Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
Thread Tools
Old 27th September 2009, 18:27   #31 (permalink)
DerAlte's Avatar
What happens when you disconnect the tweeter? Both the mid and tweeter go silent?
Tangential thinking: what happens if you short out the tweeter?
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 1st November 2009, 11:21   #32 (permalink)
greenhorn's Avatar
found another mid which would fit in. Also found that the entire under dash is covered with some thick rubber/foam (damping?) sheet. Speaker fit when it was removed.
This is an 'Osaka' mid i got hold of for <200 a piece. Seems to be working fine. Vastly improved prescence, slightly honky when pushed to the limit, but totally worth it.
The crossover is 2x470uF connected in series
sorry for the lousy pix. My digicam seems to be acting up
__________________
'07 Indica DLG - Almost a DLX
greenhorn is online now   Reply With Quote
Thread Tools
DIY : Damping the swift with yoga mats and making it rattle free rjstyles69 DIY - Do it yourself 27 8th October 2009 13:15
Hello from an engineer in the making !! d3mon Introduce yourself 16 13th December 2008 21:51
Making a Will Raja Shifting gears 18 25th November 2008 22:01
Need help in decision making burnout_boy SUVs, MUVs & 4x4s 4 27th September 2008 08:55
New AC making noise Real_man Technical Stuff 2 22nd March 2006 05:06
Powered by vBulletin
