Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 4th October 2009, 03:29   #16
aZa
aZa's Avatar
Thanked: 17 Times
There is a shop called PRO AUTOMODS here in noida, over there i saw these bi xenon projector kit. it was very similar to what there in the red getz. The kit comes with a BI xenon projector + hids + CCFL rings. It was costing around 14K
I will try get some pics.
Old 4th October 2009, 10:21   #17
Thanked: 9 Times
Thumbs up
Originally Posted by 3danikesh View Post
I have just finished my dual projector design. Please let me know what you think
The black one looks good. If you can use projectors of different size for Hi and Lo beam, it will look better.
Lord Lucan is offline   Reply With Quote
Old 8th October 2009, 08:10   #18
somebodystopme's Avatar
Thanked: 17 Times
You should go with black, silver looks more like part of body so it doesnt let car eyes look like eyes. Best of luck
somebodystopme is offline   Reply With Quote
Old 9th October 2009, 00:25   #19
noidaboy's Avatar
Thanked: 260 Times
Kudos for the light, Post some picture from inside the car,
How come i see not color band? may be its the camera.
185 for the ballasts seem a big amount. Did you compare the pricing before the purchase?
noidaboy is offline   Reply With Quote
Old 9th October 2009, 00:48   #20
AKi10's Avatar
Thanked: 20 Times
Hi aZa,
Would this be available for an i10?
Alex
AKi10 is offline   Reply With Quote
Old 9th October 2009, 02:10   #21
noidaboy's Avatar
Thanked: 260 Times
Originally Posted by AKi10 View Post
Hi aZa,
Alex
Its virtually universal it can fit any car that uses H4 bulb
Old 9th October 2009, 02:37   #22
AKi10's Avatar
Thanked: 20 Times
Pardon my ignorance.
But how does the projectors fit in. Does this use the same outer frame of the OEM light unit, or is the entire light unit changed.
Alex
Old 9th October 2009, 04:42   #23
abhinav.gupta88's Avatar
Thanked: 310 Times
I'd recommend you to contact smokin.
He'll give you the design and whatever you want and the quality as to what i've seen is really amazing.
Old 9th October 2009, 12:49   #24
m4ugr8's Avatar
Thanked: 123 Times
Interesting project. Waiting to see the final pics and light output. The GETZ lamps look great, OE look completely.
m4ugr8 is offline   Reply With Quote
Old 9th October 2009, 14:45   #25
noidaboy's Avatar
Thanked: 260 Times
Hi aZa,
Alex
Alex
The glass of your stock light can be opened easily, Remove the bulb and this projector fits it self on the lock designed for the bulb. No cutting, no pasting, no alteration.
Old 10th October 2009, 19:52   #26
Awaiting Email Confirmation
hi 3danikesh,
Pls guide as to how and where did you get this thing done. I would like to do the same on my elantra as there's none available in the aftermarket as many other cars,
cheers,
alphamike is offline   Reply With Quote
Old 10th October 2009, 23:27   #27
3danikesh's Avatar
Thanked: 44 Times
Thatís great, if possible please post the specification and Brand for the same
Yes black is better but there is lots of detailing to be done, only then I will finalize on the color.
I am using 3 inch for low beam and 2.5 for high
Itís a rough design just to have an idea. Once the design is complete it wonít look that flat.
Iíll post some pictures ASAP
I am using Matsushita digital ballast itís a OEM for Nissan/Infiniti vehicles. Itís much better than aftermarket HID kits.
Thanks, final product is at least couple of weeks away but Iíll keep updating as I progress.
Originally Posted by alphamike View Post
hi 3danikesh,
cheers,
If you want to retrofit projector I can help you but if you are planning to design a complete headlight assembly like my i20 Project, it will cost you Rs.1,50,000+. Not good for just one pair unless you are an Arabic Sheikh
3danikesh is offline   Reply With Quote
Old 13th October 2009, 09:25   #28
smokin's Avatar
Thanked: 13 Times
that's a hefty price you paid...
i am using hella e55 projectors for the last two years+
Mitsubishi Electric gen4 OEM ballast
Mitsubishi company 4300k D2s hid bulbs
green color angel eyes CCFL
led indicators(amber color)
wire harness locally made for the same(this is locally as the wire harness used to get blown after few months so made with local wire relays so if get blown i can replace the relay costing me less than 100/-)
fog lights :
h7 4300k hid bulbs
with shield removed projectors
both projectors put up in the headlight assembly in cross way
Entire Setup cost is Rs. 24000 approx and parking light is standard next projector (no LED no CCFL Angel eye)
Infinity FX 35 Bi xenon Projector - $210
Matsushita Gen 3 35W Digital Ballast -$ 185
Philips 85122+ D2S bulbs (4300K) - $ 80
Ballast control box and wire harness - $ 30
These Projectors can be fitted to virtually any Car but it might cost you more than aftermarket headlight, though cheaper options are also available
smokin is offline   Reply With Quote
Old 13th October 2009, 11:00   #29
3danikesh's Avatar
Thanked: 44 Times
fog lights :
h7 4300k hid bulbs
Thats Great
How much you paid? Everything I bought was brand new, even the Projectors (Brand New from OEM manufacturer)
Old 13th October 2009, 20:58   #30
anantnehru's Avatar
@3danikesh: Looks really cool, was in touch with some guys (maybe the same) to get projectors and HIDs for the Sx4, but as plans sometimes do, it fizzled out. How did you open the headlight though? That was my main area of concern, as I wasnt too sure how much heat was required etc. etc.
anantnehru is offline   Reply With Quote
Tata Xenon Crew-Cab launched : The Downgraded variant of Xenon XT jeepster Commercial Vehicles 183 11th March 2018 22:59
HID Kit / Projector / Xenon Lamps FAQ Takumi-san Modifications & Accessories 17 12th August 2015 14:34
Difference between Xenon-Angel Eyes-HID-Projector headlamps Abhi_Automobile Modifications & Accessories 27 11th October 2011 21:25
Corolla Mods - Eibach Springs, Xenon HIDs and Angel Eye Projector Headlights novice Modifications & Accessories 14 2nd July 2011 03:46
