||
| DIY : Damping the swift with yoga mats and making it rattle free | rjstyles69 | DIY - Do it yourself | 27 | 8th October 2009 13:15 |
| Hello from an engineer in the making !! | d3mon | Introduce yourself | 16 | 13th December 2008 21:51 |
| Making a Will | Raja | Shifting gears | 18 | 25th November 2008 22:01 |
| Need help in decision making | burnout_boy | SUVs, MUVs & 4x4s | 4 | 27th September 2008 08:55 |
| New AC making noise | Real_man | Technical Stuff | 2 | 22nd March 2006 05:06 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
