Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 31st July 2011, 12:33   #16
Vid6639's Avatar
Thanked: 20,008 Times
Default Re: Headlight Restoration
You also get one from 3M. It can be applied by hand. Requires a lot of buffing and works decently, unless you were using high wattage bulbs and the plastic is burnt
Old 31st July 2011, 12:47   #17
Akshay1234's Avatar
Thanked: 6,773 Times
Post a pic of your headlight so that we can see if the reflector is gone or the lens.
Old 31st July 2011, 12:59   #18
nishantgandhi's Avatar
Thanked: 151 Times
Link plz? If this is the one you're talking about (3M Headlight Lens Restoration System (Rs. 2699)), it may not be best suited to me, as it states "Utilizes the muscle power of a common household (1200-1600 rpm) drill to do all the necessary sanding and buffing".
Yes I have been using 100/90w bulbs since last 2 years.
Will click and post later. Untill then, this pic (left) describes the condition of my headlight the best. It's the lens which is cloudy.
nishantgandhi is offline   Reply With Quote
Old 31st July 2011, 13:04   #19
Vid6639's Avatar
Attachment 585875
Nishant that means that your headlamps are burnt and faded from the inside due to the high wattage.
The restoration kits work for outside fading like driving on sandy roads which is like sand blasting or parked in sun for long time.
Not much can be done for inside damage.
Even the mothers require a drill or powerball as they call it.
These can be applied by hand but they require a hell lot of manual labour in buffing. They work best with the drill as it is easier.
Old 31st July 2011, 15:22   #20
Thanked: 93 Times
Attachment 585875
Feel the outside surface of headlamp. If it appears rough & uneven instead of glossy. Then, it is probably dust that has got embedded in the outer layer of plastic due to heat facilitated 'diffusion'. Try a 100-150 rupee liquid rubbing compound from 3M ,manually. If it responds well, go to a bodyshop & ask them to buff it up using the liquid rubbing compound. They have a similar attachment for polishing cars. Be sure to remove the headlight from the vehicle & also, ask them to select a low rpm so that the lens does not crack.
The 3M product is compatible with machine application also.
Last edited by JustCause : 31st July 2011 at 15:24. Reason: additional details added
JustCause is offline   Reply With Quote
Old 31st July 2011, 19:34   #21
Thanked: 151 Times
Default Re: DIY Guide : How to get the sparkle back in your old (dull) headlights!
Yes, the outside surface of the headlamp feels rough/coarse. It is most definitely from the outside.
Old 19th December 2011, 14:16   #22
k_shanz's Avatar
Thanked: 64 Times
Nice job there. This is one useful tip which many people dont know, even i thought of sharing it. I had done the same very recently, and ended up with good results.
BTW, I dint know the existence of plastic polish, is it the same trims/dashboard shiner?
I had waxed the interior of the lights also, it also helped to a good extend. But removing the glass from the headlight is a big task which require lot of patience.
k_shanz is offline   Reply With Quote
Old 19th December 2011, 19:34   #23
RIC.BURNS's Avatar
Thanked: 102 Times
My Swift had a foggy LHS headlight, Formula1 Scratch Out + rubbing in circular motion all over did the trick for me.
RIC.BURNS is offline   Reply With Quote
Old 19th December 2011, 19:44   #24
IQBAL VEERJI's Avatar
Thanked: 282 Times
Originally Posted by triedeverything View Post
Brilliant! All I have to do now is wait for my car to get old
In my case of CAMRY which is 8 yrs old ,earlier owner had replaced both the headlights and tail lights assly just few months backand now they look brand new at present. I will apply this method when lights become old..
which will take ages as both the head lights and tail lights are original JAPAN made ,unlike those cheap china or malysian makes.Rubb Rakhaa
IQBAL VEERJI is offline   Reply With Quote
Old 19th December 2011, 20:03   #25
Jayant..B's Avatar
Thanked: 7 Times
My Santro is 7 years old and the headlights were becoming yellowish. After reading these posts, today rubbed the headlight lens with toothpaste for about 10 mins each and what a surprise! The effect is amazing and headlights look much much better now. Forgot to take pictures so cannot post here.
Jayant..B is offline   Reply With Quote
Old 20th December 2011, 00:46   #26
Thanked: 22 Times
Could you give detailed instructions please?
I have formula one scratch out with me, and turtle carnauba wax (and the sponge applicator that came with the wax)
What else do i need? sandpaper?,what cloth? how often to spray water? Anything to be careful of?
The RHS light of my dads palio is almost opaque now. LHS is only marginally better.The outside surface of both have become rough to touch
This will be a great thing if it works
Thanks in advance
Joe
Joe-Ker is offline   Reply With Quote
Old 20th December 2011, 15:01   #27
RIC.BURNS's Avatar
Thanked: 102 Times
Thanks in advance
Joe
I didnt do add-ons, for me the rubbing itself was enough. Try circular rubbing the scratch out with a yellow cloth or that sponge on the headlights for some time and wipe it with a clean cloth.
RIC.BURNS is offline   (1) Thanks Reply With Quote
Old 20th December 2011, 16:44   #28
Thanked: 101 Times
I just tried the suggested toothpaste cleanup. Happy to report that the results were excellent!
Ashphil
ashphil is offline   Reply With Quote
Old 20th December 2011, 19:16   #29
Thanked: 22 Times
Thanks!
Reaching back home on 23rd. Let this be my Xmas present to the Palio
Will post pics once done
Old 20th December 2011, 22:55   #30
RIC.BURNS's Avatar
Thanked: 102 Times
Saw this on ZigWheels today. It looks like a pro stuff, could be costlier for car owner on one time job.
New 3M headlight repair kit hits store shelves
Help - Dull or lifeless power steering on my Swift abhaybakshi Technical Stuff 13 31st August 2017 20:36
Please be Warned: Sparkle Car Spa @ Forum and Garuda Mall Bangalore. Tassem Modifications & Accessories 13 26th June 2014 11:45
My new Hyundai i20 CRDi ASTA Sparkle Blue mvj1976 Test-Drives & Initial Ownership Reports 61 10th January 2012 19:01
Dull hammering sound from Suzuki Zeus. Is it normal. Spotty91 Motorbikes 11 29th June 2010 12:30
