Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 24th July 2013, 14:00   #46
DeepakMenon's Avatar
Thanked: 145 Times
Default Re: Type 1 OHC headlight restoration
Buy a 3M headlight restoration kit; it will have all that you need to do a splendid job
do not be aggressive in cleaning the lens; just use colin and microfiber; if that chrome goes; its tata bye bye
removing the dome may just increase glare
lastly your engine revs going down.. no clue.. maybe power load?
DeepakMenon is offline   Reply With Quote
Old 24th July 2013, 15:06   #47
Thanked: 70 Times
@Deepak
Couldn't get hold of the 3m headlight restoration kit anywhere in bangalore.
Anyone has any idea where I can get it?
What is colin?
micraft is offline   Reply With Quote
Old 24th July 2013, 15:43   #48
RM2488's Avatar
Thanked: 117 Times
Originally Posted by micraft View Post
@Deepak
What is colin?
Colin is a household glass and other surface cleaner. You can get it in any supermarket/mall. Costs around 50-60 if I remember correctly.
Now here are my questions:
- Would removing the cup of the reflector improve the visibility? I have seen a lot of cars like Innova, i20 which donít have these cups on the reflectors.
The cups reduce glare and actually increase bulb temperatures somewhat by reflecting IR back on the filament, increasing light output without increasing power consumption. So removing it is not advisable.
- What could I use to improve the reflectors? Mainly the reflector cup which is on the main reflector which is a little rusted?
Use a buffing machine/use fine paper. Finish with jeweler's rouge.
- Where can I get 2000 grit sandpaper or higher to fine sand the lens in Bangalore?
Look for shops dealing in paints. They'll have the fine grit wet-and-dry papers you want.
- Iím planning on fixing white led strips which I also plan to connect to the indicators, any suggestions?
First- connecting them to indicators? You want white turn signals? Most people attach them to parking lamps.
Second- Bad quality LED strips will not last long.
I think it just looks ridiculous unless you go for a proper angel eyes effect.
- Another interesting thing is that whenever I switch the headlights, the engine revs down for some time, any ideas how to diagnose this? This is not only for the headlights, but even for the power windows and definitely the A/C, but maybe this should be in another thread.
This is common across cars, the ECU takes some time to readjust idle. But if it is inordinately long, perhaps the battery/alternator needs to be looked at.
RM2488 is offline   Reply With Quote
Old 25th July 2013, 01:11   #49
Thanked: 70 Times
Default Re: Type 1 Honda City - Headlight Restoration
Thanks rm2488.
I searched around in a lot of paint shops, they never heard of 2000 grit sandpaper, though I was able to get 1200 grit in one shop.
Jeweler's rouge sounds good, will be trying to get that.
The idle lag is not for a long time.
Hmmm, I guess the alternator send signals to the ECU...
Old 7th August 2013, 15:34   #50
Thanked: 70 Times
Posting the pics after the work....
Looks fine, better than what i expected..
Thanks everyone...
Old 7th October 2017, 10:31   #51
ashis89's Avatar
Thanked: 1,050 Times
Default Re: DIY Guide : How to get the sparkle back in your old (dull) headlights!
My headlights are not dull though they are not new as well (6 yr and 55k kms old). On top of that, I have started using 100/90W bulbs in it now.
I see that there a thin plastic layer peeling off in some areas of the headlight. Is it the clear coat? Will it hasten the deterioration of the headlights? Can I stop it in anyway?
TIA,
Ashis
ashis89 is offline   Reply With Quote
Help - Dull or lifeless power steering on my Swift abhaybakshi Technical Stuff 13 31st August 2017 20:36
Please be Warned: Sparkle Car Spa @ Forum and Garuda Mall Bangalore. Tassem Modifications & Accessories 13 26th June 2014 11:45
My new Hyundai i20 CRDi ASTA Sparkle Blue mvj1976 Test-Drives & Initial Ownership Reports 61 10th January 2012 19:01
Dull hammering sound from Suzuki Zeus. Is it normal. Spotty91 Motorbikes 11 29th June 2010 12:30
