Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 27th January 2010, 01:31   #1
gopinathann's Avatar
Thanked: 20 Times
Default DIY : Suzuki Logo LED in SX4
Suzuki Logo LED Setup
Tools required:
1. Cardboard / Plastic box
2. Plain paper, pencil, Black paper, glue
3. LEDs White/Blue/Red
4. Resistors
5. Soldering Iron, Lead, wires, Screw driver
6. 12 V Adapter (Optional)
7. Insulation tape
Take a slim cardboard box, the size of the box depends on the size of the logo needed. Wrap the box with black paper.
Draw the suzuki logo in a paper and mark the holes for LED
DIY : Suzuki Logo LED in SX4-1.jpg
Use the suzuki logo paper as a trace, mark the holes in the cardboard. Create holes using screw driver or any other sharp instrument. Place one led to check the hole size, if it's good then repeat the same for all.
DIY : Suzuki Logo LED in SX4-2.jpg
Now fix the LEDs in the holes so that you keep all the positives on one side and negatives on the other side to make the circuit clean. I have used 30 LEDs as specified in the diagram, however used more resistance to be on safer side. I have used 4 LEDs in Series and used 100 ohms resistor for it and 400 ohms for the remaining 2 LEDs. Solder the wires and test it using 12 V adapter. Now you are ready to set it up in the car.
DIY : Suzuki Logo LED in SX4-3.jpg
DIY : Suzuki Logo LED in SX4-4.jpg
DIY : Suzuki Logo LED in SX4-5.jpg
I placed the Logo in the rear replacing the stop lamp so that it glows when the brake is pressed. To remove the stop lamp in SX4, open the boot and there are 2 black clips exactly below the stop lamp. Press it and move it up and now from inside the car remove the stop lamp case, remove the bulb and connect the LED wires into it. You can use your preferred way of connecting it but make sure to put proper insulation to avoid short circuit. I used paper clips to connect the wires since it was easy and can be removed to revert back to old setup (could not take photos)
Now you get bright LED when the brake is pressed, looks jazzy in the night.
Normal:
DIY : Suzuki Logo LED in SX4-6.jpg
When Brake is pressed:
DIY : Suzuki Logo LED in SX4-7.jpg
DIY : Suzuki Logo LED in SX4-8.jpg
gopinathann is offline   (2) Thanks Reply With Quote
Old 27th January 2010, 09:02   #2
tht'snotME's Avatar
Thanked: 29 Times
that really cool.. i suggest to use RED LED's instead... that adds upto as a brake light...
but i would like to again say "one HELL of a Job"
tht'snotME is offline   Reply With Quote
Old 27th January 2010, 09:02   #3
Awesome gopinathan! I am jealous
devendradesh is offline   Reply With Quote
Old 27th January 2010, 09:07   #4
arjunrudra's Avatar
Thanked: 13 Times
Tools required:
4. Resistors
7. Insulation tape
Attachment 274551
Attachment 274552
Attachment 274556
Attachment 274553
Attachment 274554
Attachment 274555
Normal:
Attachment 274569
Attachment 274557
Attachment 274558
Wow this so cool and never thought this would be so easy to make. Thank you +1 to you.
arjunrudra is offline   Reply With Quote
Old 27th January 2010, 13:57   #5
recshenoy's Avatar
Thanked: 104 Times
This is Super DIY dude. really looks cool! i had read that tail light LED color of a Mustang can be changed from cabin. May be one can use those LEDs and change the color according to one's mood.
recshenoy is offline   Reply With Quote
Old 27th January 2010, 14:25   #6
bugatti_86's Avatar
Thanked: 19 Times
Creative,Innovative chennaite...
bugatti_86 is offline   Reply With Quote
Old 27th January 2010, 14:36   #7
Shardul.YamahaF's Avatar
its awesome Dude
Nice work ... Neat and clean
it would look good if some one can try to do it on acrylic number plate with drilling holes in the plate it self .. no chance of getting it stolen
but Your Creation gets 10/10
Shardul.YamahaF is offline   Reply With Quote
Old 27th January 2010, 22:02   #8
Thanked: 20 Times
Thanks for all the compliments. All the inspiration have come from the team-bhp.
gopinathann is offline   Reply With Quote
Old 29th January 2010, 14:20   #9
thedreamcatcher's Avatar
Thanked: 62 Times
Awesome job. We can basically put any design or writing and paste it up, in lieu of the logo also.
Thanks a ton, will try this out soon
thedreamcatcher is offline   Reply With Quote
iPhone 6 DIY: Light Mod Kit (glowing Apple logo) maddyguage Gadgets, Computers & Software 4 25th May 2016 23:51
DIY-Blue LED Parking Lamp & Speedo Meter+Wire Mesh Grille & Underbody Neons for Alto badboyscad DIY - Do it yourself 133 1st March 2015 00:50
DIY - Swift Interior Light Change from stock to White LED sonirohit DIY - Do it yourself 26 27th March 2010 16:16
LED front turn signals for SX4 tabrez02 Modifications & Accessories 27 27th March 2010 15:56
Suzuki SX4 or NHC type 1 second hand EDIT: SX4 now booked - EDIT 1 -Swift VDi booked GeekSrik Hatchbacks 126 24th June 2007 12:37
