Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 21st January 2010, 22:37   #1
dinu2506's Avatar
Thanked: 349 Times
Default Simple DIY - Painting Alloy Wheel Cover of Verna
This is a small DIY I did last weekend with the painting expertise of my daughter. I have the Verna CRDI SX that comes with standard alloys. I'm sure most will agree that the alloys are pretty bland. Thought I will give it a small makeover with a inhouse paintjob on the wheel nut covers. Started with prying open the four covers and washing it well to remove all dust and grime. Dried it well using a hair dryer and handed it over to my daughter to paint it so that the "H" stands out. Had a used can of Asian Paints enamel and borrowed some brushes from her collection. Other items - Newspaper, wiping cloth, thinner for cleaning the brushes etc. Let the pictures do the talking now. Starting with how the wheels looked and upto how they are now with the in-between journey. Nothing great, but gives a fresh look now to the car.
dinu2506 is offline   (1) Thanks Reply With Quote
Old 21st January 2010, 22:51   #2
NOTORIOUS's Avatar
Thanked: 89 Times
looking awesome. will plan something for wheelcap now .
NOTORIOUS is offline   Reply With Quote
Old 21st January 2010, 22:58   #3
simply_sunny001's Avatar
Thanked: 15 Times
good job dinu
and i am sure your daughter most have loved to do this.
simply_sunny001 is offline   Reply With Quote
Old 21st January 2010, 23:03   #4
DRIV3R's Avatar
Thanked: 1,433 Times
That looks great Dinu.
DRIV3R is offline   Reply With Quote
Old 22nd January 2010, 03:09   #5
Thanked: 152 Times
Suggestion: Spray Paint the wheels black!! It looks awesome.
http://www.team-bhp.com/forum/modifi...lf-thread.html
Cyrus43 is offline   Reply With Quote
Old 22nd January 2010, 09:45   #6
akshay4587's Avatar
Thanked: 1,686 Times
the wheels look nice,better than stock
Cyrus,you and your fetish for black,if you had magic wand,you would have turned all rims on earth to black
Old 22nd January 2010, 09:51   #7
dinu2506's Avatar
Thanked: 349 Times
Thanks guys, glad to know it did not turn out to be worse than stock. Yeah, my daughter paints well and I had the full confidence that she would do a good job. I painted the first one and she the remaining and I should admit hers came out better
dinu2506 is offline   Reply With Quote
Old 22nd January 2010, 11:15   #8
Epic's Avatar
Thanked: 424 Times
Hey Dinu,
Great job on the alloy wheel caps. It looks great & way better than the stock. however, what paint have you used for this job as I hope you know that wheels are subjected to very high temperatures which can lead to the paint peeling off which may end up looking bad.
Epic is online now   Reply With Quote
Old 22nd January 2010, 12:48   #9
dinu2506's Avatar
Thanked: 349 Times
Originally Posted by Epic View Post
Hey Dinu,
Thanks for the appreciation. I have used normal enamel paint. Yes, I had given a thought about durability but went ahead. Worst case, I'll replace the caps if it tends to peel off. But, I guess, the temp at the cap will not be very high and should be within the range the enamel paint can withstand. Anyway, lets see.
Old 22nd January 2010, 13:43   #10
unni.ak's Avatar
Thanked: 80 Times
You have a penchant for DIY's!! Looks good . You might have people asking you, is it a limited eidtion model? I mean, after all this is what manufacturers do to come up with special edition, limited edition etc
unni.ak is offline   Reply With Quote
DIY: Spare Wheel Hardboard Cover Desmosedici DIY - Do it yourself 10 16th December 2015 14:06
Replaced No-name alloy wheel nuts with Gorilla wheel nuts. Sankar Tyre & Alloy wheel Section 36 21st February 2013 12:34
DIY: Ford Fusion+ OE Alloy Wheel Restoration Glifford Tyre & Alloy wheel Section 48 28th September 2011 18:27
DIY : How to secure a Tata Safari Spare wheel cover from theft dadu DIY - Do it yourself 25 14th June 2010 12:19
DIY: Alloy Wheel Scratch Removal dr_know Tyre & Alloy wheel Section 8 8th December 2009 12:14
